Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    45.5%
  2. After
    57.6%
  3. Neither
    12.1%
  4. I weed whack while someone else mows
    6.1%
Multiple votes are allowed.
  1. Jul 5, 2022 at 3:25 PM
    #7921
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Your welcome
  2. Jul 5, 2022 at 3:39 PM
    #7922
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Hard to go wrong with the MTD built stuff, parts are available from many different sources.
  3. Jul 5, 2022 at 3:40 PM
    #7923
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Trying to mow here but it too danged hot. I mowed all the shady spots hoping the sun would recede a little. Nope. Waiting till 7pm or so.
    Delta09, JGO, six5crèéd[OP] and 3 others like this.
  4. Jul 5, 2022 at 3:45 PM
    #7924
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :annoyed::goingcrazy:
    six5crèéd[OP] and RustyGreen like this.
  5. Jul 5, 2022 at 3:51 PM
    #7925
    RustyGreen
    sleeping in a chair
    Pavement Princess
    For years I mowed late at night at home, the nearest neighbor is a 1/4 mile away.
    I used a magnet mount work light on the ZT.
  6. Jul 5, 2022 at 3:53 PM
    #7926
    wilcam47
    Will
    Bourbon state
    Ive heard some mowing aroud 10-11pm here
  7. Jul 5, 2022 at 4:41 PM
    #7927
    Steve Urquell
    If it keeps this up I'll mount some Nilights like I put on my 3240. 18w LEDs I think.
  8. Jul 5, 2022 at 4:50 PM
    #7928
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Started stripping the cowling.
    I'm leaning towards the breather plate gasket in the center of the block "v".
    Still want to pop the flywheel to verify that the front main seal is intact.
    Once you are this far, it is easy math to just keep checking the usual suspected places for a significant oil leak.
    PXL_20220705_210934270.jpg PXL_20220705_210946039.jpg PXL_20220705_211001992.jpg
  9. Jul 5, 2022 at 5:11 PM
    #7929
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Kinda reminds me of the time I was gettin’ a haircut & the Boss walked in. Saw the Co. car out front of the Barbershop/Poolhall.
    Told ‘em it grows on Co. time. :laugh:
  10. Jul 5, 2022 at 5:46 PM
    #7930
    Steve Urquell
    I pulled a brushhog blade off waiting on the sun to drop. Swisher designed it poorly and the bolts tighten and the blades stop swinging. Threaded stumpjumper and a locknut on top to jam the bolt a little loose on the blade so it will swing. Everyone who has one has this problem. It needed shoulder bolts.
    I'm thinking of buying a bolt with some shank and let it jam on the stumpjumper threads so it can't tighten up unless y'all have any better ideas.
    Screenshot_20220705-192223_(1)_compress38.jpg 20220705_190709_compress90.jpg
  11. Jul 5, 2022 at 9:47 PM
    #7931
    RustyGreen
    sleeping in a chair
    Pavement Princess
    McMaster - Carr has 3/4" clevis pins - not sure they would be strong enough compared to a grade 8 bolt.
    https://www.mcmaster.com/pins/clevis-pins-7/
    six5crèéd[OP] likes this.
  12. Jul 6, 2022 at 4:44 AM
    #7932
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    How about a regular shoulder bolt? They're made for applications like that.
  13. Jul 6, 2022 at 4:46 AM
    #7933
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I thought about those but the hole in the blade would have to be opened up cause the threads are smaller than the shank. The blade is probably hard(ish).
  14. Jul 6, 2022 at 5:50 AM
    #7934
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    I only looked at the setup briefly and I couldn't get dirty so I couldn't poke around much. I'll see about measuring it, and if I need to, get some better pics. Thank you gentlemen!
    RustyGreen and six5crèéd[OP] like this.
  15. Jul 6, 2022 at 5:53 AM
    #7935
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    If you have a Tractor Supply near you they have one as well. Might could buy one and see if it fits, if not return it.
    https://www.tractorsupply.com/tsc/product/countyline-box-blade-shank?cm_vc=-10005
  16. Jul 6, 2022 at 10:42 AM
    #7936
    Steve Urquell
  17. Jul 6, 2022 at 10:43 AM
    #7937
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    More than likely :thumbsup:
    RustyGreen and wilcam47 like this.
  18. Jul 6, 2022 at 10:44 AM
    #7938
    Steve Urquell
    Yep. 3/4". Someone on the tractor forum said he puts his bolt in from the top and that helps
  19. Jul 7, 2022 at 9:08 AM
    #7939
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Got all stainless hardware for the trailer floor from McMaster Carr cheaper than I could get galvanized. This was half the cost of the lumber :annoyed:
  20. Jul 7, 2022 at 9:34 AM
    #7940
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    You might want to do a google search to see if there was ever a recall on that line of bushhogs for blade issues. How many hours do you think you put on it before the bolt seized up?
