Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. May 26, 2022 at 7:20 AM
    #7481
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    If it's not locked up it wouldn't take much to get it going. Clean the carb and fuel lines, get some spark out of the magneto (may be able to file the points) and it should light off. They are pretty simple, fuel, fire, and air and off she goes :D
    If it had gas left in it and the lines, tank, carb, etc. are gummed up it makes it 10 times worse though.
    RustyGreen and toysrgood[QUOTED] like this.
  2. May 26, 2022 at 7:21 AM
    #7482
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That gas can laying under it, a friend of mine came by last week and had one he had just bought at a flea market. It looked really good and still had the original $7.99 price tag attached.
  3. May 26, 2022 at 7:30 AM
    #7483
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    Next time I go home I will poke around at it and see how it looks.
  4. May 26, 2022 at 7:33 AM
    #7484
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    If you do try and get it going, be sure and drain/replace the oil in the air breather cup. They can get nasty in the bottom :thumbsup:
  5. May 26, 2022 at 7:44 AM
    #7485
    toysrgood
    SC
    2011 4x4 Reg Cab
    That is what I'm afraid of. Lots of fluids that could gunk up and be nasty. Lots of cleaning and replacing hoses. Old gunk is no fun.
  6. May 26, 2022 at 8:30 AM
    #7486
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    Anyone ever have to try and break up and remove reclaimed concrete that’s been broken up and repaid on a dirt road?
    RustyGreen and six5crèéd[OP] like this.
  7. May 26, 2022 at 8:35 AM
    #7487
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I have not but it shouldn't be that bad if you have a box blade with some rippers.
    RustyGreen likes this.
  8. May 26, 2022 at 8:46 AM
    #7488
    toysrgood
    SC
    2011 4x4 Reg Cab
    I texted my dad to see what its condition was the last time he looked.
    It saw a lot of service. It was put away in '69 after grandad passed. He had the valves ground in '64. The cylinders are tight/seized and there are black carbon deposits around the exhaust.
  9. May 26, 2022 at 8:48 AM
    #7489
    MikeyD.25
    MikeyD.25 Well-Known Member
    As a kid I worked on a farm in Lancaster Cty., PA during the summer with a Deere just like that one. Farmer used it for cultivating/weeding and for the PTO during harvesting season. Attached a strap from the PTO wheel on the side of the Deere to the equipment used to shoot the silage up into the to opening at the top of the silo.
    The main workhorse for use around the farm was an Alice Chalmers.
  10. May 26, 2022 at 8:49 AM
    #7490
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    If it's been sitting that long, that would be tough to get running without a full engine rebuild. That's just to get it freed up.
  11. May 26, 2022 at 8:51 AM
    #7491
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The nice thing about the old tractors is you can stand there and work on them.
    No contorting yourself and only basic tools required.
    You can probably pull the oil pan off in 10 minutes.
  12. May 26, 2022 at 8:54 AM
    #7492
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I believe parts are readily available for that too.
    toysrgood and six5crèéd[OP] like this.
  13. May 26, 2022 at 8:56 AM
    #7493
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Them old 2 cylinder J.D.'s don't have an oil pan, they have a crankcase and the block/head are horizontal :thumbsup:
    The crank and connecting rods are accessed through a cover on the top and sides.
    Some of the 2 cylinders had a oil pan and the cylinders were vertical. Like the M, 40, 420, 320, 330, 430, etc.
    RustyGreen[QUOTED] and toysrgood like this.
  14. May 26, 2022 at 8:58 AM
    #7494
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Its prob just surface corrosion in the cylinder walls unless water or coolant leaked in there.
  15. May 26, 2022 at 9:00 AM
    #7495
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That's what I was thinking from sweating but it's been sitting 53 years, could be worse than expected.
  16. May 26, 2022 at 9:00 AM
    #7496
    toysrgood
    SC
    2011 4x4 Reg Cab
    There are pictures of my great grandad and that setup next to horse drawn hay wagons at the farm. Right around the time when people used both animal and machine power.
    They also had a '37 JD A which probably served as the main workhorse. The B was likely used more for what you're describing and for pulling wagons and other secondary tasks.
    I have my grandads entire inventory list from when he bought the farm from his dad in '58. Down to hammers and hay forks. Most of that was sold at auction after he passed.
  17. May 26, 2022 at 9:02 AM
    #7497
    toysrgood
    SC
    2011 4x4 Reg Cab
    The machine shed has a ton of moisture. Anything metal sweats during certain times of the year.
  18. May 26, 2022 at 9:02 AM
    #7498
    wilcam47
    Will
    Bourbon state
    Yep. If its heavy rust, run risk of snapping piston rings.
  19. May 26, 2022 at 9:02 AM
    #7499
    jpneely
    Charleston, SC
    Even if the reclaimed crushed up concrete has pretty much reset into concrete again? Would it be able to break that up again?
  20. May 26, 2022 at 9:02 AM
    #7500
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That's the way it is here.
    RustyGreen and w.adventures like this.
