Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Sep 9, 2022 at 6:29 AM
    #8941
    Tacoma Mike
    Southern Maine
    Just find a 12 V pump and carry around the group 27 battery with your other arm
  2. Sep 9, 2022 at 9:47 AM
    #8942
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Look at all the green stuff! Crazy what one rain storm can do. I am about to light my burn piles from the recent trees I cut down. Pictures to come.
  3. Sep 9, 2022 at 9:49 AM
    #8943
    SCOTT'S TACO LOCO
    SCOTT'S TACO LOCO Orange It.
    Scott
    San Antonio, Tx
    08 Toy-yo-duh TACO TRD
    Nice.
    I have probably 6 or 7 more, holy cow that was a lot of work, good thing I had my brother and friends come down to dove hunt to help out.
  4. Sep 9, 2022 at 10:15 AM
    #8944
    Toyko Joe
    Toyko Joe Here for the pictures
    Digging up some past posts... Where did you source your hydrated lime? I can't seem to locate it at the home stores. What would you estimate your application rate would be?
  5. Sep 9, 2022 at 10:31 AM
    #8945
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    The local hardware stores here have it, might try calling some feed stores, 50lb bag is probably $14 nowadays. The material I was using already has a form lime in it, I used 14 bags with approximately 22 tons of caliche.
    Toyko Joe[QUOTED] likes this.
  6. Sep 9, 2022 at 10:38 AM
    #8946
    Toyko Joe
    Thanks, I'll try that. I'm going to try using it to stabilize some pea gravel I have, the kids drag that stuff everywhere.
  7. Sep 9, 2022 at 10:41 AM
    #8947
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    What's the pea gravel made of?
  8. Sep 9, 2022 at 10:41 AM
    #8948
    SCOTT'S TACO LOCO
    Scott
    San Antonio, Tx
    Not all materials will bond together, you may end up with more of a mess.
    Toyko Joe likes this.
  9. Sep 9, 2022 at 11:29 AM
    #8949
    Toyko Joe
    I'll have to take a look and see if it is quartz, granite, limestone, or other. It is white pea gravel so it is a mix. I based off of my reading if it has calcium in it it will help bind.
  10. Sep 9, 2022 at 12:13 PM
    #8950
    w.adventures
    Nowheresville, SC
    Let there be fire!
  11. Sep 9, 2022 at 2:07 PM
    #8951
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Did you call the fire dept so they know to ignore all the 911 calls?
  12. Sep 9, 2022 at 2:32 PM
    #8952
    w.adventures
    Nowheresville, SC
    I am in South Carolina. Nobody cares :rofl::rofl::rofl:
  13. Sep 9, 2022 at 4:17 PM
    #8953
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    It’s definitely a little different east of the Mississippi where wildfires aren’t a huge problem like out west.
    six5crèéd[OP] and w.adventures like this.
  14. Sep 10, 2022 at 5:06 AM
    #8954
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    I have a single axle HD tilt trailer I’ll be using to move around the older B series Kubota I now have. I went with E rated Kenda trailer tires; my question is should these be balanced? I’m seeing mixed things about balancing specific trailer tires and that it’s not necessary? Anybody have any experience with this?
    six5crèéd[OP] likes this.
  15. Sep 10, 2022 at 5:30 AM
    #8955
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Most tire places don t balance ST tires.
    They can if you ask.
    Clark27 and six5crèéd[OP] like this.
  16. Sep 10, 2022 at 5:53 AM
    #8956
    Tacoma Mike
    Southern Maine
    Every tire I put on my stuff gets road forced balanced. Including trailer tires.
  17. Sep 10, 2022 at 6:01 AM
    #8957
    Toyko Joe
    Are they bias or radial trailer tires?
    Clark27, six5crèéd[OP] and wilcam47 like this.
  18. Sep 10, 2022 at 6:06 AM
    #8958
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I always balance trailer tires using the logic that smooth is better even if you can't feel it in the truck.
    I use one of these, not as shiny... :anonymous:
  19. Sep 10, 2022 at 7:11 AM
    #8959
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    I balance my trailer tires but I’m running 10k miles per year so tread life is a big deal.
  20. Sep 10, 2022 at 7:46 AM
    #8960
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Same thing happens here in rural Pennsylvania. "Oh, that's just Jim Bob burning again" :rofl:
