Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    46.7%
  2. After
    56.7%
  3. Neither
    13.3%
  4. I weed whack while someone else mows
    6.7%
Multiple votes are allowed.
  1. Jul 20, 2022 at 6:25 PM
    #8321
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Here is mine, still need a throttle cable for it. Or is there a place to buy just a throttle cable cap end?
  2. Jul 20, 2022 at 6:33 PM
    #8322
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Are you sure that's a throttle cable? Mine just had a safety cable running from the safety bar to the engine.
    These mowers were full throttle or nothing.
    RustyGreen and six5crèéd[OP] like this.
  3. Jul 20, 2022 at 6:40 PM
    #8323
    w.adventures
    Nowheresville, SC
    Yep, does choke, rabbit and turtle
  4. Jul 20, 2022 at 6:44 PM
    #8324
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    good idea if the area is what it can do.
  5. Jul 20, 2022 at 6:47 PM
    #8325
    koditten
    Kirk
    Central Michigan
    Thanks for the response. Mine are a bit older. It's all or nothing. Lol.
  6. Jul 20, 2022 at 6:58 PM
    #8326
    w.adventures
    Nowheresville, SC
    I wouldn’t mind all or nothing! Seriously who uses a mower at slow speed?
  7. Jul 20, 2022 at 7:04 PM
    #8327
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
  8. Jul 21, 2022 at 3:36 AM
    #8328
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    That is sweet!
    RustyGreen and wilcam47 like this.
  9. Jul 21, 2022 at 6:06 AM
    #8329
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    A couple of years back, my daughter bought a house with a relatively small yard. I got her and "EGO" mower, she hates gasoline, pulling to start and all that other icky stuff. She has used it a since and will not got to gasoline. She bought several other of their tools and uses the same battery of them.
  10. Jul 21, 2022 at 6:41 AM
    #8330
    My Name is Rahl
    Home built jobby?
  11. Jul 21, 2022 at 7:05 AM
    #8331
    w.adventures
    Nowheresville, SC
    @koditten more that I thought about it I am sure I could jerry rig a throttle stop that pulls out a little way for choke and then when pushed in its at full speed only.
  12. Jul 21, 2022 at 1:48 PM
    #8332
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Two chippers at tractor supply.
  13. Jul 21, 2022 at 1:55 PM
    #8333
    Toyko Joe
    Toyko Joe Here for the pictures
    If you can avoid direct drive chippers. My $0.02.
  14. Jul 21, 2022 at 1:59 PM
    #8334
    w.adventures
    Nowheresville, SC
    Did you buy the DR one? Come on over, I have beer waiting :cheers:
  15. Jul 21, 2022 at 2:02 PM
    #8335
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Nope!
    RustyGreen likes this.
  16. Jul 21, 2022 at 2:16 PM
    #8336
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    six5crèéd[OP] likes this.
  17. Jul 21, 2022 at 2:22 PM
    #8337
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I had a 1970s model with a primer bulb, no choke, it had a lever down on the carb marked: Low -- High
    It would burble happily along on the low setting through just about anything.
    An older fellow drove about 100 miles round trip to buy it not running, he seemed delighted to get it.
  18. Jul 21, 2022 at 2:28 PM
    #8338
    koditten
    Kirk
    Central Michigan
    Sounds exactly like the one I have sitting beside my shop. Broke pull starter. Never got around to fixing it.
  19. Jul 21, 2022 at 4:00 PM
    #8339
    Jesse
    Poulsbo
    15' DCSB OR S/C
    unless you need ultra light duty i wouldnt consider the small one. over buy for your need as they all over promise for sales.
  20. Jul 21, 2022 at 4:03 PM
    #8340
    Jesse
    Poulsbo
    15' DCSB OR S/C
    mine does the task fine for my needs but if money wasnt a factor id but a bigger one. getting a huge pile ready is key to save time, gas, and pulls getting it started.
