Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Aug 16, 2022 at 12:25 PM
    #8661
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    I’m just going to have to chop and swap. Talked to a couple of motor shops and they basically said it’s cheaper to replace the whole pump instead of rebuilding it. Just gotta figure out which pump to go with. I still don’t want to drop $900 on a not very important pump.
  2. Aug 16, 2022 at 12:47 PM
    #8662
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    If it's something not that important, you can pick up a shallow well pump for $200-$400 easily... Hell a fancy Zoeller is under $500.
  3. Aug 16, 2022 at 12:50 PM
    #8663
    jpneely
    Charleston, SC
    Everywhere I was looking was saying shallow well was considered 25’ or less, mines sitting at 33’ so I’d still need at least a deeper rated one. I’ll keep looking around.
    six5crèéd[OP] and RustyGreen like this.
  4. Aug 16, 2022 at 1:05 PM
    #8664
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    33' is a little over 14 psi head pressure it will have to overcome.
  5. Aug 16, 2022 at 2:44 PM
    #8665
    My Name is Rahl
    Geez. If 33' is considered a deep well, I wonder what the 221' well we had at the last place would be considered.
    Delta09, RustyGreen, wilcam47 and 2 others like this.
  6. Aug 16, 2022 at 2:57 PM
    #8666
    jpneely
    Charleston, SC
    Lol yea I thought 25 was a pretty shallow depth. Ours back home growing up was really deep too
  7. Aug 16, 2022 at 3:07 PM
    #8667
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    If you can get the tractor up to the stump, the woodland mills wg24 will remove any stump. I used one about a week ago. 3 maple stumps from 20” to about 6’. Biggest stump took about 2 hours.
  8. Aug 16, 2022 at 3:12 PM
    #8668
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Subterranean :notsure:
    :p
  9. Aug 16, 2022 at 3:19 PM
    #8669
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I just priced everything out from the big box stores. A new 40-gallon WH will be about $640 for everything, including new valves, drop lines, fittings, and a couple of new tools to make the job easier for the DIY install. Someday I'd like to replace all the 1/2" lines in the house with 3/4 pex, someday, so the tools should be useful again...
  10. Aug 16, 2022 at 3:50 PM
    #8670
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    We re-piped our house from 1/2” galvanized to 3/4” copper. I honestly thought I’d notice more of a difference than I do. Turning up the well pump was the biggest difference maker for us water pressure wise under heavy use
  11. Aug 16, 2022 at 4:01 PM
    #8671
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    The biggest reason I want to upsize the pipes is not having enough water pressure/flow to use two fixtures at the same time. It's not a huge issue being here by myself, but when company is over there isn't enough pressure/flow for two showers or a shower and a toilet. I have plenty of pressure coming to the house on a 2" mainline, then 3/4" for about 20' to the hot water heater, but imeadiatly after that, it drops to 1/2".
  12. Aug 16, 2022 at 4:05 PM
    #8672
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Have you got a pressure regulator in the house you can adjust?
    six5crèéd[OP] likes this.
  13. Aug 16, 2022 at 4:06 PM
    #8673
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I don't like to make company too comfortable, just sayin'... ;);)
  14. Aug 16, 2022 at 4:16 PM
    #8674
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    That’s the same issue we had too. Sucked taking a shower while she was filling the coffee pot and rinsing her dish in the morning! The piping upsize helped some for sure but not near as much as going up to 60psi on the well pump
  15. Aug 16, 2022 at 6:08 PM
    #8675
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    95.67psi head pressure :eek:
    :rofl:
  16. Aug 16, 2022 at 6:12 PM
    #8676
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Did you happen to look at any of the galvanized you cut out? I've seen that stuff so corroded inside that you couldn't see through a 2 foot stick. Just a pinhole meandering through the rust and corrosion. Galvanized was a bad idea for water.
    six5crèéd[OP] and KRAMERICA like this.
  17. Aug 16, 2022 at 6:14 PM
    #8677
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    My well sits on about 65PSI all the time...
    Only because the pressure gauge is broken... :anonymous:
  18. Aug 16, 2022 at 6:17 PM
    #8678
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    My house in Washington was like that. I replaced a bunch of 1/2" galvanized pipe with PEX. Virtually every piece I pulled out had severe blockages, it was probably more like having 1/4" pipe on the inside.
  19. Aug 16, 2022 at 6:54 PM
    #8679
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    It was shockingly not bad but there were only sections of it left, the rest was 1/2” copper so I presume there were some blockages at some point.
    Back in tractor related news, I think I’m going to start on my pistol range in the corner of the property next week. I’ve got some old old wood that’s sat outside for too long so I’m going to move the pile and cover with dirt to use as a backstop….after I clear out a shit ton of overgrowth and small trees
  20. Aug 16, 2022 at 7:06 PM
    #8680
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Bought one today secondhand off Craigslist. Looks to be in fantastic shape. Very excited to put it to work soon. I’ll reach out if I have any specific questions.
