Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    45.7%
  2. After
    57.1%
  3. Neither
    11.4%
  4. I weed whack while someone else mows
    5.7%
Multiple votes are allowed.
  1. Dec 26, 2021 at 3:15 PM
    #5941
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
  2. Dec 26, 2021 at 5:27 PM
    #5942
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You need to source some Rat Fink decals.
  3. Dec 26, 2021 at 5:40 PM
    #5943
    Steve Urquell
  4. Dec 28, 2021 at 3:43 PM
    #5944
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Leaves are done for the year.
    Bushed, RustyGreen, jester156 and 2 others like this.
  5. Dec 28, 2021 at 4:54 PM
    #5945
    koditten
    Kirk
    Central Michigan
    Mine, too!
    The bagger on the ZT is a must have!
    I don't want to sell my latest project Z Master.
  6. Dec 29, 2021 at 3:22 AM
    #5946
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    The bagger is nice, I had a trac-vac and spent more time unclogging the hose than getting leaves up. Found this mower from a friend of mine, it’s been a good one. It started starving for fuel again yesterday, time to rebuild the carb I guess.
    RustyGreen likes this.
  7. Dec 30, 2021 at 5:56 AM
    #5947
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I talked to a friend yesterday who works on welders and was telling him about my mower starving for fuel. He said take the carb off and run a wire through the jets, he sees it all the time on welders. Now to find time to do it.
  8. Dec 30, 2021 at 6:03 AM
    #5948
    koditten
    Kirk
    Central Michigan
    I would hope he starts simple with a fuel filter change 1st?
    RustyGreen and six5crèéd[OP] like this.
  9. Dec 30, 2021 at 6:58 AM
    #5949
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I’m gonna change the filter as well :thumbsup:
    I pulled the line at the carb a few weeks ago and it was flowing fine but that doesn’t mean it don’t need changing.
    RustyGreen and koditten[QUOTED] like this.
  10. Dec 30, 2021 at 12:14 PM
    #5950
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Remembered the man gave me a spare engine he had when I bought the mower. I’m gonna clean the carb off it and use it for a while :D
    Delta09 and RustyGreen like this.
  11. Dec 30, 2021 at 4:25 PM
    #5951
    Steve Urquell
    3225 is earning its keep today with more driveway maintenance. Loving the 3pt hitch.
  12. Dec 30, 2021 at 4:38 PM
    #5952
    koditten
    Kirk
    Central Michigan
    That should save some time.
  13. Dec 31, 2021 at 7:26 AM
    #5953
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    AD4C6318-2D26-4330-90BF-CD06BE1DD8A5.jpg I made something
  14. Dec 31, 2021 at 4:31 PM
    #5954
    Steve Urquell
    I mounted some 16x7.5-8 tires on wheels for my 3225. Clamping the tire down solved the nightmare of keeping the bead down while nipping them over the rim. If you've ever struggled with these it made it a breeze for me.
    My 2.5" 3240 lift cylinder has been leaking. I bought a 2" cylinder from Surpluscenter knowing my power would be decreased but speed is almost double. The 2.5" had more power than I needed. It lifted the rear of the tractor lifting a tree with the loader the other day and the rear has 500lbs of ballast. Below is before and after on speed.
    https://youtu.be/_ykjRmCg9oc
    https://youtu.be/P3SnAZs7cBw
  15. Dec 31, 2021 at 6:26 PM
    #5955
    koditten
    Kirk
    Central Michigan
    Awesome! Sometimes we need to read the stats with a bit of skepticism. It worked for you.
  16. Dec 31, 2021 at 6:36 PM
    #5956
    Steve Urquell
    When I built the loader I racked my brain with the hydraulic calculators before choosing the 2.5" cylinder knowing it was more than I really needed. I figured I'd rather be a little slower but still have plenty of power.
    I hope the 2" doesn't disappoint me.
  17. Jan 1, 2022 at 12:16 PM
    #5957
    Bushed
    Bushed Well-Known Member
    Kenora, ON
    08 DCSB TRD OR - Sold
    Cambridge Metals and Plastics Bed Bar
    I love clearing snow!!!
  18. Jan 1, 2022 at 1:44 PM
    #5958
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Mechanically produced snow wave.:burnrubber:
  19. Jan 1, 2022 at 1:50 PM
    #5959
    Bushed
    Kenora, ON
    Use to piss off everyone in the house when I was young, running from window to window at 4 in the morning to watch the grader clear the street and the lane. Had a 3 sided view of the action. Barely slept after a fresh snowfall waiting for the big yellow Champion to come around. More exciting than Santa Claus.
    TacoLarn, Delta09, RustyGreen and 2 others like this.
  20. Jan 1, 2022 at 1:52 PM
    #5960
    FastEddy59
    Eddie
    Likely before they had the back up beep too. :)
