Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    46.2%
  2. After
    57.7%
  3. Neither
    15.4%
  4. I weed whack while someone else mows
    7.7%
Multiple votes are allowed.
  1. Mar 20, 2022 at 3:36 PM
    #6461
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Definitely not an emoticon I'd ever expect to come out of you :rofl:
  2. Mar 20, 2022 at 3:38 PM
    #6462
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    You are always a special exception my friend. :fistbump:
  3. Mar 20, 2022 at 4:24 PM
    #6463
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Thanks. Yep, I love this tractor. So easy to use, get on/off of, runs great and that loader has saved my back soooo many times.
    Wow on those hours. Testament to the Kohler Command's durability. It looks like it's built like a tank. Hope you get it going your way.
    Yes, I should have set that limb up before i ever went to get her for help. Got distracted--DUH!:facepalm:
    Thanks on the gear. I try to tackle it a little at a time. I've touch up painted several spots and I wipe it down or wash it if it gets muddy but none of my stuff is a garage queen. I use it hard and fix it if I mess it up. I just take it a little piece at a time and don't let things go too long and when I fix it, I fix it to go a million miles. The old truck fleet mechanic in me.
  4. Mar 20, 2022 at 4:31 PM
    #6464
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    If my "little" Kohler KT725 even gets 1/10th that I'd be happy!
    Maybe I will now that I ordered some Valvoline VR1 Syn 10w30 and Baldwin filters, no Fram's :spy:
  5. Mar 20, 2022 at 4:41 PM
    #6465
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I take care of the important things: oil/filters/grease but have never really found the time/energy/motivation to go beyond that.
    Almost all my gear came to me very used and very cheap, I buy good parts and fix things to last but don't restore things.
    Looking back at the last few of decades I realize now that I have always had way more to do than I ever had time (and later energy) to achieve. Getting it working was always all I had time for.
    Moving forward I'm trying to devote my time to jettisoning off some of those responsibilities so maybe for once I can post a picture of something shiny. :laugh:
  6. Mar 20, 2022 at 4:43 PM
    #6466
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :thumbsup: I knew you were a smart guy!
  7. Mar 20, 2022 at 4:52 PM
    #6467
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Heh, I've been ordering Hastings filters a couple years now, which are the same as Baldwin (Clarcor Corp). They're the perfect balance of cost and durability. I order a load of them for all the vehicles every so often to offset cost and with the current situation they've been sending me the the nice red Baldwin's.
    The VR1 was a spur of the moment thing. It was $50 shipped to my door from Amazon for a 6qt case. Should last me 2 years, so $25 a year for oil is not bad... I can't get my Rotella, or Delvac and my favorite passenger vehicle oil is Valvoline, so it was a no brainer :D
  8. Mar 20, 2022 at 5:20 PM
    #6468
    Steve Urquell
    Just gotta do a little project at a time on the cosmetics. I was tired today and wanted to go sit but had enough energy to tackle a little project that's been bugging me. Cub decal on my FD620D engine all curled up on the edges. I took it off, cut the edges off, cleaned the adhesive off the back of it, and rubber cemented it back on. Lil 15min project and it makes me happy to look at it now.
    Also, Orange Can!!! :crapstorm:
    20220320_184718_HDR_compress58.jpg 20220320_184718_HDR_compress58.jpg 20220320_184718_HDR_compress58.jpg
  9. Mar 20, 2022 at 5:28 PM
    #6469
    RustyGreen
    sleeping in a chair
    Pavement Princess
    On my ZT the oil filter is difficult to get at much less write the date/hours on -- and the WIX filters I use are black as well.
    I put blue painters tape under the seat and write the date/hours on that. I do the same on the vehicles, put the blue tape on the upper rear of the drivers door frame. It doesn't fade a bit even in the winter.
    six5crèéd[OP] likes this.
  10. Mar 20, 2022 at 5:33 PM
    #6470
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    The orange can catches a lot of grief, it’s not a favorite, that fact that the machine actually saw service is MUCH more important, at least the filter isn’t layered in years of oily debris, it could be worse
    six5crèéd[OP] and RustyGreen like this.
  11. Mar 20, 2022 at 5:49 PM
    #6471
    Steve Urquell
    I put the orange can on it. I know what they are and am not afraid of them nor do I follow the trend of bashing them. That engine was absolutely filthy when I got it. All leaking seals were replaced after a thorough douching.
  12. Mar 20, 2022 at 6:12 PM
    #6472
    Blkvoodoo
    Kevin
    Near Clayton NC
    I’ve used em, and it beats not having anything, there may have been a time when there was actually an issue, I’ve seen failures from a few brands, literal failures, the can blows out the crimp seam, or the base fractures. Not same brand as discussed.
    I’m fortunate in that I can source some of my filters thru work, so I take the cost reduction when I can. ($40 air filter is still $40) I do pay attention to air filters and the media used, those I have seen performance reduction and even engine damage because of the media used. (K&N will not be used on anything I don’t reasonably expect to rebuild in short term).
  13. Mar 20, 2022 at 6:33 PM
    #6473
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I love the orange filter. It has that hi grip texture paint.
  14. Mar 20, 2022 at 6:38 PM
    #6474
    RustyGreen
    sleeping in a chair
    Pavement Princess
    56415700_2225877780767686_47074010611308_2cf622853c81494cc79fbd9062af8aff781f3059.jpg
  15. Mar 20, 2022 at 7:07 PM
    #6475
    Steve Urquell
    I do too. In fact, I just installed some new track lighting in the house. How's it look?
  16. Mar 20, 2022 at 7:14 PM
    #6476
    koditten
    Kirk
    Central Michigan
    :rofl::rofl::rofl::rofl:
  17. Mar 20, 2022 at 9:51 PM
    #6477
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Bad@$$!
    With the current "man cave" thing going on they would probably sell by the thousands! :thumbsup:
    (Mostly to Dodge truck drivers probably but hey, their money could fill your billfold just fine.)
  18. Mar 21, 2022 at 4:27 AM
    #6478
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    People use them as silencers also :rolleyes:
  19. Mar 21, 2022 at 5:02 AM
    #6479
    RustyGreen
    sleeping in a chair
    Pavement Princess
    From my extensive knowledge of firearms (gleaned entirely from 1970's TV detective shows) I believe silencers are supposed to be stealthy and discrete. A radioactive orange can doesn't really go hand in hand with discrete. :laugh:
  20. Mar 21, 2022 at 5:04 AM
    #6480
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    The orange can may scare people more than the gun :rofl:
    Delta09 and RustyGreen[QUOTED] like this.
