Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Apr 29, 2022 at 5:57 AM
    #6901
    Toyko Joe
    Toyko Joe Here for the pictures
    Instead of buying a $400 lawnmower and having to put a couple hundred into bringing it back to life. I’ve decided to buy a $400 4x6 trailer and move around the mower I already have. Going to check it out this afternoon. Looks like a Lowes job but should check a lot of boxes.
  2. Apr 29, 2022 at 6:57 AM
    #6902
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Around here there are no $400 trailers with a title. Double that might get you junk on wheels and a title -- and people say Tacomas hold their value... :laugh:
  3. Apr 29, 2022 at 7:13 AM
    #6903
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    I’ve seen a lot of comments about “putting hours on the machine, it’ll drop its resale value…”.
    WTF would you buy it if not to actually use it ? Never understood that phrase. much like buying a car, if you can’t drive it why buy it ?
  4. Apr 29, 2022 at 7:24 AM
    #6904
    Toyko Joe
    Exactly. This is half the price of new and looks to be only 1-2 years old from the pictures. Person says title in hand. If not bill of sale and previous registration is all I need. :fingerscrossed:
  5. Apr 29, 2022 at 7:26 AM
    #6905
    RustyGreen
    sleeping in a chair
    Pavement Princess
    My state is a total P-I-A about titles and forget about titling a home built trailer - just isn't worth the hassle.
    six5crèéd[OP] likes this.
  6. Apr 29, 2022 at 8:20 AM
    #6906
    Bushed
    Bushed Well-Known Member
    Kenora, ON
    08 DCSB TRD OR - Sold
    Cambridge Metals and Plastics Bed Bar
    This is an extreme over zoom, but best pic I have of my just 'broken in' backhoe. Picking and moving large boulders. Installing a thumb would probably have saved me from this damage, but ya work with what ya got. I don't feel the least bit bad about it, just adds character. Check out the waffled steel just above the bucket pin.
    Sub 100 hours. Bought a tractor to do tractor jobs.
  7. Apr 29, 2022 at 10:12 AM
    #6907
    Blkvoodoo
    Kevin
    Near Clayton NC
    Every operation is a calculated risk of some sort, most are within design parameters, others….weellllll.
    Several years ago I put my B2400 up for sale to offset the purchase of HVAC for the house. ( tractor something I don’t need, but like having around)
    One guy came to look, his first question was “will it dig ?”
    That’s up to you, it’s called a loader, not a digger. If you can operate it the right way, it may well dig.
    He didn’t like that answer
    When he showed up I was in the middle of the biweekly blowing out and greasing, he asked if that was really nessesary “only if you want it to live more than a year or 2”
    I blow out the radiator, engine, trans and mower deck every other mowing and grease all the spindles and pulleys. Grease is cheap, those parts are not.
  8. Apr 29, 2022 at 10:39 AM
    #6908
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    That guy isn't worthy of your Kubota anyways.
  9. Apr 29, 2022 at 10:42 AM
    #6909
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Agree!
    I know they are only machines and money is green even if it comes from a dumb@$$, that said I hate to sell a nice machine to a dumb@$$.
  10. Apr 29, 2022 at 10:49 AM
    #6910
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    You also have the "He sold me a piece of junk! It broke down 6mths after I bought it!" In that six months it was run hard with zero maintenance or oil level checks.
  11. Apr 29, 2022 at 11:01 AM
    #6911
    Lt. Dangle
    Ohio
    Speaking of Maintenance, I could look in the Service Manual I have, but I'm sure my tractor is due to have the coolant flushed. Is there a special Kubota Coolant I should be using? Or would any generally do?
    Reason I ask before consulting the manual is the book is like 30 years old and I am wondering if any advancements in the world of coolant might be different now.
    For a B4200.
    MY50cal, RustyGreen, wilcam47 and 2 others like this.
  12. Apr 29, 2022 at 11:09 AM
    #6912
    Blkvoodoo
    Kevin
    Near Clayton NC
    I just use basic green 50/50 as it is usually all the jug for a drain and full
    I’ve got a core plug with some corrosion on it but it’s from the outside I think
    Your old tank will probably have a brass radiator on n it so green is probably best
  13. Apr 29, 2022 at 1:00 PM
    #6913
    Blkvoodoo
    Kevin
    Near Clayton NC
    Buddy of mine recently bought a Kioti tractor, teaching him the finer points, his box blade showed up today so he’s all excited to dig up the yard. 9EAFC07F-5809-4365-966E-F42CEBAE3B50.jpg
  14. Apr 29, 2022 at 4:20 PM
    #6914
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I forgot I had this one for sale. Moved it behind the shed last fall.
    Got hit up for it today. Delivering it in the morning.PXL_20220429_231613099.jpg
  15. Apr 29, 2022 at 4:26 PM
    #6915
    Steve Urquell
    If you have scale buildup in the radiator I highly recommend Thermo-Cure flush. It has knocked a crapton of scale out of my 3205's radiator in a short time. Make sure to refill with distilled water if mixing your own antifreeze/water. The minerals in tap water accumulate in the radiator to build scale. Distilled has no minerals=no scale
  16. Apr 29, 2022 at 4:38 PM
    #6916
    Lt. Dangle
    Ohio
    I'll have to pop the cap and check it out, but it has to be scaled I would imagine.
  17. Apr 29, 2022 at 4:46 PM
    #6917
    Steve Urquell
    Here's a before and 20hrs of operation time after pic of mine.
    [​IMG][​IMG]
  18. Apr 29, 2022 at 4:50 PM
    #6918
    Blkvoodoo
    Kevin
    Near Clayton NC
    One of the reasons I use 50/50 its already mixed with demineralized water and I don’t have to go messing with it.
    When I fill a larger system I usually dump a gal of each then mix. Besides I usually have 50/50 on hand in my service van
  19. Apr 29, 2022 at 4:55 PM
    #6919
    Steve Urquell
    Yep, for small capacities the 50/50 is a great choice. I cringe at all the radiators I topped off from the garden hose in the past. I just didn't know any better.
    RustyGreen and Blkvoodoo[QUOTED] like this.
  20. Apr 29, 2022 at 4:57 PM
    #6920
    Blkvoodoo
    Kevin
    Near Clayton NC
    None of us did early on.
    Cringe even more at topping batteries of with iron rich water….
    RustyGreen likes this.
