Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    46.7%
  2. After
    56.7%
  3. Neither
    13.3%
  4. I weed whack while someone else mows
    6.7%
Multiple votes are allowed.
  1. Jul 21, 2022 at 4:07 PM
    #8341
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    my only complaint(s) about dr chippers is the weak welds on the heat shield (tore off) and their website is crap for parts orders. you have to call to get anything sent.
    JGO and six5crèéd[OP] like this.
  2. Jul 21, 2022 at 4:32 PM
    #8342
    Jesse
    Poulsbo
    15' DCSB OR S/C
    this is george jetson stuff
    six5crèéd[OP] likes this.
  3. Jul 21, 2022 at 5:31 PM
    #8343
    SCOTT'S TACO LOCO
    SCOTT'S TACO LOCO Orange It.
    Scott
    San Antonio, Tx
    08 Toy-yo-duh TACO TRD
    Its been a busy week, looks like I have few pages to comb through.
    Please Like, Subscribe and Share! Thanks!
    https://youtu.be/8EiBe4cdCU8
  4. Jul 21, 2022 at 5:32 PM
    #8344
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    get a PTO chipper for the tractor!
  5. Jul 21, 2022 at 6:18 PM
    #8345
    Jesse
    Poulsbo
    15' DCSB OR S/C
    if i ownned a tractor yes on that band wagon. more power =less time spent.
  6. Jul 21, 2022 at 6:25 PM
    #8346
    Toyko Joe
    Toyko Joe Here for the pictures
    I had one of these when I had some property 12hp belt driven drum chipper. It was perfect for chipping anything that wasn’t firewood size. Miss this old girl sometimes.
  7. Jul 21, 2022 at 6:40 PM
    #8347
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
  8. Jul 21, 2022 at 8:15 PM
    #8348
    Jesse
    Poulsbo
    15' DCSB OR S/C
  9. Jul 21, 2022 at 10:57 PM
    #8349
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Been a while on here. Tractor has 242 hours now...so relatively new still. :D
    Anyone use a three point pallet fork?
    https://www.agrisupply.com/pallet-forks/p/72511/
    The reason is to pick up large boulders that I normally can't with my FEL. I can lift 1900 lbs on the 3 point and only 1050 lbs on the FEL.
    wilcam47 and six5crèéd[OP] like this.
  10. Jul 22, 2022 at 3:32 AM
    #8350
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    My dad used a set for years to move round bales :thumbsup:
    wilcam47 and ColoradoTJ[QUOTED] like this.
  11. Jul 22, 2022 at 3:52 AM
    #8351
    ColoradoTJ
    Colorado
    I’m thinking this might be the way to go. 2000 lb rating should get me close to what I need.
  12. Jul 22, 2022 at 5:08 AM
    #8352
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  13. Jul 22, 2022 at 5:09 AM
    #8353
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  14. Jul 22, 2022 at 5:10 AM
    #8354
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Thanks, now to clean the wheels and spray them and get the floor in.
  15. Jul 22, 2022 at 6:01 AM
    #8355
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
  16. Jul 22, 2022 at 6:21 AM
    #8356
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    I went and picked up a new chicken coop last weekend. It was 45 minutes one way, and I stopped at TSC and Lowes for materials. Ten minutes from home, the ball mount came out of the receiver tube and the shock load bent the hooks on my safety chains. The entire trailer was completely disconnected from the truck. Thankfully I was going downhill on an overpass and the trailer rammed into the back of my truck instead of going on its own path. I had picked up some 2x4's and those were poking out over my tailgate. The coop hit the 2x4s and completely prevented any contact damage between truck and trailer. The coop had a few scuffs but otherwise unscathed. I hit the brakes and was able to control and slow the trailer to a stop.
    Thankfully I had a spare pin in the truck. I have no clue what happened to the pin that was in there. I drove 80 miles round trip on the highway, through town and bumpy dirt back roads and at the end of the trip suddenly there is no pin.
    Only damage is to the ball. I already got new safety chains, drop hitch ball mount, and ball.
    Thankful for the outcome considering the situation. Thankful there wasn't any substantial damage to my equipment or others. In disbelief yet humbled that this even happened to me.
    I am always pretty careful when towing. I check tires, chains, straps, hitch, etc constantly. I stopped and adjusted the straps on the coop 4 times before I was confident that it was secure. Mainly the small strap I had going over the top to prevent shingles from lifting and flapping in the wind. Odd shaped loads are pretty hard to get right and can shift pretty easy. This was a hefty reminder to be even more stringent on my checks.
    Screenshot_20220716-131201_Chrome.jpg 20220716_132643.jpg received_450085393363290.jpg
    For reference, I am not a newbie at towing but not a pro either. I towed daily at low speeds in the Air Force. Anything from 20k equipment to 500lb equipment, daisy chained 4 long or even 2x2. The truck had three hitches, one in the middle and two outside so I could tow two pieces on each outside hitch at a time. I also towed a 35' gooseneck for a year all around the state for construction projects. I had all sorts of wonky equipment strapped to that thing like welding tables, pipe stands, crates, job boxes, etc. Never an incident.
  17. Jul 22, 2022 at 6:24 AM
    #8357
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    RustOleum Red :thumbsup:
  18. Jul 22, 2022 at 6:25 AM
    #8358
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Dang, bet that was scary.
    I would to see more pics of the coop, inside pics too.
    RustyGreen and six5crèéd[OP] like this.
  19. Jul 22, 2022 at 6:26 AM
    #8359
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Dang! Glad you or anybody else didn't get hurt, stuff happens!
    RustyGreen likes this.
  20. Jul 22, 2022 at 6:36 AM
    #8360
    toysrgood
    SC
    2011 4x4 Reg Cab
    I also now realize that those safety chains are vastly under sized for the trailer. The 2,600lb safety chains I got are much more beefy than the old ones.
    Me too, that could have gone way worse than it did.
    I'll see what I can do. It is 4'x4' with 12" of one side being the laying boxes. DIY built by a tradesman who wanted a hobby and I picked it up from marketplace. It seems to be pretty well done. A few little things I'd do different but the price was nice.
