Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    45.5%
  2. After
    57.6%
  3. Neither
    12.1%
  4. I weed whack while someone else mows
    6.1%
Multiple votes are allowed.
  1. May 22, 2021 at 1:25 PM
    #3841
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    That’s how I know my sons 1963 JD 110 needs oil, when it’s not smoking :rofl:
  2. May 22, 2021 at 3:23 PM
    #3842
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    My son is fighting poison and I gotta mow a customers yard :anonymous: guess I’ll do it myself... he says “do I have to” I says on you relax I’ll enjoy the 90degree weather myself .... didn’t realized we were in August o_O
    six5crèéd[OP] and RustyGreen like this.
  3. May 22, 2021 at 3:26 PM
    #3843
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    New bushings and pins for the Toro deck.
    Total cost $4-$5.
  4. May 22, 2021 at 4:41 PM
    #3844
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    Maintenance day. Engine oil and the 2 fuel filters. This 2nd had matching is now all caught up on its fluids.
  5. May 22, 2021 at 7:17 PM
    #3845
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Helped my son with his 2 mowers that didn’t run ... push mowers with Briggs/stratton engines and both with plastic carbs.... easy peasy. He takes the carbs off and I clean them... I show him what to do. He gets them back together and 1 runs and the other tries to run.... I look at his install work :-/ somehow he had the choke arm jammed closed. Kids! ;-) he’s learning. They both run now ... time for bed. Long day it was
  6. May 23, 2021 at 8:22 AM
    #3846
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    I meant to post this awhile back but the oil filters that fit our 2.7L Tacos also fit Kohler engines. I buy the Toyota filters in a 10pk from Amazon for $4 each and have them on hand. I think the kohler filters are $8-10/each. My 2 Kohler Commands have Toyota filters on them.
  7. May 23, 2021 at 8:41 AM
    #3847
    koditten
    Kirk
    Central Michigan
  8. May 23, 2021 at 8:59 AM
    #3848
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Man GT, your luck has to change soon.
  9. May 23, 2021 at 9:06 AM
    #3849
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    :anonymous: Not gonna lie, but that middle pic had me just a‘lil Spooked. Spoiler or disclaimer coulda helped.
  10. May 23, 2021 at 9:13 AM
    #3850
    G.T.
    G.T.
    CONUS
    If it weren’t for buzzard luck I’d have none at all.
    Truth is that this machine has sat idle for over ten years so I’ve expected that it would need heaps of maintenance to get it sorted again. It’s just everything else that being thrown in my path this month which makes it so frustrating.
  11. May 23, 2021 at 9:29 AM
    #3851
    ColoradoTJ
    Colorado
    Right? I would go down to the local convenience store and buy some lottery tickets. Your number is due...big time.
  12. May 23, 2021 at 10:45 AM
    #3852
    Steve Urquell
    Brush hawging with the Swisher today. Pulled by the nekkid liquid cooled 3205. Grass is 30+ " high. The Swisher DGAF, cuts the same at 5mph as it does at 2mph.
  13. May 23, 2021 at 2:50 PM
    #3853
    koditten
    Kirk
    Central Michigan
    Drilled the rivets out of all three idler pulleys. I have new bearings that cost me about $3 each. Buying new idler pulleys complete cost around $30 each. just seems to make sense to grind the rivets out and install bolts with a new bearing.
    I pop the bearing cover off the new bearing and add additional grease.
  14. May 23, 2021 at 2:53 PM
    #3854
    ColoradoTJ
    Colorado
    Well, at least something is getting use out of the loader bucket.
  15. May 23, 2021 at 2:56 PM
    #3855
    ColoradoTJ
    Colorado
    That’s money right there. Nice modification.
  16. May 23, 2021 at 3:55 PM
    #3856
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Kendall Super Blue grease?
    six5crèéd[OP] likes this.
  17. May 23, 2021 at 4:17 PM
    #3857
    koditten
    Kirk
    Central Michigan
    I don't know. I can't remember what the can said. I squeegied out the leftovers and put the grease in a 2 gallon bucket. This was 15 years ago. I still have a lot left.
  18. May 23, 2021 at 5:26 PM
    #3858
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That’s good to know, my welder and mower both have Kohler engines.
  19. May 24, 2021 at 4:43 PM
    #3859
    ColoradoTJ
    Colorado
    Loaded up this morning....
    Came back 408 lbs heavier.
    Decided on the 66” box blade. 6” matters.
    CrippledHo, G.T., Zeke588 and 9 others like this.
  20. May 24, 2021 at 4:52 PM
    #3860
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I do the same thing on my Kohler V-Twin. I can barely squeeze a 3614 equivalent in there, but it fits. I used a $4 STP this time around. Locally Kohler filters are $12-$13 :eek:
    I used a fatter sized filter one time with the same thread pitch and gasket size. Think the filters fit alot of AMC cars back in the day.
    However the steering linkage in my Cub got it dented a little bit...
    Thread size is 3/4-16 and the gasket size is roughly 3" for those who want to go down the rabbit hole of filter cross referencing. Pretty sure Briggs will take the same filter. The Kawasaki filters have the same thread pitch size, but smaller diameter.
