Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. May 13, 2021 at 4:10 PM
    #3681
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Well, it took 3x as long as planned and cost 3x as much -- my $100 New Holland is ready to go, with Daisy along to help.KIMG1405.jpg
  2. May 13, 2021 at 4:13 PM
    #3682
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Well, almost...
    This MoJack is great to use but is big as a piano to store.
  3. May 13, 2021 at 4:19 PM
    #3683
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Several hours later...
    Raised the property value from "abandoned" all the way up to "poorly maintained".
    For a single cylinder job (Kohler Command 15) this little guy rips right along, the deck is a 42". Love the foot pedal hydro, so intuitive to use, I have an old Craftsman on the fender, silly place to put it. KIMG1408.jpg
  4. May 13, 2021 at 4:24 PM
    #3684
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Here's my old Wheelhorse version of your NH. I love my lift and take off the arms to minimize the footprint.
  5. May 13, 2021 at 4:28 PM
    #3685
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Your lift looks much heavier than mine. I think they are all space hogs.
    Looks like you WH has wheel covers? Deluxe!
    six5crèéd[OP] and T-yoda like this.
  6. May 13, 2021 at 4:28 PM
    #3686
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    This autta be a barrel full of laughs....
    six5crèéd[OP], Jtcmedic and T-yoda like this.
  7. May 13, 2021 at 4:33 PM
    #3687
    Steve Urquell
    This lift is a tank. Without the arms it is an ATV lift with 750lb capacity.
    Get em up at bench height and spray the beads with cooking spray. Extra set of hands helps. I like to have a board down to push the rim up against to prevent sliding. I steer the tires on like a steering wheel. Prepare to curse.
  8. May 13, 2021 at 4:36 PM
    #3688
    Steve Urquell
    Here's my Fischer lifting my 1000lb XT3
  9. May 13, 2021 at 5:04 PM
    #3689
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    replaced both of mine. 2nd was a hell of alot easier.. to break the bead i used a 2x6 and my truck. Gave my drive and reverse gear selector a workout
    soapy water around the rim and a long flat head screw driver + tire install iron from Harbor freight made quick work if you know what your doing
    Good luck
    wd40 works well to seal the bead but if your not comfortable with fire a ratchet strap or just a simple bouncing it while filling with air works
  10. May 13, 2021 at 5:17 PM
    #3690
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Get a deep jaw bar clamp. Squeeze the tire until it's oval shape. The rim slides right out.
  11. May 13, 2021 at 5:22 PM
    #3691
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I did 8 mower tires in a month.
    Fortunately my old Farmall 140 came with the bead breaker attachment.
    If you can bolt the wheel to something good and heavy it really helps, I used a piece of all thread.
    I take the valve core out and use the blow gun to help seat the bead.
  12. May 13, 2021 at 5:23 PM
    #3692
    auskip07
    Skip
    Atlanta, Ga
    That bead breaker is useful
  13. May 13, 2021 at 5:32 PM
    #3693
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Holy shit my Gravely caught fire today!!!
    six5crèéd[OP], T-yoda and auskip07 like this.
  14. May 13, 2021 at 5:34 PM
    #3694
    RustyGreen
    sleeping in a chair
    Pavement Princess
    That idea came after fighting with the first tire for 30 minutes :annoyed:, the other 7 were way easier.
  15. May 13, 2021 at 5:35 PM
    #3695
    Steve Urquell
    Details homes.
  16. May 13, 2021 at 5:35 PM
    #3696
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :eek:
    Bad?
  17. May 13, 2021 at 5:35 PM
    #3697
    auskip07
    Skip
    Atlanta, Ga
    had the same experience with the first tire. the damn thing fought me for 30 min. Even the 2x6 and truck weight didnt budge the beam. 2nd tire was off in 2 min
  18. May 13, 2021 at 5:41 PM
    #3698
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Not a FUEL fire thank god! UNIT IS OK I THINK.
    Mowing along......wood smoke, grass smoke.............what the hell??? TONS OF SMOKE - WIFE COMES RUNNING OUT! Quick over to a moist area. Seemed like a little friction fire center blade, caught some sticks and a pine cone or three. We live in a wet area. I cannot imagine how this may of taken off in a DRY place...............
    six5crèéd[OP], Zeke588 and T-yoda like this.
  19. May 13, 2021 at 5:46 PM
    #3699
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Glad the unit is ok!
    So under the deck caught fire with smoke coming out along with the clippings??
  20. May 13, 2021 at 5:49 PM
    #3700
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Exactly.
