Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Aug 8, 2022 at 10:24 AM
    #8561
    SCOTT'S TACO LOCO
    SCOTT'S TACO LOCO Orange It.
    Scott
    San Antonio, Tx
    08 Toy-yo-duh TACO TRD
    The holes in this grapple attachment does not offer enough protection to my Oranges, I had the neighbors ranch hand add some heavy plate to block the holes.
    20220721_122538.jpg 20220721_122601.jpg 20220721_122737.jpg 20220721_122745.jpg
    Fixed
  2. Aug 9, 2022 at 5:38 AM
    #8562
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
  3. Aug 9, 2022 at 6:07 PM
    #8563
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    It seems that hooptie lawn tractor wants to mess with me, and it was winning last night. it was a really hard start followed by on/off rough running. Maybe the left over 2 stroke gas didn't mix too well with the fresh 91 octane that went into the tank. Anywho, about 1/2 way done with the back yard and it just shut off. No starting, not even turning over. I raised the seat and gave the stupid sensor a good smack and it cranked over. It restarted, so I go to engage the lever to make the blade spin and it shut off, no cranking. I put the lever back into the "not spinning" position, it cranked and started, stalling as soon as I moved the blade engagement lever. I popped the hood, removed the gas tank to reach the stupid switch, pulled off the harness and made some jumper wires from paper clips.
    The 1st attempt I must have got the jumpers wrong because as soon as I turned the key, I heard the distinctive "pop" sound of a fuse...
    I cooked a 20 amp fuse. I spent the next 45 minutes trying to find the 200 count pack of fuses that I KNOW that I own.. it's not where it's supposed to be and I have no idea where I moved them to, so I used the emergency 150 amp fuse...:eek:
    I wasn't crazy about doing this, but I was determined to get the back yard finished. It started and ran good enough to finish the back yard in total darkness, the whole time while I'm cursing this piece of shit..
    I get home today with a new box of fusesI get a new 20 amp'er in there, and decided to raise the gas tank a bit to help with the gravity feed, as the kohler in there has a carb that sits much higher then the Briggs that once resided under the hood. It seems to help little bit.
    It will still starve on a really off angle side hill cut. Maybe I need an electric fuel pump to help out. I really don't want to spend much more time squeezing more life out of this turd.
  4. Aug 10, 2022 at 6:51 AM
    #8564
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    @Steve Urquell haven't seen you around lately, hope everything is all right. :fingerscrossed:
  5. Aug 10, 2022 at 4:02 PM
    #8565
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Thank you sir. Been nice chatting with you boys. Catch me on mytractorforum. Peace!
  6. Aug 10, 2022 at 4:28 PM
    #8566
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
  7. Aug 10, 2022 at 4:38 PM
    #8567
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Anyone thinking about a cheaper stump grinder for your tractor, check out the woodland mills wg24. I had 2 large maple stumps that were at least 5’, and it probably took about 3 hours to get rid of them. I used a backhoe before, and it leaves a mess to clean up when your done.
  8. Aug 10, 2022 at 5:51 PM
    #8568
    My Name is Rahl
    Porta-john?
    six5crèéd[OP] and RustyGreen like this.
  9. Aug 10, 2022 at 5:58 PM
    #8569
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Is that your sleeping quarters or shitting quarters?
  10. Aug 10, 2022 at 6:03 PM
    #8570
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Deer blind.
  11. Aug 10, 2022 at 9:38 PM
    #8571
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Okay, so a bit of both... :anonymous:
    RustyGreen and six5crèéd[OP] like this.
  12. Aug 10, 2022 at 10:33 PM
    #8572
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Now that you bought more fuses, did you find the ones you already had?
  13. Aug 11, 2022 at 4:26 AM
    #8573
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I built one on an old trailer frame several years ago, works like a champ and easy to move.
  14. Aug 11, 2022 at 4:26 AM
    #8574
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Delta09 and toysrgood like this.
  15. Aug 11, 2022 at 4:34 AM
    #8575
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Nice! I built it on a trailer so I could move it around. I no longer have to move it or relocate it, or mess with any deer lease or family land drama BS anymore, cause I bought my own farm.
  16. Aug 11, 2022 at 1:31 PM
    #8576
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    anyone have a recipe for fixing wallered out wheel bolt holes. I just found these and am kinda annoyed I never saw it earlier.
    56DHNQr795AAEzQ0vjzphqiAQ4CgUUqrTJImlcfc_5c41a94dc1b52f7b245e647ccbdd24d79e2d4958.jpg
  17. Aug 11, 2022 at 1:38 PM
    #8577
    RustyGreen
    sleeping in a chair
    Pavement Princess
    That looks like a lot of labor to do a decent fix... :mad:
    I would probably take the lazy way and replace it.
  18. Aug 11, 2022 at 1:44 PM
    #8578
    My Name is Rahl
    Add some hot glue and a plate and re-drill the hole?
  19. Aug 11, 2022 at 1:46 PM
    #8579
    koditten
    Kirk
    Central Michigan
    I'm leaning towards finding some extra thick 1/2" washers, running the nuts down on them then welding the washers to the wheel.
    Never done it before, so appreciate any feed back.
  20. Aug 11, 2022 at 1:50 PM
    #8580
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That was my first thought but it’ll prob wear fast and groove the bolt as well.
    wilcam47 likes this.
