Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. May 27, 2020 at 8:00 PM
    #701
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Good point. If the property is full of stumps and what not, the price goes up.
    One guy I broke the total cost down for tractor ownership/hourly cost and he was surprised. He still complained about the price though.
  2. May 27, 2020 at 8:02 PM
    #702
    Bigdaddy4760
    Maner
    Poolville Texas
    Exactly and will not give a hourly rate till I have looked at. Been bit by that before.
  3. May 28, 2020 at 4:40 AM
    #703
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    I have 2 but both of mine are shaft drive garden tractors. Those little riders have K46 hydrostats are are only meant to mow flat yards <1 acre. They are famous for overheating and burning up if overworked or mowing hills.
    If you want a Cub that will last look for the hump in the floor pan. That means it is shaft drive and has a very robust hydrostat and cast iron rear differential(aluminum if built before year 2000). If I were looking for another mower I'd buy another used Cub 3000 series. Shaft drive, auxiliary hydraulic circuit, hydraulic power steering and deck lift or a nice 2000 series.
    Below are my XT3(similar to 2000 series) and 3240.
  4. May 28, 2020 at 5:00 AM
    #704
    Steve Urquell
    You'd cook that thing in a month. Try to find a nice used 3000 series. They also have shaft driven decks. The power steering is soooo nice. I always was sore after mowing 3 acres of rough fields with my manual steering wheelhorse and thought it was from the bumps. After getting my XT3 with power steering I found out the soreness was actually from sawing the manual steering.
  5. May 28, 2020 at 5:09 AM
    #705
    Steve Urquell
    Yep. After 20yrs of mowing 2.5-3.5 acres I went to mowing 1.5 with the XT3 and brushhogging the rest every 6 weeks. Saves me a bunch of time and wear and tear on my mower.
    Bigdaddy4760 and six5crèéd[OP] like this.
  6. May 28, 2020 at 5:10 AM
    #706
    Bigdaddy4760
    Maner
    Poolville Texas
    I can probably round ya one up if ya want me to start looking.
  7. May 28, 2020 at 5:53 AM
    #707
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    clamp on will work but you are not going to get the same lifting power you would from a dedicated fork assembly. You will also be limited by the strength of your bucket lip which could deflect over time. They do work for light work, brush, maybe logs if not too heavy but the camps are putting the load much further away from your lift point and how the numbers on the tractor are presented. Factor in the bucket length and now add forks.
    Will they work, sure...... for the money and depending on other uses for forks, looking at a quick attach set might be a better investment. Im not sure what machine they are going on as you mentioned skid steer which has its own QT standard.
  8. May 28, 2020 at 6:07 AM
    #708
    ColoradoTJ
    Colorado
    This is part of my concern as well. This would be going on my Kubota. 564E8876-8DD9-4ACE-B8C0-E345CBCCD9CB.jpg
    I would be using the tractor for trees like in your posted image.
    The easiest way to solve this issue is to cut the trees in 5’ sections and go from there.
  9. May 28, 2020 at 6:19 AM
    #709
    jester156
    Cumberland, RI
    Titan is a hit or miss from what I see on the JD forums but ive been very happy with mine for what i need:
    https://www.palletforks.com/skid-steers/pallet-forks/pallet-fork-attachments/
  10. May 28, 2020 at 6:22 AM
    #710
    Bigdaddy4760
    Maner
    Poolville Texas
    Just curious, have you thought about a set of hay forks for the front end. I have a set and use them for pallets, loading brush and all kinds of stuff. Also a lot cheaper than forks.
    Generic pic as I don't have one on my phone
  11. May 28, 2020 at 6:40 AM
    #711
    ColoradoTJ
    Colorado
    Great suggestions.
    I’m just going to use life’s lessons on this one. Every time I try and do something the cheap way, it bites me in the ass hard later. This is probably one of “those” times.
    I’m going to look for a quick disconnect fork set or make my own.
  12. May 28, 2020 at 6:44 AM
    #712
    Bigdaddy4760
    Maner
    Poolville Texas
    Mine are actually Bush Hog BS-2 Tractor-Mounted Bale Spears
  13. May 28, 2020 at 6:45 AM
    #713
    ColoradoTJ
    Colorado
    Thank you. I also like this idea.
  14. May 28, 2020 at 6:47 AM
    #714
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Buy once, cry once, can't go wrong with that :thumbsup:
  15. May 28, 2020 at 6:53 AM
    #715
    ColoradoTJ
    Colorado
    It took me a while to figure this out with my rock crawling rigs.
    Great advice.
  16. May 28, 2020 at 7:04 PM
    #716
    Tractorman
    Tractorman Just A Dumb Farmer
    Stupid
    Misery
    2015 DCSB / MGM
    I wouldn’t do it for any less, in fact I would charge more. I till a few gardens around town, some might not like paying the price but they also don’t want to rent or buy a tiller. No body gave me the equipment!
  17. May 28, 2020 at 7:57 PM
    #717
    ColoradoTJ
    Colorado
    After today navigating 13 acres with stumps everywhere, you are correct. It was slow and go, and I was doing it for my neighbor.
    A1195983-C6BD-47CA-AC4F-58F284F5EBD0.jpg 6195BA88-CA4C-4288-A69B-A8421AD4082C.jpg
    She’s alone, mid 70’s, not doing well. So I chopped up a cord of wood, and had my girls stack it for her.
  18. May 29, 2020 at 4:46 AM
    #718
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Nothing really to add, except that A) I didn't see a zero turn mentioned. They're a one-trick pony for the most part, (depending, I suppose) but I mow 3 acres in about an hour with mine. It's an older Ferris.
    Also, I love the new avatar, gave me a good chuckle when I logged in this morning.
  19. May 29, 2020 at 4:59 AM
    #719
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    If they don't cut well you either aren't keeping after the blades or you have the wrong brand of mower, but good ones are very expensive
  20. May 29, 2020 at 5:00 AM
    #720
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I bought a Great Dane zero turn with a 61" deck at an auction, long story short traded it for a nicer Bobcat zero turn with a 52" deck, couldn't stand either one of them. Neither cut well, had to mow a lot of my grass twice to get a good cut even with new blades. Recently bought a Hustler with a 52" deck but 7 more HP than the Bobcat and the Hustler mows circles around both of the other ones. The Hustler is used and I gave $4K for it, sold my Bobcat and Trac-Vac and another mower I pulled the Trac-Vac with and it cost me $425 to trade. I figure I have about $3K in the Hustler with all the trading I did over the last 9 years :D
    Here it is with the vacuum system on and off.
