Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Mirrors on your tractor?
  1. Yes, have them and love them
    25.0%
  2. No, stop living in the past
    16.7%
  3. Wanted, but not yet acquired
    33.3%
  4. Have mirrors, need tractor
    25.0%
  1. Sep 2, 2021 at 11:25 AM
    #5181
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I need me one of those so I can rent my tractor out
  2. Sep 2, 2021 at 4:05 PM
    #5182
    Anchovy
    TRD Ferguson
    Can anybody throw out any brands I should look at for claw grapples? I like the kubota grapples and the EA wicked grapple. But they both have extreme lead times
    six5crèéd[OP] and RustyGreen like this.
  3. Sep 3, 2021 at 3:16 AM
    #5183
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Loflin manufacturing makes some good ones. They are based here in N.C.
    RustyGreen and Anchovy[QUOTED] like this.
  4. Sep 3, 2021 at 8:05 AM
    #5184
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    I have a tiger attachments extreme duty root grapple for my skid steer and its super well built but have no clue on their lead times
    They are in SC but will ship anywhere in the US
    RustyGreen and six5crèéd[OP] like this.
  5. Sep 3, 2021 at 8:35 AM
    #5185
    Anchovy
    TRD Ferguson
    There’s plenty out there, I’ve already found 5 or 6 companies but most of the grapples are nearly 400lbs. That’s a little too much for my L2501
  6. Sep 3, 2021 at 7:43 PM
    #5186
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    I weld nuts to broke off bolts now. Learned that one recently. Flat washer followed by a nut if flush. The heat helps loosen it. Wish I had known that trick for the 20 years I was a heavy eqpt mechanic.
  7. Sep 4, 2021 at 8:37 AM
    #5187
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    If they stick out enough that’s the best way :thumbsup:
    RustyGreen likes this.
  8. Sep 4, 2021 at 3:04 PM
    #5188
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I fucked up.
    Let the magic smoke out of the engine.
    Got in a hurry and plugged the positive into the kill/ground port.
    Looked at the fan intake and wisps of smoke were waiting up thru the vents.
    It seems this fucking mower just wants to be on some sort of fire!
    New coils on the way.
    I guess I just paid my stupidity tax.
    Pablo8 likes this.
  9. Sep 5, 2021 at 7:57 AM
    #5189
    Anchovy
    TRD Ferguson
    Can anyone help me determine the best grapple type I should look at?
    six5crèéd[OP] likes this.
  10. Sep 5, 2021 at 2:20 PM
    #5190
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Can't like that but can sympathize -- we all have our moments.:annoyed:
  11. Sep 5, 2021 at 2:47 PM
    #5191
    koditten
    Kirk
    Central Michigan
    Yep.
    Last I knew, they still make pencils with erasures for peeps like me.
  12. Sep 5, 2021 at 3:50 PM
    #5192
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    I liked it only because I've done some...........exciting..........stuff :p
  13. Sep 5, 2021 at 5:26 PM
    #5193
    Anchovy
    TRD Ferguson
    Sounds kinky…
  14. Sep 5, 2021 at 6:01 PM
    #5194
    Steve Urquell
    Used my brush hog to finish mow 3 acres today. Mainly to run the Thermocure flush thru the 3205's radiator. It has cleaned the tubes very well in just about 3hrs of run time before today but has a bunch of minerals around the tubes. Hopefully it knocked some more crud loose but it's so murky I can't tell. Smells horrible.
  15. Sep 5, 2021 at 6:13 PM
    #5195
    RustyGreen
    sleeping in a chair
    Pavement Princess
    FIFY ;)
  16. Sep 6, 2021 at 2:47 AM
    #5196
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
  17. Sep 6, 2021 at 5:04 AM
    #5197
    Anchovy
    TRD Ferguson
  18. Sep 6, 2021 at 5:17 AM
    #5198
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    If you’re referring to root grapple or one with a flat bottom, I vote root. The ones with flat bottoms gather too much dirt.
  19. Sep 6, 2021 at 5:17 AM
    #5199
    MAD777
    MAD777 Well-Known Member
    White Mountains, NH
    2021 Tacoma SR5 4x4 Double Cab 6' bed
    I stick with EA and endure the lead times. They simply make good quality, strong attachments that weigh far less than the competition.
    As to type, root vs long tines, it depends on the type of work you do. Long times bottom works best for moving logs and large rocks. Short root grapples work best for clearing brush.
  20. Sep 6, 2021 at 6:59 AM
    #5200
    Anchovy
    TRD Ferguson
    There’s multiple styles, there’s the root rake and a regular root grapple that has the “flat” bottom with 7-10” spacing between the bottom tines. I’m leaning towards a root rake with longer than normal bottom tines but I am slightly concerned about hydraulic pressures when you really get to picking and pulling with a grapple
