Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you mow in shorts?
  1. Mow, yes, weedeat, no
    43.1%
  2. Mow and weedeat, yes
    35.3%
  3. Pants all the way for me
    21.6%
  1. Sep 23, 2022 at 11:21 AM
    #9101
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I don't know anywhere to get anything but ultra-low sulfur diesel anymore.
  2. Sep 23, 2022 at 12:44 PM
    #9102
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Unless I'm wrong ( very well could be), mostly all you can get is ULSD especially at the regular pumps.
    Now I do get off road diesel.
    six5crèéd[OP] likes this.
  3. Sep 23, 2022 at 1:33 PM
    #9103
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    And off road diesel is just dyed ULSD for tax purposes. You aren’t hurting anything in a small machine that will effect you in any real capacity unless you’re a daily heavy user. Additives you put in the fuel can bring back stability and lubricity.
    I use a quarter bottle of Seafoam in the 6gal tank usually 2 times a season, and change fuel filter the beginning of every season. No issues, no hard starts. Average 55 hrs a year on my pile. B2400 Kubota 1997 model, 1500 hrs on the clock.
  4. Sep 23, 2022 at 1:40 PM
    #9104
    Tiedie
    David
    WFOY
    This is what I'm talking about but I also add Hows for winter.
  5. Sep 23, 2022 at 2:59 PM
    #9105
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    We demo'd a stand by generator for a chemical plant 2 years ago.
    It was a big v-8 Detroit Diesel.
    The base had a fuel storage tank built in it.
    The last time it ran was in 1996.
    The unit had 680 hrs on it.
    No one is sure if it was high sulphur fuel or not, but we are still burning that fuel.
    It was a shame to cut up that machine for scrap metal. Nothing leaves a chem plant in a usable form, no matter how much money was pissed away.
  6. Sep 23, 2022 at 4:15 PM
    #9106
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    If the tank was last filled in the 90s it was almost certainly hi sulfur diesel. Off-road didn’t move to low sulfur until ’07 and has been ultra low sulfur since ’10 whereas on-road has been ULSD since ‘06.
    I’ve started using Howes diesel treatment to help with the issues of ULSD.
  7. Sep 23, 2022 at 5:35 PM
    #9107
    koditten
    Kirk
    Central Michigan
    We have noticed that it grows algae. Tossing in an algaecide, swapping filters and it is running fine in the skid steers
  8. Sep 23, 2022 at 5:47 PM
    #9108
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    In about 2010 I got a drum of fuel oil that had been sitting outside since 1975, it was an odd amber color but smelled normal. I burned it in a torpedo heater, worked perfectly.
  9. Sep 23, 2022 at 5:51 PM
    #9109
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    And then there is ethanol gas :annoyed:
  10. Sep 23, 2022 at 5:51 PM
    #9110
    koditten
    Kirk
    Central Michigan
    Yep, it has a very long shelf life.
  11. Sep 23, 2022 at 6:05 PM
    #9111
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Well, Diesel is made of old dinosaurs.:rolleyes: I think Howes is supposed to help with the algae growth. It can become a real problem if it gets into your fuel lines. I've had more issues with water, I think, due to the hi humidity mixed with temperature changes.
  12. Sep 23, 2022 at 6:51 PM
    #9112
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Agree :frusty: One of the dumber things someone came up with...
  13. Sep 23, 2022 at 6:53 PM
    #9113
    Toyko Joe
    Toyko Joe Here for the pictures
    Corn doesn’t use fuel to create fuel. :notsure::lalala:
  14. Sep 23, 2022 at 7:02 PM
    #9114
    Blkvoodoo
    Kevin
    Near Clayton NC
    couple years ago I was at scrap yard working on a lift, 20 cyl MTU generator in its entirety sitting there, big as a house. Heads 7 and 8 are removed, peak into the cavern, and connecting rod spaghetti….ain’t no bringing that back
    Scrap yard tried to market for parts before it got broken down, it met the torch, all of it. I can’t even imagine the cost to replace that.
  15. Sep 23, 2022 at 7:03 PM
    #9115
    w.adventures
    Nowheresville, SC
    We are all going to get banned :anonymous:
  16. Sep 23, 2022 at 7:04 PM
    #9116
    Toyko Joe
  17. Sep 24, 2022 at 4:14 AM
    #9117
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Everything is considered contaminated, even if it was never used. It’s amazing what you can see in the metal dumpsters at work.
  18. Sep 24, 2022 at 4:23 AM
    #9118
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    Then after struggling all day to half ass a road grade, my neighbor (her family owns a big farm around here but she never helps with anything for the common road) has a worker show up with a perfect kubota with grader for her back yard….. :annoyed:
  19. Sep 24, 2022 at 4:59 PM
    #9119
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Same here. Kioti made the most sense for the money for me
  20. Sep 24, 2022 at 5:20 PM
    #9120
    Blkvoodoo
    Kevin
    Near Clayton NC
    Kioti wasn’t a known brand when I bought my Kubota, since then there is the southeastern distribution center 8 miles from me, been there several times, finally got to operate a CX25HST w/loader a friend bought.
    Loader lift height is much higher than my Kubota LA352/B2400, BUT loader joy stick is buried behind my right knee, knees are in the dash, operating the stick gets frustrating fighting knee/leg room.
    Kubota loader stick is forward on side of dash, easy to reach and not in way of movement.
    other than my fat 6’4” ass not fitting well, I found it to be a pretty nice machine. The guy that bought it, is 6’5” and as big as me, he loves it. His biggest complaint is burning his right heel on the trans filter sticking into the floor area, I mentioned that wearing Crocs while operating probably wasn’t a design consideration…..nor was his size 16 gorilla feet…..
