Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Sep 15, 2022 at 5:05 AM
    #9001
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Amazon or eBay are where I get my trailer supplies. Their prices are usually better than TSC or Northern tool.
  2. Sep 15, 2022 at 5:38 AM
    #9002
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    That looks kinda of familiar .
    Here's my 79' B7100. But I have no mowing deck.
    KRAMERICA, Bushed, RustyGreen and 5 others like this.
  3. Sep 15, 2022 at 6:20 AM
    #9003
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Yeah. It is the first welding project I made. It's not pretty, but it has held up and works, so good enough for me.
  4. Sep 15, 2022 at 6:21 AM
    #9004
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Making stuff is the only way to learn and get better at it, just like everything else :cheers:
  5. Sep 15, 2022 at 6:26 AM
    #9005
    Lt. Dangle
    Ohio
    Honestly, I just enjoy tinkering so it was a win for me. Plus, I looked at buying one and figured "How hard could it be?" and just built one lol.
    I did learn what size wire I like, and I learned that I don't like Flux core wire, so it was a good project all around.
    Here is a short video showing the finished product with my son driving the tractor. Watch your audio...
    https://www.youtube.com/watch?v=nhO6zPavLRI
  6. Sep 15, 2022 at 6:28 AM
    #9006
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Flux core wire is awful, but it's better than nothing. That's awesome with your son driving, I need to turn my son loose on the tractor. He does great with the mower and the Tacoma by himself.
  7. Sep 15, 2022 at 6:31 AM
    #9007
    Lt. Dangle
    Ohio
    Eh, he can't reach the clutch so I just put it in low 1st and let him cruise around lol. I have to hang out by him since that tractor won't stop for anything and I lack a ROPS.
  8. Sep 15, 2022 at 6:35 AM
    #9008
    Lt. Dangle
    Ohio
    I forgot to 45 the top in the circle. I learned that if I bind up the 3 pt and tractor, it will bite you lol. Guess how I learnt that? That's right, the hard way.
  9. Sep 15, 2022 at 9:01 AM
    #9009
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
  10. Sep 15, 2022 at 9:05 AM
    #9010
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    RustyGreen likes this.
  11. Sep 15, 2022 at 9:09 AM
    #9011
    Toyko Joe
    Toyko Joe Here for the pictures
    My old neighbor had one with about that many hours. I was on its 3rd rebuild of the hydraulic pump, but he had a bucket and used it hard. I think they are a good value to tractor at $2000-6000 depending on implements and other wear.
    RustyGreen and six5crèéd[OP] like this.
  12. Sep 15, 2022 at 10:27 AM
    #9012
    Lt. Dangle
    Ohio
    Just an FYI, I paid $2400 for my B4200D at around 500 hours a few years ago. Taking into account how the world is now vs. then, I still think at best it is a $3500 tractor, give or take a few hundred. If I was to list my tractor, I'd start around there anyways.
    The hours listed in the ad are irrelevant also, these little Kubotas go thousands of hours before needing rebuilt. I live in a high income area, so I don't think my prices are on the low end either.
    At $4500, the world is your Oyster when it comes to old Kubotas.
  13. Sep 15, 2022 at 10:44 AM
    #9013
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    Looks like he's starting off on the high end of what it's worth. Without a loader it seems like it should be closer to 3500 but then again, it's 4wd which adds value to it. I guess it also depends on where you live. Here in the PNW everything is more expensive and a guy probably would get the 4500 for it.
    You ought to check it out though, old Kubotas are super dependable and hard working tractors in my experience.
  14. Sep 15, 2022 at 12:09 PM
    #9014
    w.adventures
    Nowheresville, SC
    Dang, $2500 would be a sweet deal. My how times have changed.
    I am down in South Carolina, no reason tractors should be that expensive without any attachments.
  15. Sep 16, 2022 at 11:14 AM
    #9015
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I have an issue with my Titan 60" finishing mower deck. A couple of months ago, the middle blade came loose. I thought I had it fixed by cleaning up the threads and putting a new nut on it. But apparently, the threads on the shaft are also messed up, and it came loose again when I got into some really thick grass. I added another washer and a lot of blue Loctite to get it to engage on threads that are not messed up as another fix. But I don't really expect that to last. Does anybody know if you can get just a new shaft, or do I have to replace that entire assembly to fix it permanently? Also, does anyone have any suggestions on where to go to get the parts? I really don't want to have to go back to the dealer for this.
    FD6E830A-1B61-4651-8A70-621AA65A80DE.jpg B6873F15-EF2D-4413-8348-146DA375C5DF.jpg 43BDBC81-5340-478B-B945-0DEEB3CF117C.jpg
    Here’s what it was doing before I messed with it.
    https://youtube.com/shorts/_DBgd7UJZ6w?feature=share
  16. Sep 16, 2022 at 11:36 AM
    #9016
    My Name is Rahl
    Can you chase the threads with a die? Or are they past that point?
  17. Sep 16, 2022 at 12:25 PM
    #9017
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    #11 on page 17 spindle assy. Prob have to call them
    https://support.palletforks.com/hc/en-us/articles/4908410894605-60-in-Finish-Mower
  18. Sep 16, 2022 at 1:15 PM
    #9018
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    That's kinda what I did the first time I fixed it. I got it so the new nut would tread on smoothly and snugged it up. But now, when too much force is applied, the nut skips on the threads and the blade becomes loose. I'm hoping with the double washers and Loctite on there now, it will get me through the rest of this season. :fingerscrossed:
  19. Sep 16, 2022 at 5:50 PM
    #9019
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Sold! Loaded up ready for delivery. I need to take the lift kit off my truck or get a 8” drop hitch. Or do a spring over on the trailer. How hard would it be to do a spring over conversion?
    2A350E5E-3A67-4195-AA87-D6BD1541C195.jpg F2C23B14-4B1D-4826-9586-3A8E84B782BB.jpg
  20. Sep 16, 2022 at 5:57 PM
    #9020
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I think an 8" drop hitch would be easier and probably cheaper.
