Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Aug 13, 2022 at 6:57 AM
    #8621
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
  2. Aug 13, 2022 at 6:59 AM
    #8622
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :rofl:
  3. Aug 13, 2022 at 7:00 AM
    #8623
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    More like 1-2 days after the standard 6 year warranty...
    I know mine won't last much longer than the warranty. I'm on softened well water and it's already making the hot water smell funky. I can tell when I get home and shower if nobody has been using much hot water during the day. I know there's special anode rods for this, just haven't put the effort into it yet :laugh:
  4. Aug 13, 2022 at 7:08 AM
    #8624
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    AO Smith used to be a decent brand, till they branched out into the big box market. Mine is an AO and it definitely ain't what they use to be, as pictured here, cheapened out on some things...
  5. Aug 13, 2022 at 7:08 AM
    #8625
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Agreed
  6. Aug 13, 2022 at 7:22 AM
    #8626
    My Name is Rahl
    I paid extra for a Rheem instead of AO Smith for that reason. Had a Home Depot contractor install it, and I would definitely do that again.
    I had a 40 gallon that was 12 years old. Bought a 50 gallon and with installation, it was $1,500.
  7. Aug 13, 2022 at 7:54 AM
    #8627
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I always save receipts -- actually finding them is something we won't mention...:annoyed:
  8. Aug 13, 2022 at 7:55 AM
    #8628
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Lots of good info here: https://www.waterheaterrescue.com/
    @Delta09 info on smelly water anode:
    https://www.waterheaterrescue.com/troubleshooting/smelly-hot-water.html
  9. Aug 13, 2022 at 7:57 AM
    #8629
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I haven't looked at local plumbing supply places yet, but if the prices are similar to what I've seen online. I'll probably end up with an HD or Lowes 40 gal. I'll do my own installation, which will save me some money. I think I can get by for about $500 + the cost of some better valves. :pray:
  10. Aug 13, 2022 at 8:00 AM
    #8630
    wilcam47
    Will
    Bourbon state
  11. Aug 13, 2022 at 11:27 AM
    #8631
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    Yea that’s the one I’m going to get. It’s weird that the ao smith manual I was looking at said my heater took a 16” one. I didn’t figure that was really correct but figured the heating elements got in the way of a longer one or something so I just got a short one. Should have followed my gut. I don’t guess my heaters going to last through another anode though. I was eying up the rheem platinum one on HDs website. Not sure I can do an install myself, but at pay if I do and I spring a leak it’s in the garage and not my attic
  12. Aug 13, 2022 at 11:38 AM
    #8632
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    There are plenty of how-to videos on YT. If the location is easy to get to, like in your garage, installation is not very complicated. The water tanks don't weigh very much when they are empty. I installed my first one before YT was a thing. I would certainly encourage you to watch some videos and try to do it yourself. Plumbers are expensive!
  13. Aug 13, 2022 at 11:43 AM
    #8633
    jpneely
    Charleston, SC
    Yea it’s location makes replacement stupid easy. I’ve just never soldered copper pipe before. I’ll do some practice ones first haha
  14. Aug 13, 2022 at 11:45 AM
    #8634
    RustyGreen
    sleeping in a chair
    Pavement Princess
    As long as the pipe is clean and dry with a good fit up soldering is quite easy.
    Do a few practice parts and you can learn quick.
  15. Aug 13, 2022 at 2:56 PM
    #8635
    My Name is Rahl
    Soldering is easy, just be sure you get plenty of flux on the pipe.
  16. Aug 13, 2022 at 4:08 PM
    #8636
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I would not solder the pipes. I would get some flexible pipe and a shark bite fittings. Cut back how ever much of the house pipes is necessary to make room for the SB flitting and new flexpipe. I want to be able to use a wrench to put the heater in and if necessary take it out.
    six5crèéd[OP] and 308savage like this.
  17. Aug 13, 2022 at 5:06 PM
    #8637
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You fuckers just ain't right!
    Funny, but twisted.
    Can't wait until the next random shit pops up.
  18. Aug 13, 2022 at 5:10 PM
    #8638
    koditten
    Kirk
    Central Michigan
    Little known fact:
    Plumbers in the past were paid hourly.
    They like sweating copper because it takes longer.
    It's not rocket science, but it is easy to burn down the house.
    Today's compression fittings and crimped fittings are more popular since you don't have an open flame...and most plumbing jobs are bid by the job.
    As well they are just as reliable as a sweated fitting.
  19. Aug 13, 2022 at 8:38 PM
    #8639
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I replaced most of the plumbing valves to my sinks and toilets when I moved into my house. As virtually every one of the valves was stuck open. I sawalled them off and replaced them with shark bite fitted 1/4 turn ball valves. Was way simpler than soldering pipe. Soldering might be cheaper, but I don't think it's worth the hassle.
  20. Aug 14, 2022 at 9:57 AM
    #8640
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Anyone here run a PTO driver stump grinder? Looking at a Woodland Mills stump grinder this week for the Kubota
    six5crèéd[OP] likes this.
