Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Mar 16, 2022 at 3:19 AM
    #6421
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Post whatever you want, I don’t care :cheers:
  2. Mar 16, 2022 at 3:19 AM
    #6422
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :anonymous:
  3. Mar 16, 2022 at 4:46 AM
    #6423
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    ALLLrighty then...
    So my wife has an easy fall back when it comes to Christmas presents. She can always buy Ryobi stuff for me. She got me one of their little electric pressure washers and has been after me to use it ever since. Hey...ahhh...it's kinda been freezing ya know honey.
    Finally got a nice day and busted it out. I must say I'm pretty impressed considering I'm using cold water. It feels very similar in pressure to a carwash nozzle. Has different nozzles(I'm using a 15deg flat here) as well as a detergent pick up tube but I'm using straight water here.
    One thing I really like about it is the pump only runs when you pull the trigger. As soon as you let off everything is completely silent.
    Ahh, love the smell of Arkansas sulfur water in the evening.
    https://youtu.be/y6eCutAwIDc
    Also bought a high limb saw kit from Amazon. The kit has a saw chain which cuts both ways and has teeth on both sides.
    You throw a rope hooked to the throw bag over a limb, drag it over, and saw it from a safe distance. Been researching these for awhile. I have 2 huge limbs high up that have been preventing me from cutting trees down.
    I tried it on a 5" oak limb that I knew I could get to with my pole saw if I got the chain stuck. I knew going in that these are not great for one person use since the radius gets small as you cut thru and they bind up. This limb was very hard and very dry as well making it probably the worst learning curve limb I could have chosen.
    I went side to side to undercut the branch to limit this but it still stuck a lot and generated some fine words taught to me by 20yrs of dealing with OTR truck drivers. Finally got it down.
    It cuts great but really needs 2 people to keep the radius of the cut bigger and prevent binding. Even spreading my arms wide when it stuck was enough to get it unstuck sometimes.
    [​IMG] [​IMG] [​IMG]
    308savage, koditten, Delta09 and 2 others like this.
  4. Mar 16, 2022 at 5:35 AM
    #6424
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
  5. Mar 16, 2022 at 5:41 AM
    #6425
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Could you please post the link for the saw kit you bought?
    I have been pondering one of these as I can't do ladders any more.
    six5crèéd[OP] likes this.
  6. Mar 16, 2022 at 6:53 AM
    #6426
    Steve Urquell
    I posted mine on the tractor forum and someone else posted this one which is cheaper. Looks just like mine. https://www.amazon.com/Chainsaw-Handles-Webbing-Carabiner-Sharpener/dp/B099281T6W
  7. Mar 16, 2022 at 6:54 AM
    #6427
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Reminds me I need to replace my electric pressure washer that I got at Lowe's several years back. I've worn it slap out and the pump will no longer keep prime. Used it yesterday and it almost didn't turn on. Luckily I don't have to deal with that nasty smelling sulfur. My outside spigots are fed by the cistern so it's eco-friendly rain water :D
    Also, skip the detergent thing and go with a foam cannon!
  8. Mar 16, 2022 at 8:53 AM
    #6428
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    I picked up my new XT1 GT54 last night. So far I am very excited about it. It is a big unit. Much larger than the old Scotts. Some compromises like poly bushings instead of bearings, but overall I think it should be a solid unit.
    Just waiting for this rain to go away so I can get out and use it.
    Looking for attachments now. Primarily a dethatcher for sticks and dethatching work.
    I am so tempted to get a sleeve hitch for it for a landscape rake or one of those little agri-fab 42" box blades.
    I don't want to be overconfident in it's capabilities, so maybe just a gravel drag harrow like Yard Tuff 78 in. Driveway Draggin' Drag Harrow, ATV-78LDT at Tractor Supply Co. or something.
    I did find on Tuff Torq's specs for the K58 that they use heat treated steel gears as opposed to powdered metal. So that is a bonus. K58 - Tuff Torq Corporation
    "These units are engineered for the higher demands of estate tractors and small garden tractors, including; heavier weight tractors, better speed and response, auxiliary hydraulics support, ground-engaging equipment support and much more."
    This is conflicting, because most people will say the K58 is definitely not meant for GT activities.
    Also conflicting, compatible accessories for the XT1 GT54 lists cub's sleeve hitch, but the sleeve hitch itself says XT2 Garden Tractors only.
    If the XT1 and XT2 are on the same chassis, and the XT2 GX50 also runs the K58 transaxle, then what is the difference between the XT1 GT54 and XT2 GX50 in terms of capabilities? What makes the GX50 more capable?
    RustyGreen and six5crèéd[OP] like this.
  9. Mar 16, 2022 at 10:31 AM
    #6429
    Steve Urquell
    The transaxle is the same and it shouldn't matter too much. I'd sleeve hitch it if I wanted to. Don't buy the AF box blade, buy the Brinly. It's built better. I welded 50lbs of iron to my AF to make it usable.
  10. Mar 16, 2022 at 11:00 AM
    #6430
    toysrgood
    SC
    2011 4x4 Reg Cab
    Good to know. Brinly makes a smaller one too and should pull easier for peace of mind.
    Let er rip
    Aside from the GT designation, prior years specifically state the GT54 is a Garden Tractor, such as the 2020 model listed here. Cub Cadet XT1 GT54" Garden Tractor | Cub Cadet US
  11. Mar 16, 2022 at 11:36 AM
    #6431
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Remember the deck belt I got on clearance yesterday?
    I just put it on the shelf in the garage -- next to two just like it... :rofl:
    There are advantages to being disorganized -- mostly for people selling things it would seem.
    six5crèéd[OP] and w.adventures like this.
  12. Mar 16, 2022 at 11:50 AM
    #6432
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Speaking of pressure washers. I bought this one at Sams back in October on clearance for $199, I didn't need it, I put it in the building and haven't even opened the box. My other one works fine :anonymous:
  13. Mar 16, 2022 at 4:10 PM
    #6433
    Steve Urquell
    Do all of these pressure washers use a universal QD? I don't want to buy one that won't connect to my wand.
  14. Mar 16, 2022 at 5:22 PM
    #6434
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The lower end units use a smaller type of quick detach fitting.
    The conventional pressure washers use a 3/8" fitting. They are pretty common at decent hardware stores .
  15. Mar 16, 2022 at 5:28 PM
    #6435
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I believe they do, I bought one on Amazon for about $18 and it clicked right on.
    I won't be going back to the bucket wash method after having the foam cannon.
    My car washing PW is a really small electric Sun Joe.
  16. Mar 16, 2022 at 5:32 PM
    #6436
    Steve Urquell
  17. Mar 16, 2022 at 5:33 PM
    #6437
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The well water at the garage isn't the best so I filter it a bit first...
  18. Mar 16, 2022 at 6:06 PM
    #6438
    koditten
    Kirk
    Central Michigan
  19. Mar 17, 2022 at 7:35 PM
    #6439
    itsdug
    itsdug Well-Known Member
    Doug
    Fentress County
    2018 DCSB 4x4
    Bought my first tractor this week. Grapple should be here tomorrow. Any other TYM other owners on here?
    shaeff, Rick323, bigmw and 9 others like this.
  20. Mar 17, 2022 at 8:27 PM
    #6440
    Steve Urquell
    Congrats! Great looking machine.
