Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Sep 24, 2022 at 7:08 PM
    #9121
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Yeah, dealer location is important. There are a number of good tractors out there, but they didn't have dealerships in the town closest to me, and I didn't want to drive an hour or more for any kind of service or parts. Having operated a lot of different loaders/forklifts over the years. I think the loader control valve could be smoother on the Kioti and it's a little cramped. I'm Fat and 5'8", but with the seat all the way back, I do have enough room. Though, if the height were in my legs, fitting in another 8" would be a challenge. I do like where the loader stick is located, and I have a manual 12x12 shuttle shift trans, so no HST issues for me. I also didn't care for the HST rocker-style pedal on the Kabota, I find it awkward to lift my heel up for reverse. I think the sidexside pedal is a better configuration if I had gone the HST route. If your friend doesn't have one already, I'd tell him to look into getting the form-fitting rubber floor mat. My local dealer puts them on all the tractors, even base models. I operate mine wearing Crocs all the time. The mat is thick and would go a long way toward insulating him from the heat of the HST filter.
  2. Sep 24, 2022 at 9:01 PM
    #9122
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    How thick is the steel plate you used to mount the hooks? I've got 1/4" and 3/16" steel plates, but I'm not sure which I should use.
  3. Sep 25, 2022 at 6:22 AM
    #9123
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I’d go 1/4”. I used 5/16”.
    KRAMERICA[QUOTED] and RustyGreen like this.
  4. Sep 25, 2022 at 7:59 AM
    #9124
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    I put the old tractors to work for a bit yesterday. Pulled a couple dead alder trees up out of the forest so I could buck them up into firewood.
    I tried removing the blade that came with the B5100 only to find that the lift arms are essentially rusted to the pins on the blade. Any suggestions? I even tried spreading the arms apart with hilift without success.
  5. Sep 25, 2022 at 8:53 AM
    #9125
    My Name is Rahl
    Can't be stuck if it's a liquid...
  6. Sep 25, 2022 at 9:04 AM
    #9126
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I'm sure you tried to loosen the chain check bolts next to the lift arms, you know the ones that keep the impliment from swaying back and forth. You can try heating them up or spray penetrating oil on the pins.
    Good luck
  7. Sep 25, 2022 at 9:10 AM
    #9127
    Tiedie
    David
    WFOY
    Here ya go a copyof my manual page 32
    six5crèéd[OP] and RustyGreen like this.
  8. Sep 25, 2022 at 11:08 AM
    #9128
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Check that the chain checks have sufficient slack as Tiedie said above. ^^^
    If they are actually rusted in place, wire brush all the rust you can off of the pins and spray generously with some PB Blaster, you can leave it sitting with just a bit of tension from the hi lift jack on it (don't go overboard ;)), tap the assembly with a hammer occasionally and respray.
  9. Sep 25, 2022 at 11:10 AM
    #9129
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :rofl::rofl:
  10. Sep 25, 2022 at 11:32 AM
    #9130
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    ^^^What he said^^^
    PB Blaster, and a big hammer.
  11. Sep 25, 2022 at 1:39 PM
    #9131
    RustyGreen
    sleeping in a chair
    Pavement Princess
    With the jack giving pressure you don't need to hit it hard.
    The vibrations help break the rust bond which helps the penetrant to make further inroads in the joint.
    Soak, tap, jack, wait - repeat - usually gets the job done.
  12. Sep 25, 2022 at 6:23 PM
    #9132
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Forget the PB Blaster, it's merely WD40 with a different smell. Find some Free All or Kroil. A 50/50 mix of acetone and Valvoline transmission fluid mix also does quite well...
    six5crèéd[OP] likes this.
  13. Sep 25, 2022 at 6:50 PM
    #9133
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I keep a can of WD around for battery terminals and goo remover, PB is my usual removal aid choice.
    Kroil and Free All aren't common to find around here it seems.
  14. Sep 25, 2022 at 6:54 PM
    #9134
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I've found Free All at Advance Auto of all places... Kroil is pretty hard to find and needs mail ordered lots of time. Reminds me I'm out and need to get some more...
    I typically break out the smoke wrench at work. Most of my co-workers are scared of it, but it's my favourite tool. I can cut off a stuck inner bearing race off a shaft without damaging it most times. Co-workers think I'm a Wizard :rofl:
  15. Sep 25, 2022 at 7:00 PM
    #9135
    My Name is Rahl
    You do have the beard and like to go barefoot...
  16. Sep 25, 2022 at 7:02 PM
    #9136
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I... I... uhhh... yea I got nothing for that one... :rofl:
  17. Sep 25, 2022 at 7:07 PM
    #9137
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :fistbump:
    I do...
    :rofl::rofl::rofl::rofl::rofl:
    :rofl::rofl::rofl:
    :rofl::rofl:
    and
    :rofl:
  18. Sep 25, 2022 at 9:04 PM
    #9138
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Vinegar also works for removing rust. but might be difficult to apply in this application.
  19. Sep 25, 2022 at 10:16 PM
    #9139
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Vinegar is good on french fries too. :hungry:
  20. Sep 26, 2022 at 4:53 AM
    #9140
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Looking for recommendations for a generator to run the kitchen refrigerator, and maybe a space heater.
