Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Sep 4, 2022 at 6:51 PM
    #8921
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Sketchy. If you(he)sold the item take your add down!
    six5crèéd[OP] likes this.
  2. Sep 4, 2022 at 6:53 PM
    #8922
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    For that machine at that price he was probably inundated with messages.
    six5crèéd[OP] and wilcam47 like this.
  3. Sep 5, 2022 at 5:40 AM
    #8923
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    Getting a little over an acre of my property manageable with the new tractor. Burn pile going strong20220905_070127.jpg
    Also with some help
  4. Sep 5, 2022 at 6:52 AM
    #8924
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Put the kids to work with the tonka truck picking up mockernuts. We have plenty of hickory now that needs to be split and I need to test out my Alaskan mill. Would love a bob cat to move everything around but a cant hook and some physical labor works. The lumberjack workout program gets you in shape!
  5. Sep 5, 2022 at 7:04 AM
    #8925
    wilcam47
    Will
    Bourbon state
    What are mocker nuts?
  6. Sep 5, 2022 at 8:24 AM
    #8926
    w.adventures
    Nowheresville, SC
    Big nuts that squirrels liked throwing the husks at us whenever we walked under the tree. Found this online about using them in the smoker so looking forward to giving it a go.
    “I have been using whole hickory nuts to smoke meats for over 30 years. A coworker brought me some in 1983 as I did not even know what hickory nuts looked like.
    I used them and found the smoke flavor was sweeter than with wood chips. Ribs especially are blackened with smoke, not burned and most folks who have tried them like them without any bbq sauce.”
  7. Sep 5, 2022 at 8:28 AM
    #8927
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    You vs. the guy she told you not to worry about :rofl:
  8. Sep 5, 2022 at 8:37 AM
    #8928
    w.adventures
    Nowheresville, SC
    Wife and I were out there working with the kids and we thought of this Billy bucking ray video. I would have had no problem if he showed up and wanted to split my wood, would have joined in on the fun with him.
    https://youtu.be/lzplk1sWwrE
    Delta09[QUOTED] likes this.
  9. Sep 5, 2022 at 11:49 AM
    #8929
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    What are you using for throw rope?
  10. Sep 5, 2022 at 1:25 PM
    #8930
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Lawnmower is a Sarlo WX24SP with a 6.75 Briggs engine. With the blade mounted, you have to work with it for 15-30 minutes to get it started. Remove the blade and it will start easily on the second or third pull. Any idea what would cause this?
  11. Sep 5, 2022 at 1:45 PM
    #8931
    w.adventures
    Nowheresville, SC
  12. Sep 5, 2022 at 2:29 PM
    #8932
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
  13. Sep 5, 2022 at 3:35 PM
    #8933
    Toyko Joe
    Toyko Joe Here for the pictures
    Back when I did do tree work I found that caulk line was better for me with the throw line and easier to clean up. It is still my preferred twine for general use.
  14. Sep 5, 2022 at 6:18 PM
    #8934
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm using an onion sack filled with 6 old spark plugs.:anonymous:.
  15. Sep 5, 2022 at 7:03 PM
    #8935
    SCOTT'S TACO LOCO
    SCOTT'S TACO LOCO Orange It.
    Scott
    San Antonio, Tx
    08 Toy-yo-duh TACO TRD
    Burned lots of chit this past wknd!
    Zoom in on photos, lit about 30+ brush piles.
    Very rewarding to end the long wknd here at the farm with this colorful sunset.
  16. Sep 5, 2022 at 7:06 PM
    #8936
    koditten
    Kirk
    Central Michigan
    That sunset is computer background worthy!
  17. Sep 6, 2022 at 4:37 AM
    #8937
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Low compression maybe?
    308savage[QUOTED] likes this.
  18. Sep 6, 2022 at 9:24 AM
    #8938
    Toyko Joe
    I was able to mow with the JD sst-18 over the weekend and was very pleased to get all the lawns mowed. Got some fresh ethanol free gas in her and a fresh oil filter. Added sea foam to the oil and will run it for the next mow and do a full oil change. I need a new seat or at least a seat cover. All and all, there are a few things about this engine that really annoy me, but I will keep it around for now.
    1. the oil filter is in the most obnoxious place and cannot be removed without making a total mess.
    2. the valve adjustment has no room for a wrench to fit on the jam nut. This one kicked my ass looking for a tool to use as its a 13mm jam nut, I think I found a solution and I will do one more valve adjustment check.
    3. the heat from the exhaust is too much for the OEM plastic around the hood. Perhaps I am reassembled it wrong but melting plastic is bad...
  19. Sep 6, 2022 at 7:10 PM
    #8939
    koditten
    Kirk
    Central Michigan
    Talked myself into going "all in" on this machine.
    Cylinder Head Gasket Kit Crankshaft Seals, Two Sets Of Piston Rings Compatible with Kohler 24-108-14, 24-108-14-S, 24-108-05-S, 24-108-14, 2410805, 2410814 83mm Standard, 1.5mm Rings, Style A https://www.amazon.com/dp/B08684VFC8
  20. Sep 9, 2022 at 6:17 AM
    #8940
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I bought a Stihl backpack sprayer last year, when I use it I’m constantly pumping it for pressure. Who knew they make battery powered backpack sprayers now :facepalm:
