Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Aug 16, 2022 at 7:12 PM
    #8681
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Got any railroads near you?
    This is my backstop.
  2. Aug 16, 2022 at 7:16 PM
    #8682
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Awesome. That’s the impression I got from reviews.
    six5crèéd[OP] likes this.
  3. Aug 16, 2022 at 7:23 PM
    #8683
    Clark27
    Springfield, MA
    2015 Lexus GX460
    I do need to upgrade my stabilizer stay chains for my 3 point. Any recommendations?
  4. Aug 16, 2022 at 7:24 PM
    #8684
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I do and I’ve definitely considered something similar with the ties. No idea where to get them for free/cheap though?
    six5crèéd[OP] and KRAMERICA like this.
  5. Aug 16, 2022 at 7:31 PM
    #8685
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    RR ties, tires and dirt are some of the best building blocks for a private range.
  6. Aug 16, 2022 at 8:54 PM
    #8686
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    They replace them every few years and leave the old ones alongside the tracks at least for a while.
    Might need permission to be on railroad property.
    I have a friend that works for the railroad and we got hundreds for various projects.
  7. Aug 17, 2022 at 3:04 AM
    #8687
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    I need a tractor for residential use, I have 1.5 acres. Need to move some logs, dirt, light bush hogging, gravel work. Etc etc.
    Can anyone recommend specific models to me?
  8. Aug 17, 2022 at 3:13 AM
    #8688
    Tacoma Mike
    Southern Maine
    Is this were I’m suppose to say
    “ Couldn’t hit the broadside of a barn?”
  9. Aug 17, 2022 at 4:17 AM
    #8689
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Any of the brand names are good these days, John Deere, New Holland, Kubota, Kioti, Mahindra, etc. Do you have any tractor places near you? That may help narrow it down since you could go there and get filters and parts if needed. But then again you can order almost anything these days so there's that.
    I will say get something a little bigger than you think you'll need, you'll use the extra HP and weight more than you think :thumbsup:
  10. Aug 17, 2022 at 4:20 AM
    #8690
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I have this kind, they are awesome. Easy to just put the pin in to lock them in position or remove the pin for free swinging.
    Fmt3V8Oet7_brke2gyu9owGJUy1deTlYmxNCLOJA_6ce0415410089124ddab967ba7201532ed27e7b2.jpg
  11. Aug 17, 2022 at 4:20 AM
    #8691
    Tacoma Mike
    Southern Maine
    THIS 100%……
  12. Aug 17, 2022 at 6:20 AM
    #8692
    Clark27
    Springfield, MA
    2015 Lexus GX460
    That looks great. I need to look closer though since the B series Kubota has them on the inside of the arms and not the outside.
  13. Aug 17, 2022 at 6:26 AM
    #8693
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Yeah that may cause a problem, they are bulky.
  14. Aug 17, 2022 at 6:33 AM
    #8694
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I'd start with what dealers are near you and then look at their subcompact line of tractors. More HP is better than less. With most manufacturers, you can get up to 25hp in the subcompact line, that's under the emissions limit for tractors. Be sure to get a loader; I'd also get a box blade, 4'-5' brush hog, and a 54"-60" mower deck. With all of that, you can easily maintain just about anything. If your wallet can afford it, get the model with all the bells and whistles on it. Like rear remotes, hydraulic top link, telescoping stabilizers like six5creed has, extendable lower links. I'm sure there are others I'm not thinking of, Ask Tractor Mike has a good video on some of the better ones to look for. Tractor time with Tim also has a good playlist for new tractor buyers.
    https://youtu.be/llPOKFaZOvg
    https://youtube.com/playlist?list=PLuUZ6lo0MDxB-YUhHCCEvakr5C4ELI-3F
    You could say that, but you can.:( My Gen 1 backstop was just two layers of RR ties. After I started inviting other friends over to shoot and two .30 cal bullets appeared lodged in the side of the barn. I built the Gen 2 backstop, which is why it is now 3x wider and 4x deeper than the first generation wall. You really have to miss BIG to hit the broadside of the barn now... :D
    Those are the same type I have, they are so much better than a turnbuckle. :thumbsup:
  15. Aug 17, 2022 at 7:51 AM
    #8695
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    To expand a bit more on why to choose a dealer closer to you than to say just go buy a Kabota or John Deere because they are the biggest manufacturers of tractors. If the dealership you buy from is 200 miles away and you need service from them for anything, you have to be able to get your tractor to the dealership for that service. The dealerships will come to get your tractor for you if you don't have the truck and trailer to haul it yourself, but most of them charge $2+ per mile. So if you have a warranty claim repair with that dealer that is 200 miles away, it could still cost you $400+ in transportation costs for that warranty service. If you instead bought a Kioti or New Holland that is only 20 miles away, any service needs would be much easier to obtain. I wouldn't buy a tractor just based on how close or far they are to me, but it would be a factor to consider. In 4 years of ownership, I've had to take my tractor to the dealership once and had the service tech come to my place to read the codes twice, and my dealership is about 20 miles one way. All of my service issues turned out to be fuel related. So if you like the JD way better than the Kabota, but it's an extra 50 miles away, I'd get the JD, but I'd also figure out which of my friends had a truck and trailer I could borrow if I didn't already own one myself.
  16. Aug 17, 2022 at 10:59 AM
    #8696
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    Well im not exactly liking the looks of my boats spark plugs. (are we adding boats to the title too?) 2-stroke v6 Yamaha. they've been in there 2 years maybe? we don't get to use her as much as we used to so I figured 2 years wouldn't hurt. every single terminal tip was loose except one. I didn't change them myself last time.
  17. Aug 17, 2022 at 11:02 AM
    #8697
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Why not :rolleyes:
    RustyGreen and jpneely[QUOTED] like this.
  18. Aug 17, 2022 at 11:04 AM
    #8698
    jpneely
    Charleston, SC
    :D
  19. Aug 17, 2022 at 1:56 PM
    #8699
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I found an old rim with the same bolt pattern. I plasma cut the center out of the old, good rim.
    I used this new center as a template to cut out the bad wheel center.
    six5crèéd[OP] and RustyGreen like this.
  20. Aug 17, 2022 at 2:05 PM
    #8700
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    o_O Would not run on my trailer. Sometimes it’s best to buy a new wheel.
