Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. May 5, 2022 at 3:46 PM
    #7061
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Depends on how old, I have a big 1960's Wisconsin powered Bolens Husky 1256 around here somewhere. It is the tractor that got me started with the Wisconsin engines years ago -- I liked the bark of the exhaust. :laugh:
    Like this:
  2. May 5, 2022 at 4:23 PM
    #7062
    My Name is Rahl
    I have one that I'd like to sell.
    1969 Bolens 1220.
  3. May 5, 2022 at 4:48 PM
    #7063
    RustyGreen
    sleeping in a chair
    Pavement Princess
    That would be a "Husky" tube frame series, quality machines -- weighed in about 650 with no attachments.
    Originally had a Tecumseh 12 hp engine and a manual transmission, the hydro version was a 1225.
  4. May 5, 2022 at 4:50 PM
    #7064
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I like them. The ones I dealt with were built like brick shit houses!
    They were quite busy when it came to the mechanicals.
  5. May 5, 2022 at 4:54 PM
    #7065
    RustyGreen
    sleeping in a chair
    Pavement Princess
    They did have quite a bit going on didn't they, built to be serviced and repaired however.
    The starter/generator never sounds ambitious but they seem to work, mostly.
  6. May 5, 2022 at 4:58 PM
    #7066
    koditten
    Kirk
    Central Michigan
    Lol. You are right. It was at times easier to just wrap a cord around the fan flywheel. Seemed odd they had a built in notch for wrapping the pull cord.
  7. May 5, 2022 at 5:26 PM
    #7067
    koditten
    Kirk
    Central Michigan
    Serious, mower related question:
    What is the reason for the zero turn industry moving to vertcle shaft engines?
    As a wrencher, I would much rather work on horizontal shaft powered units.
    As for longevity, I'm not seeing a big difference in hours before a repower is required.
    Please express your opinion. The small searches I did were inconclusive.
    six5crèéd[OP] and RustyGreen like this.
  8. May 5, 2022 at 5:30 PM
    #7068
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    When you find out, let me know also. Horizontal/V twin engines tend to have less leaks [ crankseal isn't under oil] and last longer. Only thing I MAY think is you can make a mower more compact/shorter with a vertical then a horizontal engine.
  9. May 5, 2022 at 5:35 PM
    #7069
    RustyGreen
    sleeping in a chair
    Pavement Princess
    For the same reasons we have front wheel drive cars, cheaper to build and more efficient.
    It all comes to turning the direction of the power, with a horizontal shaft you must turn the power 90 degrees to drive the blade and nothing is ever free.
    That 90 degree turn uses expensive horsepower that can be put directly to use with a vertical engine. Also the mechanics to turn the power costs money.
  10. May 5, 2022 at 5:37 PM
    #7070
    koditten
    Kirk
    Central Michigan
    Yes.
    The 500 (horizontal) series vs the 5000 (vertical) series Toro mowers is a bit longer .
  11. May 5, 2022 at 5:39 PM
    #7071
    koditten
    Kirk
    Central Michigan
    New engines vs a more expensive deck belt and a a couple $25 idler pulley does add up.
  12. May 5, 2022 at 5:56 PM
    #7072
    RustyGreen
    sleeping in a chair
    Pavement Princess
    As you said for the commercial cutters the vertical engines seem to last just as long before needing a re-power.
    The simpler power transmission systems should be more reliable too --after all, the reliability of a part that isn't there is infinite.
    six5crèéd[OP] and koditten like this.
  13. May 5, 2022 at 6:04 PM
    #7073
    fxntime
    Grasshopper has a stupidly simple design. One end of the crank drives the hydros, the other end drives the deck driveshaft. Works extremely well. International cub cadet had the same set up, [I had a 104]
  14. May 5, 2022 at 6:11 PM
    #7074
    koditten
    Kirk
    Central Michigan
    Untile you replace a clutch on a vertical shaft engine, all those points are valid .
    six5crèéd[OP] likes this.
  15. May 5, 2022 at 6:14 PM
    #7075
    fxntime
    That's why I put 44'' Ground Hawgs on my ZT, never get stuck and I can work under it.
    At 40 MPH I can now mow and drive on the highway if need be.
  16. May 5, 2022 at 6:15 PM
    #7076
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I wanted a Grasshopper front mount, they accept snow blowers and blades -- until I saw one in person. They are giants and take up a whole garage bay to store.
    :gossip: (...naturally if I stumble over one for cheap I will haul it home -- cool trumps smart for me sometimes...)
  17. May 5, 2022 at 6:19 PM
    #7077
    koditten
    Kirk
    Central Michigan
    I like them too, but the older ones had hydro drive motors that chain drove a wheel sprocket. Not sure if the new ones do or not .
  18. May 5, 2022 at 6:30 PM
    #7078
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    My little patch of weeds :annoyed:
  19. May 5, 2022 at 6:35 PM
    #7079
    fxntime
    Yeah, they are long, mine has a vacuum system with a dump hopper on it so at least the length is put to good use. They also cut closer to stuff then a normal ZT does. With no deck on the front [floats where it attaches to the mower body] it has little traction, put it on and it does well and side hills much better then a rear drive ZT.
  20. May 5, 2022 at 7:01 PM
    #7080
    fxntime
    My 720K uses hydros that then drive wheel motors. The filters for the hydros [2, one for each hydro] are the size of a filter for a V-8. I'd have bought another one if they were not so dang expensive now.
