Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    45.7%
  2. After
    57.1%
  3. Neither
    11.4%
  4. I weed whack while someone else mows
    5.7%
Multiple votes are allowed.
  1. Sep 26, 2021 at 7:14 PM
    #5421
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    They will weld very nice if you practice. Here are some of the first welds I made with mine after not welding stick for 13 years. 7018AC rod. It also makes some nice welds with 6013.
  2. Sep 26, 2021 at 7:18 PM
    #5422
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    About the only good thing I can think of for those TS welders is once I MIG welded, I was never stick welding again.
    Seriously, think about MIG welders. The difference is unmeasurable.
    six5crèéd[OP] and RustyGreen like this.
  3. Sep 26, 2021 at 7:34 PM
    #5423
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I used an ESAB Migmaster 250 at my work.
    At home I have a MillerMatic 135 (?) that I bought at least 20 years ago, fixed a lot of mower decks and rust holes in car bodies. I would like to become proficient with the stick "just because".
  4. Sep 26, 2021 at 7:41 PM
    #5424
    RustyGreen
    sleeping in a chair
    Pavement Princess
    He also gave me about 50 pounds of 6011 rod so that is what I work with.
    After using a MIG for years the 6011 is pretty handy for rusty, crappy things that come along like the oil tank chicken cooker the neighbor brought over that was pretty much built of rust holding hands. :laugh:
  5. Sep 26, 2021 at 7:52 PM
    #5425
    Steve Urquell
    I ran MIG, spool gun MIG on aluminum, SS, and steel and stick in the shops I worked in for 20 years. We still ran stick ~30% of the time, even with a pile of MIG welders.
    For me it isn't worth it to have a bottle when I can weld just as good with flux core or stick.
  6. Sep 27, 2021 at 2:48 PM
    #5426
    koditten
    Kirk
    Central Michigan
    Well, shit! Block gasket took a shit! Was hoping it was the oil cooler o-ring. No such luck.
    I guess this motor gets to come out.
    Pablo8 and Zeke588 like this.
  7. Sep 27, 2021 at 4:03 PM
    #5427
    Steve Urquell
    Sorry duder. What is that in?
    RustyGreen likes this.
  8. Sep 27, 2021 at 5:53 PM
    #5428
    koditten
    Kirk
    Central Michigan
  9. Sep 27, 2021 at 6:10 PM
    #5429
    doityerself
    doityerself Well-Known Member
    The Deep South
    2006 SR5 DCLB 4x4
    Not Enough and it continues...
    Ok educate me. Lol. What's CRAFT?:anonymous:
    RustyGreen and koditten[QUOTED] like this.
  10. Sep 27, 2021 at 6:18 PM
    #5430
    koditten
    Kirk
    Central Michigan
    C can't.
    R remember.
    A a
    F fucking.
    T thing
  11. Sep 27, 2021 at 6:28 PM
    #5431
    koditten
    Kirk
    Central Michigan
    It's not entirely bad. I did discover a crack in the frame under all the grime. With motor out it'll be cake to weld it up on both sides.
    A have found some sketchy wiring that I'll be able to clean up proper.
    I still need to figure out the radar fuel gauge...I think. Not sure how that works. I found the sending unit in 2 pieces. I don't know if there is supposed to be a float in the tube.
    Before I messed with it the digital fuel gauge read full all the time. Since I put it back together it now reads empty and the tank is full.PXL_20210927_162154897.jpg PXL_20210927_162224184.jpg
  12. Sep 27, 2021 at 6:44 PM
    #5432
    doityerself
    The Deep South
    2006 SR5 DCLB 4x4
    Oh yeah, I think I knew that. Guess i forgot.:rofl::rofl:
    koditten[QUOTED] and RustyGreen like this.
  13. Sep 28, 2021 at 4:23 PM
    #5433
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I’ve got a Hobart 140 running flux and a Lincoln 180 set up for MIG. I use them both about 50/50 just depending on the wind and whichever one happens to be closer. I like flux for blasting through rusty metal on little jobs like the mower deck and such
  14. Sep 29, 2021 at 6:09 AM
    #5434
    SCOTT'S TACO LOCO
    SCOTT'S TACO LOCO Orange It.
    Scott
    San Antonio, Tx
    08 Toy-yo-duh TACO TRD
    Finished burning the diamond grate yesterday, put trailer up on lift, to help with not bending/hunching over to finish grinding welds down.
  15. Sep 29, 2021 at 6:20 AM
    #5435
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    Replaced outer axle seals and 1 outer bearing on our NH TC40D.
    Fun little project. I was thinking that the gears on these would need shims and backlash and all of that like a vehicle's differential gears but these are pretty low tolerance and very beefy.
  16. Oct 1, 2021 at 8:55 PM
    #5436
    Steve Urquell
    I did a little tedious project that saved me $70 or so. Cub taillights are $80-100 each. The left one is always messed up due to being below the gas fill neck, getting gas on it and having the gas can leaned on it.
    I had 2 decent right lights and made a right one into a left. They have back up lights so I had to paint the existing one with clear red paint and cut a spot to put another back up lens in it since it shifted left. They won't just flip upside down--top and bottom are different
    DIssassembled the lens from base
    Cut a new back up lens hole and countersink cut the back to let the lens sit flush with the face.
    Glued a crack all the way across the lens with DAP brand ethyl cyanoacrylate with a primer then glued the lenses in with e6000 glue
    Painted the extra lens with clear red paint
    Glued the lens back in the base.
  17. Oct 2, 2021 at 5:24 AM
    #5437
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :101010: Nice job!
    I really admire folks who can do tedious projects like this -- I don't have the fine hand skills -- or the patience. :smash:
  18. Oct 2, 2021 at 8:12 AM
    #5438
    Steve Urquell
    Thanks man. It was done for 2 reasons
    1. I'm a cheap bastid
    2. Just to see if I could
  19. Oct 2, 2021 at 1:56 PM
    #5439
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Before the summer, you couldn't even walk into this corral, it had 9 years of overgrowth on it, different story today, disc and seeding in some winter rye.
  20. Oct 2, 2021 at 2:33 PM
    #5440
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :thumbsup:
    I am most definitely #1, as far as #2 -- those days are behind me... I just don't have the energy to challenge myself anymore.
