Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Jun 3, 2022 at 6:54 AM
    #7601
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    That's what the inside or an Intek looks like lol.
    RustyGreen and six5crèéd[OP] like this.
  2. Jun 3, 2022 at 6:55 AM
    #7602
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I had one on my last zero turn, wasn't a fan. It blew the crankcase gasket while getting leaves up. Luckily I noticed all the oil before internal damage occurred. It must have been a problem with that particular engine cause when I got a new gasket it came with new bolts.
  3. Jun 3, 2022 at 7:04 AM
    #7603
    Lt. Dangle
    Ohio
    Like I said, the older I/C motors and Vanguards are better IMO. Vanguards are flat better, period.
    I like my 13.5 intek single, but if it blows, I probably will go a different repower route.
  4. Jun 3, 2022 at 7:14 AM
    #7604
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I have a Vanguard on the wood chipper -- that is a sweet running engine! :)
  5. Jun 3, 2022 at 7:17 AM
    #7605
    Lt. Dangle
    Ohio
    I look for anything vanguard powered on fbm. Even if I don't need it lol.
  6. Jun 3, 2022 at 11:42 AM
    #7606
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Just got home. Gonna pop the engine out now.
    It's got a good battery and a full tank of gas . I'm already ahead.PXL_20220603_184034980.jpg
  7. Jun 3, 2022 at 12:08 PM
    #7607
    koditten
    Kirk
    Central Michigan
    Does this shit only happen to me?
  8. Jun 3, 2022 at 12:13 PM
    #7608
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Yes. It’s not like it’s new or anything :luvya:
    But for real, how does that even happen.
    koditten[QUOTED] likes this.
  9. Jun 3, 2022 at 2:55 PM
    #7609
    Lt. Dangle
    Ohio
    What's wrong with the motor?
  10. Jun 3, 2022 at 3:05 PM
    #7610
    koditten
    Kirk
    Central Michigan
    As far as I know, nothing.
    Seller started it just before I winched it on the trailer. No smoke noted on a cold start . It sounded great thru all rpm ranges.
    I have an Exmark walk behind unit that needs an engine. My intention is to use this one on the walk behind. It originally had an FH 580. I'm not wasting time finding out why the Kawasaki keeps dislodging push rods.
    It's an older unit, so a person has to limit themselves to how much money is worth it to invest in it...as most on this thread know.
    I will have to McGyver the wire harness, but that shouldn't be a big puzzle.
  11. Jun 3, 2022 at 6:05 PM
    #7611
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Click bait title: Check
    Kohler Engine oil, I can't believe what it did to my engine!!!
    Sensationalist text: Check
    You won't believe what Rusty found when he pulled the valve cover!!!
    Did some work on the CC ZT today. This is a 2006 with 518 hours, Kohler Courage 17hp single. It has had Kohler 10W-30 oil and WIX filters changed every 50 hours.
    The photos above are exactly as found, I hadn't wiped anything off. The valve cover has 2 pieces that pop together -- used for crankcase ventilation, in photo 4 you can see the plastic fabric filter and the one way valve.
    The ignition switch worked fine but I was afraid the key was going to fall out -- took 60 seconds to change with only a putty knife to pop it out of the fender.
    It uses very little oil but I have been noticing some oily dirt build up under the valve cover area. While I was there I adjusted the valves for the very first time ever. The intake was just slightly tight, the exhaust just slightly loose, rounded the job out with a new plug and valve cover gasket.
    Here's hoping for another 500 hours. :fingerscrossed:
  12. Jun 3, 2022 at 6:07 PM
    #7612
    koditten
    Kirk
    Central Michigan
    Click bait!
    six5crèéd[OP] and RustyGreen like this.
  13. Jun 3, 2022 at 6:08 PM
    #7613
    koditten
    Kirk
    Central Michigan
    Thought that was gonna segue into a boner pill add...
  14. Jun 3, 2022 at 6:12 PM
    #7614
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :rofl::rofl:
  15. Jun 4, 2022 at 8:41 AM
    #7615
    SCOTT'S TACO LOCO
    SCOTT'S TACO LOCO Orange It.
    Scott
    San Antonio, Tx
    08 Toy-yo-duh TACO TRD
    Called Kubota yesterday to check up on the progress of my Orange, he said they started putting in the backup camera. Radio is scheduled to be installed on Monday.
  16. Jun 4, 2022 at 10:29 AM
    #7616
    MikeyD.25
    MikeyD.25 Well-Known Member
    GMRS or FM Business band radio I hope! :thumbsup:
  17. Jun 4, 2022 at 11:15 AM
    #7617
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    The stuff works but dogs do like it. I got four inch diameter PVC pipe and a "T". I cut the pipe to three section each about four feet in length and pieced it together. With two chains staked to hold it on the ground, I could lift the center pipe and drop the chunk bait into the center part of the "T". It was large enough for the rodents to get into the dark. It was also large, heavy and awkward enough that the dogs didn't seem to notice. Two black labs gave it some sniffs and left it alone.
  18. Jun 4, 2022 at 11:23 AM
    #7618
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Standard radio with bluetooth, what ever Kubota uses, and its the quote 'free radio'... that were going to throw into this 70k skidsteer. Machines I rented and used last year with radios, I still wore ear plugs, because of hydraulic whins and other what sound knots.
  19. Jun 4, 2022 at 11:36 AM
    #7619
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I like tire bonnets. I prefer the ones with 3 hooks rather than 2, especially for cars. The angle change in the 3 hook is less likely to cause damage to body panels and less likely to have a body panels cut through the strap.
    You can buy and add the idler hooks if you already have bonnets or tire straps.
    On my next car/tractor trailer (looking at a 10k full tilt 7x18), it will get setup with either bolt/weld on D rings or two rows of E track on each side to use tire bonnets on my '40.
  20. Jun 5, 2022 at 6:54 AM
    #7620
    RustyGreen
    sleeping in a chair
    Pavement Princess
    That is a great solution -- and cheap too! :101010:
    six5crèéd[OP] and JGO[QUOTED] like this.
