Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Jul 18, 2022 at 5:54 AM
    #8261
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    When I was doing my internship with the Park Service, my crew boss used one of those Stihl brush cutters with a blade similar to hack down an 8" round tree. He just hacked at it like a beaver and it took it down probably faster than a chain saw. You need a chain saw style helmet with the mesh face shield with one of those. They'll throw some chips in a hurry.
    Those who use a mulcher/chipper, what would you say is the justification for using that versus burning debris and then buying truck loads of mulch? I can get a yard of good natural cypress mulch for $53. I would need to get 30 yards of mulch out of the chipper to get the same volume/cost and it would just be lower quality woods and not cypress.
    RustyGreen and six5crèéd[OP] like this.
  2. Jul 18, 2022 at 6:00 AM
    #8262
    toysrgood
    SC
    2011 4x4 Reg Cab
    I am in SC too. Let me know!
  3. Jul 18, 2022 at 6:00 AM
    #8263
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I don't want a chipper to make mulch, I want one just to get rid of all the tree limbs that fall out of our large oaks after every storm.
  4. Jul 18, 2022 at 6:01 AM
    #8264
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Making mulch the hard way! Biggest stump ground to date.
  5. Jul 18, 2022 at 7:19 AM
    #8265
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I really do need to buy a trailer, but it's not in the budget right now. :pout:
    And the mower ran fine after all my investigation. Weirdest thing...
  6. Jul 18, 2022 at 8:15 AM
    #8266
    Tacoma Mike
    Southern Maine
    Did you happen to shut it right off when you were done? Like full hi rpm shut off?
    I usually let mine idle for like 30 seconds before shut down. Gets rid of a little heat.
  7. Jul 18, 2022 at 8:18 AM
    #8267
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Nah, I kinda half throttled it to the front of the house by the garage. It might be a fuel delivery issue possibly, but taking the carb off this twin is kind of a PITA. Gonna have to grind down a sacrificial wrench to get the bottom shut off solenoid off. I'll keep an eye on it. I always use fresh ethanol free gas, but you never know a piece of dirt coulda got somewhere. Only takes a minute spec to get in one of the small ports.
  8. Jul 18, 2022 at 8:24 AM
    #8268
    Tacoma Mike
    Southern Maine
    Yea.
    Fixed many with a piece of wire.
    RustyGreen, JGO and six5crèéd[OP] like this.
  9. Jul 18, 2022 at 12:06 PM
    #8269
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    well the capacitor fixed my well pump! then the magic smoke started and shes not looking good anymore.
    six5crèéd[OP] and w.adventures like this.
  10. Jul 18, 2022 at 12:18 PM
    #8270
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Convenience.
    Burning takes a lot of time and is frequently banned by the County during dry season.
    A 1/2 hour with the chipper can make a big mess disappear.
    I don't really care about the quality of the mulch it just goes around the trees or in the hedgerow.
    six5crèéd[OP] likes this.
  11. Jul 18, 2022 at 12:22 PM
    #8271
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Sorry to hear this.
    The original problem occurred when you were on vacation, no telling how hot the motor got and for how long.
    It could have been already doomed.
    As long as the pump spins freely a plumbing supply house should be able to get you a new motor.
  12. Jul 18, 2022 at 12:23 PM
    #8272
    jpneely
    Charleston, SC
    yea true. she worked fine for about 45 seconds. had my hopes up then poof. up in smoke. Thank yall for yalls help so far!
  13. Jul 18, 2022 at 1:02 PM
    #8273
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Got my finishing mower blades fixed this weekend. The middle blade came loose just enough to free spin on the shaft. The washer was crushed and the nut was seriously buggered up. My big impact had a tough time getting it off. The nut looks like it cross threaded on the shaft.F98F66EE-DB37-4B96-8BFD-3F4C6A40D01C.jpg6A060B84-793B-47D1-B0E0-9EB97DD88A55.jpg
    The shaft was okay so I was able to get a new nut and washer. All the blades were a bit bent out of shape. So I ordered new ones. Hopefully I can bend the old blades back in to the correct shape. :fingerscrossed:0EFEA236-B81F-49B3-B9F2-D53BBA663F19.jpg
  14. Jul 18, 2022 at 2:24 PM
    #8274
    w.adventures
    Nowheresville, SC
  15. Jul 18, 2022 at 2:41 PM
    #8275
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    id get goats but keeping them safe is tough. bobcats are large here, the coyotes are bigger than any dog around, and the cougar can kill them with one swing. fortunately the bear only show up for the blackberries.
  16. Jul 18, 2022 at 2:43 PM
    #8276
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :infantry::infantry::infantry:
  17. Jul 18, 2022 at 2:48 PM
    #8277
    Jesse
    Poulsbo
    15' DCSB OR S/C
    im essentually just wanting a vast quantity of brush to go away. wet most of the year here so decomp happens quick. id have to haul all of it quite a distance to safely burn. if not i risk something lighting back up when im sleeping or at work. last 2 summers burn bans prohibit any fires. chipper runs safe wet or dry year round. my wooden nickel of thought.
  18. Jul 18, 2022 at 2:51 PM
    #8278
    Jesse
    Poulsbo
    15' DCSB OR S/C
    they are incredibly stealth. only seen them on cameras. not totally opposed to blast one, but at 3am my neighbors would be:censored:ing pissed.
  19. Jul 18, 2022 at 2:52 PM
    #8279
    wilcam47
    Will
    Bourbon state
    Yeah ive hunted bear, they are sneaky as hell.
  20. Jul 18, 2022 at 2:55 PM
    #8280
    Jesse
    Poulsbo
    15' DCSB OR S/C
    kinda the opposite here. black bear snapping braches wandering around munching. last year at my neighbors kids b-day big male walked right down the diveway with no regard to the gokart racing. spooky. the cats are like ninjas
