Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Mar 19, 2020 at 12:58 PM
    #341
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    My buddy got his hitch powdercoated. Not sure why he didn’t do orange.
    ColoradoTJ and Tractorman like this.
  2. Mar 19, 2020 at 1:42 PM
    #342
    ralfnjan
    ralfnjan Well-Known Member
    Shoulda welded some hooks on that frame for chain pulling...cars, logs etc.
    Tractorman and six5crèéd[OP] like this.
  3. Mar 19, 2020 at 5:20 PM
    #343
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    If you knew my buddy and his tractor skills you’d know why I didn’t. I have hooks on mine :D
    Tractorman and EdinCincinnati like this.
  4. Mar 19, 2020 at 7:15 PM
    #344
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I have friends like that. Smart decision!
  5. Mar 20, 2020 at 3:08 AM
    #345
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Here’s the hooks on my hitch, actually have 2 hitches, one is cat 1 and one is cat 2 a little beefier. Two hooks for pulling straight and one for pulling up. The one for up works great on fence post. I also put a piece of pipe in the center and have a bale spear for it and a gooseneck ball for moving the trailer around.
    Tractorman and Noelie84 like this.
  6. Mar 20, 2020 at 3:10 AM
    #346
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Used the hitch (another one with a fast hitch adapter) last year to get a power pole from a neighbor.
  7. Mar 20, 2020 at 4:22 AM
    #347
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Has steel gone crazy in the last 6-7 years in your area? Around here the price of channel, tube, and angle seems to have almost doubled since I started welding again.
  8. Mar 20, 2020 at 4:23 AM
    #348
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Yes, it's about doubled around here in the past 6-7 years as well.
    Tractorman likes this.
  9. Mar 20, 2020 at 6:14 AM
    #349
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Gotta get creative. My scrap guy will let me dig his pile and sells at weight price. Think I got ~150lbs of cut offs for $14 last time I went.
  10. Mar 20, 2020 at 6:47 AM
    #350
    Noelie84
    Noel
    Wales, Maine
    My local scrapyard mostly just has cars/parts, washing machines, water heaters, etc. Never seems to have much for structural steel unless you're looking for the big I-beams from mobile home frames.
    :pout:
  11. Mar 20, 2020 at 7:02 AM
    #351
    Steve Urquell
    I have one scrap place like that and another that sells steel and also has a scrap pile. Look at your steel supplier and see if they sell drops or take in scrap.
  12. Mar 20, 2020 at 7:23 AM
    #352
    Noelie84
    Noel
    Wales, Maine
    Yeah, I'll have to ask them if they sell the cutoffs next time I'm up. I know they don't take in scrap, but I'm not sure what they do with their odds & sods.
  13. Mar 20, 2020 at 7:27 AM
    #353
    Steve Urquell
    Drops are usually much cheaper. Also look on FB marketplace. I caught a fab shop moving and bought a bunch from them for really cheap awhile back. I've also scored at the restore resale shop locally.
  14. Mar 20, 2020 at 5:13 PM
    #354
    Steve Urquell
    Had the day off and got in some seat time. Cut a bunch of brush and edges where I mow. Let a bunch of the edge stuff lie and hooked up the brushhog and chopped it up.
    Also finished brushhogging my county road frontage which was 5ft tall field grass. Rats as big as my foot were running out. Twas a good day on the seat. 20200320_160352.jpg
  15. Mar 20, 2020 at 5:19 PM
    #355
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Got a little seat time today too, put some fertilizer on the goat lot.
  16. Mar 20, 2020 at 5:20 PM
    #356
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Friend of mine saves me his small rolls for our goats. Went and got one on the trailer feeder I made a few years ago to make it easier to get and also clean the old hay out of the shed. Tractor barely clears the header.
  17. Mar 21, 2020 at 5:05 PM
    #357
    Noelie84
    Noel
    Wales, Maine
    Today was a maintenance day, since everything's still too soft to get out and work it. Oil & filter change, blew out the air filter, changed the fuel, hydraulic, & HST filters, and topped off with fresh fluid. Greased every zerk and ball, and then swapped the front universal & portal fluids. I considered changing the HST/hydraulic & power steering fluids, but everything was still perfectly honey-colored so I didn't bother.
  18. Mar 23, 2020 at 8:49 AM
    #358
    Steve Urquell
    A little more brush burning today. Moved a bunch of long sumac with a pallet on my rear fork lift set. Lifted a 23ft tall tree to haul to the brushpile.
    Before any safety nanny loses their mind. The pic was right after I lit the pile and I moved the tractor right after the pic. Tractor is 30ft from the pile. 20200322_174905.jpg 20200323_092904.jpg 20200323_095545.jpg
  19. Mar 23, 2020 at 10:10 AM
    #359
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Welded a piece on this broken fertilizer bracket today.
  20. Mar 23, 2020 at 5:17 PM
    #360
    Steve Urquell
    So the sleeve hitch fork set was built for my other GT and the angles are wrong for my 3240. Using it pissed me off more than helped. I said to heck with that nonsense today and built a forkset for my bucket.
    My other set is also T-posts and handle 400lbs well so I'm fine with them for my bucket as I don't intend to lift >300lbs with them. Strangely enough they are high tensile rail steel and are unbelievably tough for their size. I wanted no tool attach so built it to use 1/2" pins.
    I plan to build a couple plugs to keep dirt out of the retention pipes. If I bend a T-post I'll build some pipe forks. Ran out of time and will squirt some black on it later.
    20200323_152352.jpg 20200323_160650.jpg 20200323_164822.jpg 20200323_165638.jpg 20200323_172709.jpg 20200323_172718.jpg 20200323_181227.jpg
