Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Feb 15, 2022 at 8:48 PM
    #6221
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Getting ready to close on a new house. It’s about 3/4 of an acre with a lot behind I plan to buy later on to make it close to 1.5 acres. It’s got quite a bit of grass and never had grass besides as a kid and it was a small amount.
    I wanted an old school riding lawn mower but being close to Vegas there isn’t much “old school” of anything or much anything to do with lawn care.
    so any recommendations for a riding lawn mower? Can’t afford a zero turn and property has a little bit of a grade to it. We will get a little snow so being able to put a small blade on the front will be a plus. Budgets around 2k but less is better
    also going to need a weed whacker and blower and probably looking at a gas one since there’s a lot to do and I’ll burn up the cordless batteries doing something this big.
    Following this thread as well as ultimate goal is to get a decent sized tractor with a front bucket and rear back hoe like the kubota or John deer but wouldn’t mind a skid steer either.
    picture of property from the ad
    bigmw, six5crèéd[OP] and RustyGreen like this.
  2. Feb 16, 2022 at 4:07 AM
    #6222
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    If you're looking for a used one you may have to expand your search area and do a little traveling. It would be nice if you could find an older John Deere or Cub Cadet with a blade attachment already with it. When you start buying attachments the price adds up quick. Good look in your search and congrats on your new property purchase!
  3. Feb 16, 2022 at 2:36 PM
    #6223
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Very strange.
    No project in the shop at this moment. The place has a strange echo.PXL_20220216_211537804.jpg
    Well that didn't last long.
    Just got contracted to build another utility trailer. So much for wide, open, spaces.
    I kind of expected it. Peeps with tax returns always reach out this time of year.
  4. Feb 16, 2022 at 3:36 PM
    #6224
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Nice looking place -- amazing view out the back door. :101010:
  5. Feb 16, 2022 at 4:03 PM
    #6225
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The last time I had that much space I got three Wisconsin 2 cylinders in 3 weeks.:laugh:
    Every time I make that much clear space something "appears" in it... :annoyed:
    The magic shrinking garage syndrome, maybe it was built over a plutonium deposit or something. :notsure:
  6. Feb 16, 2022 at 5:27 PM
    #6226
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I know what you mean, I clean mine out and 2 weeks later you can barely walk :anonymous:
    RustyGreen[QUOTED] likes this.
  7. Feb 18, 2022 at 5:41 AM
    #6227
    ralfnjan
    ralfnjan Well-Known Member
    I can make any good saw cut like that Poulan!
    six5crèéd[OP] likes this.
  8. Feb 18, 2022 at 12:59 PM
    #6228
    koditten
    Kirk
    Central Michigan
  9. Feb 19, 2022 at 4:35 AM
    #6229
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    What you making?
    RustyGreen likes this.
  10. Feb 19, 2022 at 4:53 AM
    #6230
    koditten
    Kirk
    Central Michigan
  11. Feb 19, 2022 at 5:16 AM
    #6231
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  12. Feb 19, 2022 at 5:18 AM
    #6232
    koditten
    Kirk
    Central Michigan
    Yep, I'll have 300 in wood as well. Sucks!
    RustyGreen and six5crèéd[OP] like this.
  13. Feb 19, 2022 at 5:19 AM
    #6233
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I need to refloor this one, it’s 6’ x 12’ I paid $400 for the trailer many years ago.
  14. Feb 19, 2022 at 7:09 AM
    #6234
    RustyGreen
    sleeping in a chair
    Pavement Princess
    There are no more $100 fix up trailers anymore, junk on wheels with a title is at least $500 here.
  15. Feb 20, 2022 at 12:28 PM
    #6235
    ralfnjan
    Got a question. The picture is of the leaky part pissing diesel fuel all over the valve cover of my JD1830. There was a tiny hole in the bottom (where the JB weld is covering). The part was at the far end of the injector rail. One of the holes (top) was the return to the fuel tank, the botom was the line from the rail. The lowest one went to the air intake. I think that was for a start assist that has never worked for me. There's a spade terminal on the end of the line...gets heated then fuel is pumped across it so your first cranks have hot fuel in the air being compressed?
    I finally figured it was a regulator of some sort. The return to fuel tank pees in the filler neck like an old guy pissing, not a lot of force. Pressure in the fuel rail to injectors must be high, so it drops the pressure down I'm guessing.
    The JBweld seems to be holding. The hole was about 1/16inch diam. Maybe from a bad casting (it's aluminum), or a spot where erosion occured due to high pressure fuel impinging on it? Any thoughts?
  16. Feb 20, 2022 at 4:29 PM
    #6236
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Don't know on that reg.
    I took down a dead cherry tree that I mow under. It had huge limbs going both ways and leaned away from the biggest as well as being on a slope. I was worried a limb would fall off on me so I cut it and then pulled it down. Those huge limbs shattered when it fell so my extra work was justified to me.
    Limbed it with the Poulan 2150 and did the thick stuff with my new/used Stihl MS291. That dude rocks. That trunk was bouncing the 500lbs of ballasted rear off the ground on my 3240.
    20220220_111830_HDR_compress44.jpg 20220220_113454_HDR_compress9.jpg 20220220_113646_HDR_compress75.jpg 20220220_133637_HDR_compress45.jpg 20220220_142245_HDR_compress23.jpg 20220220_160915_HDR_compress90.jpg
  17. Feb 20, 2022 at 4:43 PM
    #6237
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    What happens when you bring a blower to a backhoe/loader fight.
    :smack:
  18. Feb 20, 2022 at 5:01 PM
    #6238
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Are you and wife feeling back to normal yet? :fingerscrossed:
  19. Feb 20, 2022 at 5:12 PM
    #6239
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    My little 24" Troybuilt would just shutter and the Tecumseh Sno-King would throw a rod even attempting that :rofl:
  20. Feb 20, 2022 at 5:35 PM
    #6240
    Steve Urquell
    Wife is having some weirdness going on. In the ER Friday. Cardiac stress test this coming week. I'm OK but fatigue easily. Took several breaks today while cutting that tree.
    six5crèéd[OP], bigmw and koditten like this.
