Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    46.2%
  2. After
    57.7%
  3. Neither
    15.4%
  4. I weed whack while someone else mows
    7.7%
Multiple votes are allowed.
  1. May 24, 2021 at 4:54 PM
    #3861
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Did you get a brand new one?
    Now I'm wondering how those teeth are held in.
    Looks like some kind of spring clip in the back forcing them forwards in a notch?
  2. May 24, 2021 at 6:38 PM
    #3862
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Yes I did buy new. I have been looking for a while for used. The ones I have seen were either 48” or 72”+ and way overpriced. The last one I seen was 800.00+, rusty, fixed blade, and 4 hour drive one way.
    This is how it attaches:
  3. May 24, 2021 at 6:45 PM
    #3863
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    A few days ago I excavated the chipper from the shed, I last used it in 2010 near as I can tell -- work got in the way of life for the last 10 years or so...
    New battery -- $56, it is an all plastic sealed job only about 1/3 size of a regular mower battery. Oil & grease, found a new knife in the garage (from 2004).
    Had some squatters under the fuel tank. Funny, the fuel didn't have the awful varnish smell of bad modern fuel - it was old enough to be real no ethanol fuel.
    Fortunately I always use the fuel shut off valve, there was fuel left in the tank but the carb was stored dry.
  4. May 24, 2021 at 6:49 PM
    #3864
    RustyGreen
    sleeping in a chair
    Pavement Princess
    It has a Vanguard 16 twin, amazing smooth and quiet. Naturally Daisy had to supervise.
    Ginger needs a wash -- she has been my daily since the brake locked up on the van.
    Too lazy to fix it yet.
  5. May 24, 2021 at 6:54 PM
    #3865
    RustyGreen
    sleeping in a chair
    Pavement Princess
    This is such a satisfying machine to run, converts a big pile of crap to chips, gives a real sense of accomplishment -- like taking things to the dump.
    Really takes a 3 person crew to be efficient, 1) to bring the brush 2) feed the machine 3) keep the discharge clear -- 3 people make brush piles vanish in minutes.
  6. May 24, 2021 at 6:56 PM
    #3866
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Yard supervisor approved this load.
  7. May 24, 2021 at 6:56 PM
    #3867
    RustyGreen
    sleeping in a chair
    Pavement Princess
  8. May 24, 2021 at 7:57 PM
    #3868
    ColoradoTJ
    Colorado
    Nice supervision you have there.....and from the looks of it a great piece of land.
  9. May 24, 2021 at 8:18 PM
    #3869
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Need to discharge chips directly into the wagon. Work smarter, not harder. :)
  10. May 24, 2021 at 8:21 PM
    #3870
    RustyGreen
    sleeping in a chair
    Pavement Princess
    She is six pounds of "I'll do whatever I darn well please" :laugh:, fears nothing -- deer, bear, turkeys, vacuum cleaners, lawn mowers...
    Only 3 houses on our dead end dirt road, can't get much better for traffic!
    Everything is on a hill however, which I have been fighting with for 27 years. I don't mind living on the hill -- living with it is a p-i-a!
  11. May 24, 2021 at 8:24 PM
    #3871
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I was contemplating taking the small deflector off the discharge and trying just that.
    They come out with quite a bit of force, might blow right out of the wagon.
    six5crèéd[OP] and T-yoda like this.
  12. May 24, 2021 at 8:55 PM
    #3872
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Injun ear a way to keep 'em in there! :oldglory:
  13. May 25, 2021 at 3:44 AM
    #3873
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    make some pins from square stock to drop down behind the teeth, deep enough to go thru to bottom, and a 90° bend at top . this is how mine is and haven't lost any in 10-12years.
    If you get into some heavy roots the front top of the shank pocket will start to break out ( mine has done this ) at some point i'll weld a face plate to beef up the front.
  14. May 25, 2021 at 5:41 AM
    #3874
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    NrWljv44WCYxv9CIWpZ9JvhK3ZcmwNL29mDflwba_618403460184bebf96e622270cda17ce1f7f9cc4.jpg
    Picked this up second hand yesterday - It's a 2008 with 500 hours and change on the clock. It has a few little dings and scrapes, but nothing bad for its age. Mechanically, it seems to have been maintained well. Blades, belts, air filter, and transmission fluid all looked brand new and the deck is clean. I put new NGK plugs in it last night and am going to change the oil and filter tonight so I have a starting point there. I also ordered a new seat since the one that's on it has some cracks and is the biggest thing dragging the appearance down.
    The differential lock is amazing, I doubt I'll ever be able to go back. It's tougher to get it stuck than my old Craftsman to begin with due to the bigger tires and weight, but I found some spots yesterday to deliberately try it. Just hit the lock pedal and it goes!
    This is a plain X500 so it doesn't have power steering or the hydraulic lift deck. I can't imagine why I'd want power steering, it steers super easy. The pedal lift for the deck works fine, too.
    Two annoying things - the fact that it kills the PTO if I back up and don't hold the override switch drives me nuts. And the drive pedals don't return immediately. It takes maybe a second for them to move back to a neutral position. Interestingly, there's a shock connecting the pedal rod to the transaxle so it seems like this may be by design to make slowing down less abrupt?
  15. May 25, 2021 at 6:36 AM
    #3875
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Nice tractor but I envy your neat organized shop more! :jellydance:
    My garage looks like a tornado hit a flea market... :anonymous:
  16. May 25, 2021 at 6:44 AM
    #3876
    js312
    Joe
    New England
    Ha, thanks! I need a shed to put the tractor, ATV, snowblower, push mower, weedwacker, and pressure washer in. In the summer it isn't a big deal because only the girlfriend parks in the garage. In the winter I like to park in there too, though, so I don't have to clear off the truck and so the driveway is empty and easier for snow removal. That stuff ends up getting moved to a canopy out back which isn't my favorite solution.
    That was going to be something for this summer, but a lot of the funds for it just went toward this tractor. My last one went through what I think is just a spindle, but I decided I was done working on something that didn't really suit my needs to begin with.
  17. May 25, 2021 at 7:00 AM
    #3877
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Thought the same. It would take all my will power not to mix up those end wrenches when you weren't looking.
    T-yoda, js312, CurtB and 2 others like this.
  18. May 25, 2021 at 7:20 AM
    #3878
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Dude, that is cold hearted cruelty... :devil::devil:
  19. May 25, 2021 at 12:33 PM
    #3879
    koditten
    Kirk
    Central Michigan
    To the road she goes.
    How much I'll get?
  20. May 25, 2021 at 1:00 PM
    #3880
    ColoradoTJ
    Colorado
    I’m not sure what I was doing without a box blade...
