Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Mirrors on your tractor?
  1. Yes, have them and love them
    25.0%
  2. No, stop living in the past
    16.7%
  3. Wanted, but not yet acquired
    33.3%
  4. Have mirrors, need tractor
    25.0%
  1. May 17, 2021 at 5:16 AM
    #3741
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Hmm, search time.
  2. May 17, 2021 at 5:16 AM
    #3742
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Think I’m just going to pick up a new box blade instead of looking for a good used one. Most of the used ones are pretty beat up and want as much or more than a new one.
    Called my local Kubota dealer and a new Land Pride 60” BB is around 770.00
  3. May 17, 2021 at 5:18 AM
    #3743
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    You'll be happier in the long run, not buying someone else's junk or paying almost new when you could have new. Land Pride makes good stuff :thumbsup:
  4. May 17, 2021 at 5:18 AM
    #3744
    ColoradoTJ
    Colorado
    @Daria
  5. May 17, 2021 at 5:23 AM
    #3745
    Fitzwilly
    Fitzwilly Well-Known Member
    Bill
    South Central Mass
    2018 JKU "Golden Eagle" Edition
    i have a vinyl cutter for single colors or I can print then cut on gloss vinyl then maybe clear coat?
  6. May 17, 2021 at 5:39 AM
    #3746
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    By mini I meant actual dedicated mini excavators.
    The 15k - 25k weights are the range of backhoes built here in Dubuque, which are the 310, 410, and 710
  7. May 17, 2021 at 5:40 AM
    #3747
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Please report back.
    I'm looking for a cheaper alternative to what Toro and Exmark ask for their decals.
  8. May 17, 2021 at 5:41 AM
    #3748
    koditten
    Kirk
    Central Michigan
    Guess I should have read to the end of the thread.
  9. May 17, 2021 at 5:43 AM
    #3749
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Yeah, ok. Actual commercial stuff. That'd definitely weigh more.
  10. May 17, 2021 at 5:45 AM
    #3750
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    That's all I have experience with! They're not something you pull around with a pickup, and I just saw a backhoe with an F250 in front of it and thought "well duh" :rofl:
  11. May 17, 2021 at 5:49 AM
    #3751
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    That's another thing I learned today, I had no idea those trucks can pull that much these days. Is that without a gooseneck?
    EDIT: I see you said "conventional" so I'll be quiet now, hahaha
  12. May 17, 2021 at 5:55 AM
    #3752
    Fitzwilly
    Bill
    South Central Mass
    let me know what you need and I’ll see if I’m able to do it. I use oracal 651 all weather permanent vinyl for most of my outdoor applications. I made some print then cut and coated them in outdoor clear coat, haven’t been able to see the sun effects yet...
  13. May 17, 2021 at 5:55 AM
    #3753
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    I pulled a 53 footer for a few years and it's crazy to me that you can hook up to 1/3 the weight with half the axles and brakes and a normal driver's license!
    I'm feeling out of my element in more ways than one! Happy Monday, I need to get to work :rofl:
  14. May 17, 2021 at 6:25 AM
    #3754
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Agreed with whomever said way too rich. Also, this machine wasn't upgraded to a one-wire alternator was it? I got a brand new one-wire from YT and I think the diode pack is bad. If I let the tractor sit with the battery hooked up it'll drain it overnight. I put a battery disconnect on the negative terminal. Easier than sending it back. Still charges perfectly.
    Also this- and when I still had points/condenser in my MF35 Utility, I went through several condensers. Most of the new ones are cheap Chinese junk. Got tired of it and did as fxntime said- upgraded to an electronic ignition module. Between that and the alternator upgrade, the spark on my machine has never been so hot. I'm talking fat, blue spark that snaps hard and looks like lightning. WELL worth the upgrade and easily reversible if you want to go back to "collector item".
    If that's the HF tire changer, be careful with that bead breaker if you use it on some really stuck beads. It WILL bend, and if you reinforce it, the tube section it's attached to WILL bend. Ask me how I know. lol
    I need to rebuild my bead breaker and find a piece of thicker tubing to use for the handle point, I bent the hell out of it all swapping tires for my wife's Subaru.
  15. May 17, 2021 at 6:35 AM
    #3755
    Noelie84
    Noel
    Wales, Maine
    The towing #'s on the new diesels are just nuts. You need a CDL to even take advantage of close to what they're rated for. Conventional tow ratings for like 20k and over 30k on a 5th wheel, even for the 4x4's
  16. May 17, 2021 at 7:15 AM
    #3756
    G.T.
    G.T.
    CONUS
    Added a quick disconnect to the negative terminal as well, do that with all of my equipment that has batteries for GP.
    two wire alternator on it, will troubleshoot more in a few days, dialysis today and the boy has scouts this evening.
  17. May 17, 2021 at 8:55 AM
    #3757
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    MSRP on the big 3 setup for towing are around $90 grand so I'd hope they've come a LONG way but that is absolutely nuts - I bought my first goddamn house for 95K!
    Thanks for going easy on me guys, I didn't mean to dumb the thread down :rofl::cheers:
  18. May 17, 2021 at 9:03 AM
    #3758
    Noelie84
    Noel
    Wales, Maine
    Hell, I bought my CURRENT house for $95k, lol.
    And no worries about the conversation; there's a difference between ignorance and being dumb. :thumbsup:
    There's a reason that I'm always complaining about wanting a light duty diesel option for the HD trucks. Something with the numbers of a late-production 5.9 Cummins or early 6.6 Duramax; 500-600 ft/lbs and 20+ mpg. I don't need 1000 ft/lbs; but I want something that can comfortably tow mid-teens and won't devour its transmission, that can still take a plow and give good fuel economy unloaded.
    Edit: Basically, I want a truck from 2005 but with 8 speeds, a warranty & without 15 years of wear & tear :laugh:
    T-yoda, RustyGreen, Zeke588 and 3 others like this.
  19. May 17, 2021 at 9:05 AM
    #3759
    ColoradoTJ
    Colorado
    It was a legit conversation. All good.
  20. May 17, 2021 at 9:08 AM
    #3760
    ColoradoTJ
    Colorado
    Through the mountains to grandmothers house my truck does did pretty good at 60-65 mph.
