Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. May 11, 2022 at 9:13 AM
    #7141
    My Name is Rahl
    Neighbor just gave this to me, I think it only has a 30" deck? Anything I should watch out for? Is there larger decks I can find to put on it? I only ask about that as I have about an acre to mow.
  2. May 11, 2022 at 9:19 AM
    #7142
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Price was right! Usually MTD parts and information is easy to find and not too expensive.
    Decks usually are specific to that kind of machine, probably not enough HP to turn a larger one also.
    Do a good service - oil, air filter, grease, sharpen the blade. Wouldn't be a bad idea to change the transmission oil as well.
  3. May 11, 2022 at 9:20 AM
    #7143
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Found a Rankin 3point splitter. From the picture it looks like a LS20E, so it should be switchable from horizontal to vertical and appears to be in good shape. Guy said it only go used for a couple cords and then got put in storage after he bought a bigger tractor. Having my folks pick it up today. Figured I would get it for my father to use as his 5t electric splitter is a PITA. At $350, I feel it's a good buy.
    Plus, it gives me good reason to run a power beyond circuit to the back of the tractor.
    RustyGreen and six5crèéd[OP] like this.
  4. May 11, 2022 at 9:31 AM
    #7144
    Toyko Joe
    Toyko Joe Here for the pictures
    I love those little doodle bugs.
    https://www.promow.com/product/po301/
    It seems like this company is way out of stock, but one suggestion. Otherwise in all honesty look for a zeroturn. I really like the Toro Timecutter 42. For my 3 lawns totaling 1.125 acres.
  5. May 11, 2022 at 9:34 AM
    #7145
    Toyko Joe
  6. May 11, 2022 at 9:55 AM
    #7146
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    not a bad deal. I do hear the 3pt splitters are quite slow given the lower GMP on most tractors except skidsteers. What machine are you planning to use?
  7. May 11, 2022 at 10:06 AM
    #7147
    My Name is Rahl
    Thanks, Rusty. I figured I'd need to do a service. Just didn't know if I was going to run into head gasket issues or not.
    I'd love to have a zero turn mower, but right now, $free is about all I can afford with having to do other home repairs.
  8. May 11, 2022 at 10:32 AM
    #7148
    windsor
    windsor Just a guy
    Homeless in Oregon
    It's going to go on my 1955 Ford 640 with Wagner FEL and crank driven pump. Good thing is, if it doesn't work well on my setup, price is low enough to either flip it or build it to a trailer mounted unit with an engine & pump. Plan to give my father my trailer next yr when I buy a new one anyways and since he borrows it to haul firewood, it would make a decent setup either way.
  9. May 11, 2022 at 10:36 AM
    #7149
    Toyko Joe
    I totally understand. $Free.99 or barter is my game lately for personal items. I think I sold or traded about $2k worth of parts and equipment since December and I still have more I want and need to work on getting. The 30" mower will work just fine, just take a few more cold ones to complete the mowing job. :cheers:
  10. May 11, 2022 at 1:33 PM
    #7150
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Well fellers, I'm feeling a bit nervous...
    So far 3 mowers have gone to work no problems and today the weed eater started first pull. o_O
    Generally Rusty's luck doesn't go this way, I hope there isn't a new (and expensive) disaster lurking on my personal horizon.
    :fingerscrossed:
    I even started up the old International 140 today, cranked less than 5 seconds.
  11. May 11, 2022 at 1:58 PM
    #7151
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    :yay:
    RustyGreen[QUOTED] likes this.
  12. May 11, 2022 at 2:01 PM
    #7152
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Finally got a new tie rod end for the 4630, it’s been loose for a while. Had they put a grease fitting in it from the factory it may still be good, and it had a rubber cover to keep the dirt out. Now to find time to replace it.
  13. May 11, 2022 at 2:08 PM
    #7153
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Yes.
    It's nice to be able to remove the gate entirely If you have to haul something long.
  14. May 11, 2022 at 4:49 PM
    #7154
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    I puncture the boot with a grease needle on those and grease them anyways. At 160,000 miles my wife's car and my truck still had good tie rod ends and ball joints because of that.
  15. May 11, 2022 at 4:54 PM
    #7155
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Who needs a tractor when you have a Lexus?
  16. May 11, 2022 at 5:16 PM
    #7156
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Or unload something with a forklift. ;)
  17. May 11, 2022 at 5:16 PM
    #7157
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I always wondered what Lexus owners did with their free time. :101010:
  18. May 12, 2022 at 6:27 PM
    #7158
    koditten
    Kirk
    Central Michigan
  19. May 13, 2022 at 2:56 AM
    #7159
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    No, no, no, those are ''opportunity purchases.'' They allow you to buy new needed tools and man toys and to justify the expense to your SO. ''But honey, I HAD to buy that new MIG welder, besides, I'll be able to use it on all sorts of other stuff too!!"
  20. May 13, 2022 at 3:03 AM
    #7160
    fxntime
    That's about 6 miles from me. I'd need to build another workshop if I bought any more stuff.
