Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you mow in shorts?
  1. Mow, yes, weedeat, no
    43.1%
  2. Mow and weedeat, yes
    35.3%
  3. Pants all the way for me
    21.6%
  1. Aug 15, 2021 at 7:55 AM
    #4901
    SCOTT'S TACO LOCO
    SCOTT'S TACO LOCO Orange It.
    Scott
    San Antonio, Tx
    08 Toy-yo-duh TACO TRD
    Nice, I really need to learn to weld, havnt welded since HS(90's) and that was DC/stick welding. I assume you have a cnc table as well. I have ample garage and shop room, I bought some welding equipment from a friend a couple years ago, haven't mess with it, I'll have take a couple pics of what I got.
    I have been using my neighbors skills for all my welding needs, he welds in the oil field, but he's been laid off and on for past couple years, he is working on getting a CDL, so he might not be around anymore if he gets into the long hual trucking.
  2. Aug 15, 2021 at 8:01 AM
    #4902
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Yes, CNC plasma table. I've been building it for the last 2 years and am just now starting to get some real use out of it. It is an amazing tool to add to my fabrication equipment.
    six5crèéd[OP] and RustyGreen like this.
  3. Aug 15, 2021 at 8:01 AM
    #4903
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Yes I know, I have visited 3 different dealers probably dozen or more times in past couple months, hydraulic fittings are starting to become thin in inventory as well, last 2 months I have gone through 5 hydraulic hoses and 1 oring on a fitting. I now have spare hoses on everything except my lower hoses on the grapple, have yet to replace one, they are behind tubing and more protected than all the others as well.
  4. Aug 15, 2021 at 8:03 AM
    #4904
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Built the table? didn't buy a prefab kit?
  5. Aug 15, 2021 at 8:13 AM
    #4905
    koditten
    Kirk
    Central Michigan
    Yep, I built is from the ground up.
    If you look at the bottom of my post, there is a link to my YT channel. I have some vids of verious progress on the table build. Nothing fancy, just ramblings pretty much.
  6. Aug 15, 2021 at 8:20 AM
    #4906
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Cool.
    Sweet, thanks for noting that, would not have never known about links, cause I'm on my phone, and I don't see them in this current setting.
  7. Aug 15, 2021 at 8:21 AM
    #4907
    koditten
    Kirk
    Central Michigan
    Just have to turn the phone sideways and you will be able to see the links. Don't sweat it. I had be told how to see them as well.
  8. Aug 15, 2021 at 8:26 AM
    #4908
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Me: Tech tard :anonymous:
  9. Aug 15, 2021 at 8:28 AM
    #4909
    koditten
    Kirk
    Central Michigan
    Same, same but I try.
  10. Aug 15, 2021 at 10:10 AM
    #4910
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    More decals.
    20210815_104105_compress97.jpg 20210815_112831_compress73.jpg 20210815_120438_compress3.jpg
  11. Aug 15, 2021 at 11:33 AM
    #4911
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    After 16 years I replaced the old lawn tractor. Money can't buy you happiness, but it can get you a lawn go-cart. The new machine almost makes mowing the lawn fun.
  12. Aug 15, 2021 at 1:04 PM
    #4912
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    :fistbump:
    :thumbsup:Brother joe and I have a couple mow carts :fistbump:
  13. Aug 15, 2021 at 1:39 PM
    #4913
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Seen a zero turn on a trailer this morning with ag tires on the back, I couldn’t help think how much grass that thing would tear up when turning hard.
  14. Aug 15, 2021 at 2:19 PM
    #4914
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Problem with zeroturns are… if soft and wet and ya got nothing to pull you out of the squishy stuff… probably make for a long day…. Ag tires maybe your best bet to run depending on your situation
  15. Aug 15, 2021 at 6:37 PM
    #4915
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    And if used on more slopes, not much traction with the standard tires.
  16. Aug 16, 2021 at 4:13 AM
    #4916
    308savage
    Adam
    East Tennessee
    I hadn't thought about that, makes sense. I think that's the first one I've seen around here with tractor tread tires on it.
  17. Aug 16, 2021 at 4:38 AM
    #4917
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    It is a real concern. I almost didn't buy mine for this reason. My property is on a slope and of course it rains.
    I have not gotten stuck.
    First I don't bother mowing when raining hard or right after. When wet there are some driving and turning techniques that can and do help. No uphill cranks in a bog. No full stop L and juice R in wet (and R/L vv) etc. Just smart driving. My property does drain quickly.
    Have not looked at tractor tires. So far no need.
  18. Aug 16, 2021 at 4:46 AM
    #4918
    koditten
    Kirk
    Central Michigan
    What you guys are seeing is actually ATV tires with a chevron pattern. These are very shallow lugs. Pretty common around here.
  19. Aug 16, 2021 at 5:03 AM
    #4919
    Steve Urquell
    It can be either. Companies make ags in a bunch of mower tire sizes. I like ATV tires over ags because they have softer compound and better grip. I don't like the chevron pattern because they are terrible in reverse. Switched my loader GT to Sun-F non-directional ATV tread and it's much better in reverse uphill.
  20. Aug 16, 2021 at 5:23 AM
    #4920
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    I've noticed seat time can be very deceiving. Doubt your meter is off.
    On a similar note... we found that if you leave the key in any position other than off on the new Redmax zero turn the meter will continue to run. Accidentally left the key in the accessory position after a mow, the meter was still running 3 days later. Went from ~12 to ~80 hours. That's going to jack up the maintenace cycle, might have to put a p-touch next to it; "-70 hrs". Damn meter should only run when the engine is turning :rant:
