Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Sep 19, 2021 at 10:13 AM
    #5381
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    You don’t know you NEED a loader until you have one, as such, you never knew you needed 4wd until you have a machine that has it (don’t get a loader without 4wd)
    My junk is orange, but I’ve had it for over 10 years, it was supposed to be a temporary (2-3years) acquisition but I cannot bring myself to get rid of it. 24hp diesel (basic maintenance and it runs like a top) 60” 3 blade belly mower (one acre with obstacles 1hour mowing) 60” box blade (to large for machine technically, but small bite it’ll eat an elephant) FEL 1/3yd bucket 54” wide, gravel, dirt, logs, general crap, generators, engines, heavy stuff you don’t wanna lift…..or carry….and the option to run PTO powered “things”.
    Neighbor had 4 oaks taken out last week, I scored 2 logs, daughter and I cut them up and hauled them back into the yard yesterday.
    16EEDE4C-57A4-445F-9CDE-89117E83FD25.jpgF48864B4-A44C-4509-ADD4-6AC99B4D6FBF.jpgA68F07DF-54AA-4B41-BD78-5FB8ABA3EB06.jpg
  2. Sep 19, 2021 at 10:22 AM
    #5382
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    I mix them at their recommended rate in the same sprayer. So I'll add a gallon of water to the sprayer and put the dose for 1 gallon mix of Bifen, then the recommended dose for 1 gallon of Permetherin.
  3. Sep 19, 2021 at 10:25 AM
    #5383
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Thanks!
    six5crèéd[OP] and T-yoda like this.
  4. Sep 21, 2021 at 6:09 PM
    #5384
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Why you no post?
    Awfully quiet in here.
    Road trip in the morning for a couple Toro ZMasters. I'm guessing 12 hours behind the wheel.
  5. Sep 21, 2021 at 6:18 PM
    #5385
    Steve Urquell
    I did a little bit over the weekend. Stripped peeling powdercoat off the seatback of my 3205 and repainted it. Refurbed the toolbox/seatbase and all hardware.
    20210919_162440_compress71.jpg 20210919_162750_HDR_compress64.jpg 20210919_162804_HDR_compress90.jpg 20210918_130155_compress40.jpg
  6. Sep 21, 2021 at 6:19 PM
    #5386
    koditten
    Kirk
    Central Michigan
    That is a job I hate, but is always worth it after you are done.
  7. Sep 21, 2021 at 6:21 PM
    #5387
    Steve Urquell
    Yeah if I take parts off I like to refurb them. I have a real pet peeve with rust. Especially rusty hardware. I hate seeing rusty bolts on my machines.
  8. Sep 21, 2021 at 6:38 PM
    #5388
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Been mowing! Mower works great. Pulled the trailer up hill with a load for the burn pile.
    RustyGreen and six5crèéd[OP] like this.
  9. Sep 21, 2021 at 6:40 PM
    #5389
    SCOTT'S TACO LOCO
    SCOTT'S TACO LOCO Orange It.
    Scott
    San Antonio, Tx
    08 Toy-yo-duh TACO TRD
    Cuz we busy.
  10. Sep 21, 2021 at 6:43 PM
    #5390
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Started on the trailer today.
    Cut some additional supports and welded them in.
    six5crèéd[OP] and RustyGreen like this.
  11. Sep 21, 2021 at 6:48 PM
    #5391
    koditten
    Kirk
    Central Michigan
    What's the dementions? Are you adding an axle or moving that one forward?
    Forgive me if I already asked. I suffer from CRAFT.
  12. Sep 21, 2021 at 6:54 PM
    #5392
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    If you don’t need a fel the x758 is a great tractor built to last a lifetime. I have the x758 and a kubota b2650 tlb with a snow plow for winter. Could easily plow with the x758 most of the time, but once in a while we get hit with a 2’ plus storm when I’m on the road and nothing really slows the b2650 down.
  13. Sep 21, 2021 at 7:17 PM
    #5393
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    5 x 12, not moving the axle, it's going to be a mobile chicken coop, if we leave town, drop coop off at family/friends house.
  14. Sep 21, 2021 at 7:19 PM
    #5394
    koditten
    Kirk
    Central Michigan
    Now I remember, thanks.
  15. Sep 21, 2021 at 8:52 PM
    #5395
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    For some reason I never think to grab pictures when I’m working on either the 318 or 9N….might have something to do with seemingly being constantly covered in hydro oil. Getting PM done before snow season gets here
    I had the deck off the 318 to weld up a few cracks and re-engineer the tensioner pulley location since it wasn’t in the factory location when I got it and was throwing belts from time to time. Got everything in alignment and it now takes the correct 48” deck belt. Moved the plow too and the second spool hydro is still happy and functional.
    The gt500’s 3 point was leaking down bad. Less than 5 minutes from turning the tractor off to have it sink from raised to on the ground. So I pulled the top cover off to swap out the metal ringed lift piston to an NAA o-ring piston that’s supposed to be a big improvement over the metal ringed piston that was whooped in mine. Of course I dropped the control valve into the pump so I had to pull the PTO shaft and pump out the bottom to find the valve after 2 hours of unsuccessful hunting with a magnet from the top. It’s a learning curve for me to lean on the service manual for info because it’s from a time before there was a tutorial for everything written up on forums
  16. Sep 22, 2021 at 8:51 PM
    #5396
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    The GT500 is back together with the 3 point holding pressure great now. I appreciate a 70 year old tractor still kicking, but the 1/4” cast iron everything is a bear to handle at times…the top cover with lift arms had to weigh 80 lbs and most recommend an engine hoist to R&R it. 5 fresh gallons of oil and it’s ready to go for snow season now.
    Gave it a bath with the pressure washer afterwards and it rewarded me with a non-start until after it dried out. Fired right up after 15 mins of drying though. The front mount distributors hate water/moisture on them apparently
  17. Sep 22, 2021 at 9:41 PM
    #5397
    koditten
    Kirk
    Central Michigan
    How'd you dry it? The wife's hair dryer and a couple cold ones to keep you occupied?
  18. Sep 23, 2021 at 4:05 AM
    #5398
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Isn't there an O-ring that goes where you have the black circle of gasket maker? I worked on a Ford 601 lift many years ago and think I remember one being there for the fluid that goes through that hole.
    RustyGreen likes this.
  19. Sep 23, 2021 at 11:24 AM
    #5399
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Somehow my wife doesn’t have one and I didn’t want to stand there with a heat gun so it just got a nice air dry from some serious north winds we’ve had lately.
    No provisions for an o-ring there so I just threw some Toyota FIPG around that hydro passage as extra insurance against leaks. Probably some sort of sacrilege but fuck if I was going to take that top cover off again for a leak there
  20. Sep 23, 2021 at 3:43 PM
    #5400
    Steve Urquell
    It was a good day. I'm off today because I work this weekend in the hospital--Covid ICU duty tomorrow. Had 4 bucks in my yard this AM ranging from 6-10pts. Pic is from my phone taking the pic thru my binoculars. Got my seatback and seat base/toolbox back together and on the Cub 3205. Also made a pin out of a roll up door spread rivet to fix the retention problems that plague Cub XT3's battery boxes--the clowns used 2 plastic clips that snap over a rod and don't hold.
    Kayaked with the wife after 11AM then stopped at the best burger place in NW AR--CJ's Butcher Boy. You order at the cold case. They are grinding meat when you order and you order like this : What cheese? What condiments? What toppings? Mine was pepper jack, mayo, lettuce, tomato, jalapeno.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
