Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. May 16, 2021 at 7:43 AM
    #3721
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Saw this pic posted on "Orange Tractor Talks". Thread was asking folks to guess how this happened. I replied it started with " dude, hold my beer", and ended with "no way dude!".
    At least the tractor looks unharmed,...and, it was only a Ford, so.
  2. May 16, 2021 at 7:47 AM
    #3722
    Wsidr1
    Indiana
    Got some use out of my Kubota (GL3130) yesterday. Cherry tree down in hay field. Nice firewood for next Winter.
  3. May 16, 2021 at 7:57 AM
    #3723
    G.T.
    G.T.
    CONUS
    Nice and clean.
    Replaced the offending cable, found the wire to the coil a little loose so sorted that, new plugs arrive soon-ish as a mate grabbed them on his way over. Starter and switch good. No replacement plug wires on hand so hoping they will be good to go until replacements can be sourced. Of the two oil petcocks on the side of the pan, one has its adjustment tab missing making it a ballache to open. Luckily it’s the lower one and with the upper open you just let it weep/drip until it stops and that will let you know that you are at the max level.
    Heading out in a few to pull the carb to clean and inspect. I’ve worked on a few Farmall carbs before and they are almost as easy as ‘30s era John Deere carbs.
  4. May 16, 2021 at 9:41 AM
    #3724
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    New mower arrived yesterday. Should say “my sons”. For now I’ll take it.
  5. May 16, 2021 at 9:50 AM
    #3725
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    I see a chain binder on the ground. Most likely didn't check tension after going a little ways when everything had settled or have an extra safety system in place.
  6. May 16, 2021 at 10:29 AM
    #3726
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    My ZT didn't come with a son to run it!! Dang it!!
    (Nice!)
  7. May 16, 2021 at 10:49 AM
    #3727
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    :101010:
    RustyGreen and T-yoda like this.
  8. May 16, 2021 at 10:51 AM
    #3728
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Pretty foolish to pull a backhoe with that size truck, even a dually with a 5th wheel would be pushing your luck
    Driver made more than one mistake I’d bet!
  9. May 16, 2021 at 1:55 PM
    #3729
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    That is an extra, pretty costly over the long haul when it'll run you a tenner and a pizza or a Jefferson for each mow. However, he WILL know exactly how high it will pull a wheelie on hard ground.
  10. May 16, 2021 at 2:00 PM
    #3730
    fxntime
    And don't forget the condenser, it is often overlooked but will fry your points in short order if it fails.
    [I just rip both out and install a point replacement kit or module. Usually stupidly cheap and so worth the money.]
  11. May 16, 2021 at 2:14 PM
    #3731
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    That looks like an L series Kubota...6-7k lbs tops with attachments and fluid filled tires. Well within the limits of a 10k tag trailer and f250.
  12. May 16, 2021 at 2:28 PM
    #3732
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    No kidding? I assemble backhoes at Deere, nothing I’m around is anywhere near that light.
  13. May 16, 2021 at 7:43 PM
    #3733
    Steve Urquell
    I did a bunch of tire work today getting ready to paint my 3205 and prepping wheels, switching good tires on to golf cart wheels as I'm converting the spindles to 4-lug boat trailer hubs. Broke beads with my new HF tire breaker and was happy with it.
    Did a little test of Van Sickle IH yellow to see if it's close enough to suit me. Looks good and I will proceed to use it to paint the 3205 in Yanmar Sc2400 colors. This was the spray can version on the back side of a wheel but I'm gonna buy a gallon and use hardener. I'm having custom decals made for it as well.
  14. May 17, 2021 at 3:14 AM
    #3734
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That’s going to look good :thumbsup:
  15. May 17, 2021 at 4:50 AM
    #3735
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    That was my guess, as well. Now, THIS guy knows how to tie down a tractor.
    The weight shouldn't be an issue. That looks like an L series tractor, so well below 10k even with loaded tires and backhoe. Even the biggest Kubotas, the M-series, probably wouldn't be much over 10k in loaded-tire TLB form. Still within spec for a properly fitted F250 (as long as you secure the load correctly, at least!)
    Lt. Dangle, Snowy, Zeke588 and 6 others like this.
  16. May 17, 2021 at 4:54 AM
    #3736
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Yeah I didn’t realize anybody made such small backhoes. Deere’s lightest (with a boom & dipper at least, not the landscaper kind) is 15,000 or so, on up to 25,000!
    That’s why so many folks do backhoe work with a skid steer & mini - they can pull those around much safer.
    Anyway, thanks for the correction, I digress! :cheers:
  17. May 17, 2021 at 5:10 AM
    #3737
    Steve Urquell
    Thanks, getting excited about painting it now. I can't get my ebay decal guy to reply to me though. Any suggestions for an online custom decal guy?
  18. May 17, 2021 at 5:13 AM
    #3738
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I've heard of someone on here making decals but I can't remember who it is :confused:
    RustyGreen, koditten and T-yoda like this.
  19. May 17, 2021 at 5:14 AM
    #3739
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    A M62 with a loader is 8925 lbs without any rim guard.
    F-250 can conventional tow ~15000 lbs in that generation. F-350 even more.
  20. May 17, 2021 at 5:15 AM
    #3740
    Noelie84
    Noel
    Wales, Maine
    Are you talking TLB's, or actual dedicated excavators? Because they've got their overseas-manufactured compacts that are available as a TLB, and those wouldn't weigh anything close to 15k
