Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Jul 7, 2022 at 9:47 AM
    #7941
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I took these ramps off of a tandem gooseneck I bought and cut them down to fit this trailer many years ago. Got the mesh reattached and almost ready for new paint. Time to do the other one.
  2. Jul 7, 2022 at 11:24 AM
    #7942
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Other side done.
  3. Jul 7, 2022 at 11:39 AM
    #7943
    Tacoma Mike
    Southern Maine
    I need to find some elcheapo led square mount driving lights to add to my winch frame on my JD D140 for my blower.
    A whopping 9amp charging system doesn’t have much reserve for anything excessive.. LOL.
  4. Jul 7, 2022 at 11:56 AM
    #7944
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    @Steve Urquell what do you have on yours?
    RustyGreen likes this.
  5. Jul 7, 2022 at 12:04 PM
    #7945
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    I’ve got a Kawell pod on the back of my 4wheeler, works great for seeing at night loading deer.
    https://www.amazon.com/KAWELL-Shoot...&qid=1657220377&sprefix=Kawell,aps,125&sr=8-4
    https://www.amazon.com/s?k=kawell+l...efix=Kawell,aps,125&ref=nb_sb_ss_ts-doa-p_1_6
  6. Jul 7, 2022 at 12:08 PM
    #7946
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    I agree, I look at the attention to details in the build quality between the White and the sears mower... no comparison IMO. The White uses tiny rod ends on the steering tie rod, the sears mower had a piece of solid bar that was bent at the ends and passed through plastic bushings that no longer exist. I had to adapt a used Kubota tie rod onto the sears. The big deal for me is that the blade RPM seems much higher on the White, it devours grass while moving along at a good clip. The sears just wants to bog down when the grass is too high, it forces me to creep along in 1st gear with the deck raised in a higher position. I like that I sit lower in the White, I don't feel like I'm going to tip over when I cut across the hill. I have to do a 'sail boat' style counter lean when I cut the same way with the sears mower. I really can't whine about either one, they both cut grass, which is all I need them to do. I was hoping that the sears mower would work at least as good as the White so that I could sell the White and just cut the lawn on a low-budget riding mower.
  7. Jul 7, 2022 at 12:17 PM
    #7947
    Tacoma Mike
    Southern Maine
  8. Jul 7, 2022 at 12:47 PM
    #7948
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
  9. Jul 7, 2022 at 12:57 PM
    #7949
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  10. Jul 7, 2022 at 1:06 PM
    #7950
    Tacoma Mike
    Southern Maine
    Awesome TY.
    Could have found it I guess but to much shit in the fire right now.
  11. Jul 7, 2022 at 1:19 PM
    #7951
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Check out TSC, I have some on my old Ford plow tractor that you could drive a car with.
    They pull less power than the original backup bulb ones they replaced.
  12. Jul 7, 2022 at 1:23 PM
    #7952
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The older mowers were allowed a higher blade speed -- safety laws slowed them down, might be why the White cuts better.
    six5crèéd[OP] likes this.
  13. Jul 7, 2022 at 2:38 PM
    #7953
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Got my buddy to help take tires off and get it on jack stands.
  14. Jul 7, 2022 at 2:46 PM
    #7954
    SCOTT'S TACO LOCO
    SCOTT'S TACO LOCO Orange It.
    Scott
    San Antonio, Tx
    08 Toy-yo-duh TACO TRD
    Ok, got a question here for y'all.
    I want to paint the top of the skidsteer cab white to reflect some of this South Texas sun, it should cut down on some heat absorption.
    I bought a can oil based glossy white.
    But then I remembered there is also a roof coating materials like; Acrylic, Silicone and Elastomer.
    Any suggestions?
    six5crèéd[OP] and RustyGreen like this.
  15. Jul 7, 2022 at 3:05 PM
    #7955
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Roof products like that are generally thicker with a softer, grippy texture.
    It seems that tree branches and the like would get a better grip on that surface and do more damage to it rather than the smooth paint. The softer surface also imbeds dirt that will darken the color over time.
    Hard to beat an oil base finish for durability, throw some car wax on it now and then.
  16. Jul 7, 2022 at 3:06 PM
    #7956
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I agree :thumbsup:
  17. Jul 7, 2022 at 3:36 PM
    #7957
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Appreciate your thoughts and recommendation!
  18. Jul 7, 2022 at 3:36 PM
    #7958
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    :hattip:
  19. Jul 7, 2022 at 3:42 PM
    #7959
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I think I'd just clamp a cheap umbrella to the roof.
    There will be very little heat difference noted with a coating of paint, no matter the color.
    The pro mower guys fab up an electric fan to blow fresh air down on the operator to keep things tolerable.
  20. Jul 7, 2022 at 3:54 PM
    #7960
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
