Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Jul 15, 2022 at 6:22 PM
    #8161
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    If I have just a little bit of 2 stroke left in my can when I need to fill up the 5 gallon as well can I'll just dump it in the push mower. I always run Ethanol free 90oct and never had any issues...
    I used to dump the old snow blower gas in the truck, but I have stopped doing that once I got rid of my old truck...
    Reminds me, I have old 87 oct 10% ethanol gas in the snowblower tank. I ran the carb dry, but between moving and "renovating" I totally forgot it. Glad I live in the country and start a fire with itand can properly dispose of it :spy:
  2. Jul 16, 2022 at 4:36 AM
    #8162
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Looks like he had the heavy side downhill too, which is a big no no with offset tractors.
    wilcam47 and RustyGreen[QUOTED] like this.
  3. Jul 16, 2022 at 5:54 AM
    #8163
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    He knows that now. :oops:
  4. Jul 16, 2022 at 7:08 AM
    #8164
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Did you try Digikey? They're a great source for electronic components.
  5. Jul 16, 2022 at 10:09 AM
    #8165
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    I did not. I looked through the first couple of pages of google results until I found the cheapest identical replacement that I could find. ill add it to my list of suppliers though!
  6. Jul 16, 2022 at 1:16 PM
    #8166
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    I use 2 stroke gas in my generator for storage, non eth and the oil mix I’ve not had any issues with starting. Forgot to do same in pressure washer and the carb corroded. 8oz 50:1 mixed with regular non eth and have had no issues
  7. Jul 16, 2022 at 1:19 PM
    #8167
    Blkvoodoo
    Kevin
    Near Clayton NC
    Last night and this morning, neighbor had 20ton gated but it was thick, he called me after about 20min of hand shoveling.
    51D605C3-62AF-49F1-A1E6-851CA809E5F6.jpg 44DE98C6-3822-4F3E-BA8A-246B81736145.jpg 54FAA41F-A3B5-4F26-996B-A2600522FD15.jpg
    TacoLarn, JGO, Delta09 and 4 others like this.
  8. Jul 16, 2022 at 1:29 PM
    #8168
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Looks great :101010:
    RustyGreen likes this.
  9. Jul 16, 2022 at 1:38 PM
    #8169
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    man, that is the most manicured gravel driveway ive ever seen. great job on the finish work!
  10. Jul 16, 2022 at 2:38 PM
    #8170
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Bent part removed, straightened and welded in. Always a bit of a pain welding painted/rusted iron.
    Fortunately the new paint will cover a lot of sin PXL_20220715_200135585.jpg PXL_20220715_200149948.jpg
  11. Jul 16, 2022 at 2:41 PM
    #8171
    koditten
    Kirk
    Central Michigan
    Deck got it's 1st coat of paint.
    I used a needle scaler to remove all the loose rust and paint. I ran the wire wheel cup over everything else I could get the cup into. I'd say 90% of the surface was decently prepped for paint. The coat of paint sure brightens it up.PXL_20220716_201603530.jpg
  12. Jul 16, 2022 at 2:55 PM
    #8172
    Tacoma Mike
    Southern Maine
    And the answer is
    Needle scaler.
    Question
    How to piss off a dealership in 30 seconds..
    OMFG those things are horrible..
  13. Jul 16, 2022 at 3:08 PM
    #8173
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Looking good Kirk!
    RustyGreen and koditten[QUOTED] like this.
  14. Jul 16, 2022 at 3:43 PM
    #8174
    koditten
    Kirk
    Central Michigan
    I don't follow?
  15. Jul 16, 2022 at 3:47 PM
    #8175
    Tacoma Mike
    Southern Maine
    Oh dude.
    They are so fuckin noisy in certain situations you need ear protection.
    And the whole shop has to grab for it.
    And there is always someone trying to find a noise that shuts him down..
  16. Jul 16, 2022 at 3:50 PM
    #8176
    koditten
    Kirk
    Central Michigan
    I get you now. Yes, they are noisy pricks.
    I'm always with ear protection, so I don't mind it too bad.
    six5crèéd[OP] and RustyGreen like this.
  17. Jul 16, 2022 at 3:55 PM
    #8177
    Tacoma Mike
    Southern Maine
    It’s fine if your by yourself but trying to communicate with other techs
    Or the parts dept and on the phone to another dept sucks
  18. Jul 16, 2022 at 4:03 PM
    #8178
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    My dealership has been doin’ a Reno forever now. Noisy AF & you don’t even get to see the parts dept. anymore. :facepalm:
  19. Jul 16, 2022 at 4:09 PM
    #8179
    Jesse
    Poulsbo
    15' DCSB OR S/C
    picture a tattoo needle on roids vibrating metal. its as awful as a recip saw on steel. insanely loud. kinda like my ex when i didnt do something correct.
  20. Jul 16, 2022 at 4:09 PM
    #8180
    FastEddy59
    Eddie
    While I was lookin for it I came across the Showroom. Completely empty except for a desk, computer & a sales guy. So he asks “Can I help you?”. I said “Finally somethin’ I can afford”. :laughing:
