Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Mirrors on your tractor?
  1. Yes, have them and love them
    25.0%
  2. No, stop living in the past
    16.7%
  3. Wanted, but not yet acquired
    33.3%
  4. Have mirrors, need tractor
    25.0%
  1. May 31, 2021 at 9:50 AM
    #3941
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Has it been sitting for awhile? I'd start with spark and then go to the fuel pump.
  2. May 31, 2021 at 9:53 AM
    #3942
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    No. Used it cut the grass 2 days ago.
  3. May 31, 2021 at 10:22 AM
    #3943
    fxntime
    If you have a 12v test light, they are pretty easy to determine if the fuel pump is bad. There are some really good videos on line to show you how. You can also check to see if power is going to the pump with one. Can you hear the pump priming when the key is switched to the on position?
  4. May 31, 2021 at 10:49 AM
    #3944
    koditten
    Kirk
    Central Michigan
    Yep, can hear the pump cycle when key it turned to run position, then turns off when fuel pressure is reached.
  5. May 31, 2021 at 10:51 AM
    #3945
    fxntime
    That is normal then. Need a kit to check the pressures which should be 39 PSI +_3. Did you check for spark?
  6. May 31, 2021 at 1:39 PM
    #3946
    koditten
    Kirk
    Central Michigan
    Yep, has great spark.
    I drained the tank. Fuel looked good.
    I need to put in some new fuel next.
  7. May 31, 2021 at 2:18 PM
    #3947
    koditten
    Kirk
    Central Michigan
    New fuel added. No change.
    Walking away for the day. Several beers calling my name.
  8. Jun 1, 2021 at 4:45 AM
    #3948
    fxntime
    I'd try a very short shot of starting fluid to see if it fires, if it does, even for a second, then it's going to be in the fuel supply system. Does it have a filter? and make sure the o2 sensor is hooked up and hasn't had the wires chewed on. In fact, check all the wiring for rodent damage. Check all your molex connections to make sure they are secure. And I know you will likely have a fuse panel, check those and make sure they are all good and secure.
    RustyGreen, Pablo8, koditten and 2 others like this.
  9. Jun 1, 2021 at 2:30 PM
    #3949
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Think it’s a sign. :amen:
  10. Jun 1, 2021 at 3:06 PM
    #3950
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Speaking of mowers, because I have no life, or had too many beers I decided to clean up the Cub. Pressure washed but not only that, I followed up with a coat of one of those ceramic sprays :rofl:
    RustyGreen, T-yoda, Bushed and 5 others like this.
  11. Jun 1, 2021 at 3:13 PM
    #3951
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    It’s too shiny to mow with :cheers:
  12. Jun 1, 2021 at 3:20 PM
    #3952
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Heh, yea, gonna be a shame to get it dirty again. Maybe with the spray coating it won't stick as bad. If not, it'll atleast be easier to clean off. My one neighbor was passing by and seen what I was doing. Just chuckled and shook his head :rofl: Jokes on him, I also used the same stuff on my trash can to try and perk up the faded plastic. I'll say it works pretty good; nicest old trash can in the neighborhood. :rofl:
  13. Jun 1, 2021 at 3:31 PM
    #3953
    fxntime
    Too fancy for me. I just blow mine off with a leaf blower or the compressor and a wand. I don't actually wash mine very often, the water tends to do more damage then a little dry dust does. At the end of the season I wash mine, let it run for awhile to let everything dry [including under the deck], grease all the zerks and then put mothballs anywhere mice might decide to winter over. [and that includes down into the engine, they vaporize over the winter so not much remains] Sure it smells like an old ladies basement but that sure beats mouse remains and poo when they heat up.
  14. Jun 1, 2021 at 4:11 PM
    #3954
    koditten
    Kirk
    Central Michigan
    Dude!
    Save some pussy for the rest of us!
  15. Jun 1, 2021 at 4:13 PM
    #3955
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Somebody tell him, someone :rofl::rofl::rofl:
  16. Jun 1, 2021 at 5:33 PM
    #3956
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    :muscleflexing:Definitely to many beers going around in dis thread tonight :drunk:
  17. Jun 1, 2021 at 5:36 PM
    #3957
    koditten
    Kirk
    Central Michigan
    It's the only thread drinking and driving (a lawn mower) is not taboo.
  18. Jun 1, 2021 at 5:38 PM
    #3958
    fxntime
    They wouldn't put beer holders on lawn mowers if it wasn't OK to do. My new one has TWO beer holders. :cheers: Now if I can just figure out how to mount one on the ROPS...........
    RustyGreen, T-yoda, Delta09 and 2 others like this.
  19. Jun 1, 2021 at 5:43 PM
    #3959
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    One of the other mods on my tractor forum took one of my XT3 pictures and had a mouse pad made and sent to me.
    Here's my setup. I have the PC hooked to the TV and a wireless keyboard and mouse. Lap Deer-head Chihuahua optional
  20. Jun 1, 2021 at 5:55 PM
    #3960
    fxntime
    I'm down to a hour and 15 minutes with the new ZTR now and that includes a bit of trimming with the push mower. The new one took just about 25-30 minutes off over my old ZTR. Originally it used to take 3.5 hours to mow the lawn on a regular tractor type. [44 inch deck] 11 MPH ain't no joke when you are mowing. I should be able to knock another 10-15 minutes off with a bit more practice with the new one.
