Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. May 5, 2022 at 4:50 AM
    #7021
    My Name is Rahl
    I need the length in mm. I assume it is fine thread since it's a flywheel bolt?
  2. May 5, 2022 at 4:52 AM
    #7022
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I'm guessing 20mm :popcorn:
  3. May 5, 2022 at 5:27 AM
    #7023
    My Name is Rahl
    Or it's an M8-1.25x 25mm...
  4. May 5, 2022 at 5:36 AM
    #7024
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'll measure it again once I head out to the shop.
  5. May 5, 2022 at 9:35 AM
    #7025
    koditten
    Kirk
    Central Michigan
  6. May 5, 2022 at 9:39 AM
    #7026
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  7. May 5, 2022 at 9:42 AM
    #7027
    koditten
    Kirk
    Central Michigan
    Nice to see my $12 overseas calipers read the same as the domestic stuff.
  8. May 5, 2022 at 9:43 AM
    #7028
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Yes it is, add a zero to the end for the ones I'm using :eek:
    Absolutely no difference in function though :D
    RustyGreen and koditten[QUOTED] like this.
  9. May 5, 2022 at 10:49 AM
    #7029
    My Name is Rahl
    The length is from under the head. I assume 20mm?
    RustyGreen and six5crèéd[OP] like this.
  10. May 5, 2022 at 11:00 AM
    #7030
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That's why I measured one we have, to show you this. See the one I tagged you in below his :facepalm:
    wilcam47 likes this.
  11. May 5, 2022 at 11:06 AM
    #7031
    koditten
    Kirk
    Central Michigan
    Btw, this is an SAE thread bolt.
  12. May 5, 2022 at 11:09 AM
    #7032
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    In need of a cheap push mower. What should I be looking for on Craigslist? It will be for a patch of weeds with some grass mixed in so I don’t need anything nice just something that won’t crap out on me.
    six5crèéd[OP] likes this.
  13. May 5, 2022 at 11:09 AM
    #7033
    koditten
    Kirk
    Central Michigan
    Hopefully these fuckers will learn to stay away from my gennie!
    Using @Steve Urquell recipe.
    Fluid Film and Cheyenne pepper .
    I'm still sneezing!
    I found their access. Stuffed the hole with a copper brillo pad.
  14. May 5, 2022 at 11:12 AM
    #7034
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Looks like you can get a brand new one at Wal Mart for around $225, if buying a used one just make sure it runs good and doesn't smoke and it's cheap:thumbsup:
  15. May 5, 2022 at 11:13 AM
    #7035
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  16. May 5, 2022 at 11:16 AM
    #7036
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Don't be stingy with that cayenne. I cover anything I don't think it'll hurt in a layer. If they get in after that I'll be extremely surprised.
  17. May 5, 2022 at 11:22 AM
    #7037
    koditten
    Kirk
    Central Michigan
    After I can breath, I'll give it another dose.
    Thanks!
  18. May 5, 2022 at 11:23 AM
    #7038
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Wait until the wind changes, I can smell it down here!!!!
    RustyGreen and wilcam47 like this.
  19. May 5, 2022 at 11:25 AM
    #7039
    Steve Urquell
    I made some habanero pepper spray by soaking habaneros in alcohol until the liquid turned orange. I sprayed that on a hot engine and good GOD, I retched so hard I felt like it turned me inside out. It did NOT deter the rodents though.
  20. May 5, 2022 at 11:27 AM
    #7040
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :rofl::rofl::rofl:
