Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    46.7%
  2. After
    56.7%
  3. Neither
    13.3%
  4. I weed whack while someone else mows
    6.7%
Multiple votes are allowed.
  1. Jun 9, 2022 at 11:02 AM
    #7661
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Working on my jungle today .
    Put my plasma table cut grapple to work.
    Worked amazing for being home made...just wish it was 3 times bigger .
    I'm about half way done with this hot mess.
  2. Jun 9, 2022 at 11:07 AM
    #7662
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    :101010::oldglory:
    RustyGreen and wilcam47 like this.
  3. Jun 9, 2022 at 2:14 PM
    #7663
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    I’ve used one similar on the golf course mowing steep hills. Climbs like a goat but terrible in the knees with the articulation.
  4. Jun 10, 2022 at 7:59 AM
    #7664
    koditten
    Kirk
    Central Michigan
    Taking the wife out for lunch.
    I am not buying anything!
  5. Jun 10, 2022 at 8:07 AM
    #7665
    My Name is Rahl
    Famous last words!
    RustyGreen and six5crèéd[OP] like this.
  6. Jun 10, 2022 at 8:18 AM
    #7666
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I'm not buying what you are saying :evil:
    :fistbump:
    JGO, RustyGreen and koditten[QUOTED] like this.
  7. Jun 10, 2022 at 10:05 AM
    #7667
    koditten
    Kirk
    Central Michigan
    Did the shopping before lunch.
  8. Jun 11, 2022 at 8:04 AM
    #7668
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    5 hour oil change complete. Does anybody have a recommendation for a hour meter? Is it worth it on something I should just change the oil yearly?
    six5crèéd[OP] and RustyGreen like this.
  9. Jun 11, 2022 at 8:13 AM
    #7669
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Having data is better then wondering to me. You can get all sorts of different hour meters for not much money anymore.
    six5crèéd[OP] likes this.
  10. Jun 11, 2022 at 8:47 AM
    #7670
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    I put me of these on a suitcase generator I carry in my work van, either I don’t use it as often as I though (possible) or it’s not extremely accurate
    Lead wraps around plug wire as it’s trigger and pickup. I have it adhered inside the case.
    https://www.amazon.com/dp/B07Y3ZYBLW?ref_=cm_sw_r_cp_ud_dp_R95YYT0DSMNEPWNG8BZ8
  11. Jun 11, 2022 at 8:57 AM
    #7671
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Dumb question on small trailers, are the bearing typically standard size? Thinking about getting a used 5x8 sized trailer. Ive only greased them so never messed with them. Buying used, bearings and tires would be my only real concern.
  12. Jun 11, 2022 at 9:06 AM
    #7672
    RustyGreen
    sleeping in a chair
    Pavement Princess
    All pretty standard stuff.
    Your local TSC should have every repair part you would ever need.
    Unless the trailer has been submerged, 80 mph while grossly overloaded or run with the dust caps off the bearings are usually pretty trouble free. Repack them when you get the trailer and you are good for 10 years or more.
  13. Jun 11, 2022 at 9:09 AM
    #7673
    wilcam47
    Will
    Bourbon state
    We always had junky stuff growing up so breaking down on highway is always a concern. Plus you never know what the last ownwer did or didnt do. Hopefully i can find something cheaper than full price of new trailers...
  14. Jun 11, 2022 at 9:20 AM
    #7674
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Decent used trailers are insanely expensive now. :eek:
  15. Jun 11, 2022 at 9:28 AM
    #7675
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    One of the reasons I am building my own for the splitter. I'm seeing people selling HF trailers for $1k after adding side boards and beating the crap out of the trailer. I'd rather have 3.5k ez lube axles instead of a 1.5k pos axle with questionable bearings and spindles. It is sometimes better to spend extra money to have something that will last a lifetime than to save money but get something that will break down and be left on the side of the road in a year or two.
  16. Jun 11, 2022 at 9:39 AM
    #7676
    RustyGreen
    sleeping in a chair
    Pavement Princess
    My state makes is extremely difficult to title a home built trailer -- just isn't worth the aggravation.
    As a consequence of this, or a benefit if you happen to be selling, junk on wheels with a title has a $1000 price tag now.
  17. Jun 11, 2022 at 9:41 AM
    #7677
    windsor
    windsor Just a guy
    Homeless in Oregon
    That sucks.
  18. Jun 11, 2022 at 10:26 AM
    #7678
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Probably standardized as has been answered. My experience with my trailers and swapping axles has been the #2200 and #3500 axles have all used bearings that were nothing special and pretty consistent based on the axle diameter itself.
    https://www.etrailer.com/faq-popular-wheel-bearings.aspx
  19. Jun 11, 2022 at 11:07 AM
    #7679
    koditten
    Kirk
    Central Michigan
    Dammit!
    Sold this mower to a friend 2 years ago and he hit some old foundation rerod. This deck is not savable. Bent and twisted.
    What did Russ say about rubber rooms, naked and anvils?
    That describes the peeps I hang with.
    Fortunately they are good payers.
  20. Jun 11, 2022 at 12:25 PM
    #7680
    wilcam47
    Will
    Bourbon state
    Yes. Ive seen some on auction but they go overbid of what a new one costs ,so i usually bail at $300-400
