Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    46.7%
  2. After
    56.7%
  3. Neither
    13.3%
  4. I weed whack while someone else mows
    6.7%
Multiple votes are allowed.
  1. Sep 26, 2022 at 5:34 AM
    #9141
    Toyko Joe
    Toyko Joe Here for the pictures
    Oil or electric ceramic space heater?
    Wattage and length of runtime are your big factors for generator selection.
    I chose a 2300watt peak with 1800w running for use with my refrigerator, fridge and a/c unit. Each would run independently of the other. A backup generator for your house to be able to run multiple high demand items will not have a long running time, meaning you will have to refuel a lot and also have a high fuel consumption rate.
    I looked into LP/gas powered hybrid generators which would run off a 100# tank it would have been a great setup for a standby whole house but I really only need a unit to power one appliance at a time. My shed office has heat and A/c and runs off of a 15a circuit so my generator could power that through the night hot or cold and we would be fine for a few nights “camping” in my office.
  2. Sep 26, 2022 at 7:01 AM
    #9142
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    So many good tips here! Thanks guys. I had those sway chains completely disconnected at one point but they weren't was was keeping the arms from spreading. The whole thing has been soaking in PB blaster for a little over a day now. When I get home I'll try beating it with the hammer again.
    KRAMERICA and six5crèéd[OP] like this.
  3. Sep 26, 2022 at 7:26 AM
    #9143
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Try disconnecting from the lower part of lift arms near the rear of PTO shaft might be easier and less damaging.
    six5crèéd[OP] likes this.
  4. Sep 26, 2022 at 8:07 AM
    #9144
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Mostly just refrigerator and a small ceramic heater in the winter if the power goes out. We've got gas logs so we can always close the door to the den and stay warm, and maybe run a small heater upstairs intermittently. Seems like every time we get a storm nowadays, the power is out for a while. But mostly to keep the fridge cold.
    wilcam47 and six5crèéd[OP] like this.
  5. Sep 26, 2022 at 8:20 AM
    #9145
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    I use a 3500w Preditor inverter generator, well, its Power horse from Norther but same as the HF Preditor.
    Zero issues, very quiet and just keeping fridge and chest freezer uses about 2gal in about 24hrs, only time I hear Otis when compressor kicks. Have had for several years now. The “starting” battery is useless after a few months of non use, just not running it to keep it charged, 2-3 pulls on rope and it’s running.
  6. Sep 26, 2022 at 8:41 AM
    #9146
    12thmanhawkfan
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    At one point I did do that. I ended up putting it back on but I might take it off again when I get back to it tonight.
  7. Sep 26, 2022 at 9:37 AM
    #9147
    308savage
    Adam
    East Tennessee
    six5crèéd[OP] and wilcam47 like this.
  8. Sep 26, 2022 at 10:04 AM
    #9148
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    That's a very short-term solution, and if the batteries are not fully charged when the power goes out, it will be an even shorter-term solution.
    Batteries also lose their ability to hold a charge after several years. So in 5 years or so, you could be forced to buy new batteries, and those damn things are expensive.
    I'd stick to finding a 2-3K gas/propane generator. Take care of it, keep your fuel fresh, and you'll have a backup power source for decades.
  9. Sep 26, 2022 at 10:12 AM
    #9149
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    308savage[QUOTED] likes this.
  10. Sep 26, 2022 at 10:17 AM
    #9150
    308savage
    Adam
    East Tennessee
    I'll be forced to buy batteries anyway, I'm all in on the battery powered yard equipment!
    I didn't know they ran on propane now. To me that sounds better than gas.
    https://www.walmart.com/ip/Sportsman-4000W-Dual-Fuel-Generator/46542325
  11. Sep 26, 2022 at 10:37 AM
    #9151
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    You get slightly lower power output on propane, but you'd still have plenty of power for the Fridge. I think the biggest problem with a battery power unit like that is once the batteries are used up, you'll likely be unable to charge them again until the power is restored. You can buy solar panels to recharge the unit, but those rely on good weather to achieve sufficient power. And that would still take a full day of direct sunlight to get a partial charge.
    I want a suffient backup power source so I can keep going for a week. With a 2-3k gas unit and a 5 gal can of gas or a propane tank, you can do that. Now I also want to be able to power everything in my house, including HVAC, so I bought a 9.5k generator. Eventually, I want to upgrade my electric box so that I can plug the whole house in at once. For now, I have enough power cords I can plug the essentials in and run the gen set all at once.
  12. Sep 26, 2022 at 12:00 PM
    #9152
    Toyko Joe
    No offense but that might only get through (1) standard fridge/freezer for one cooling cycle. Fridge/freezers use around 700-1,100 watts with a cooling cycle of 10-30minutes. Their example of a 200w fridge running for 4.5hrs is one of those 2.5cft refrigerators.
  13. Sep 26, 2022 at 1:53 PM
    #9153
    Tiedie
    David
    WFOY
    HAHaHA, Got you kinda beat I have a 8000 running with a 12000 surge with transfer switch wired to main breaker . HVAC not hooked up. But if power goes out in summer its not as bad as winter. Propane fire place,stove,grill,water heater. Well hooked up to generac along with rest of house and I keep 25 gal of gas on hand.
    Had I had the money when needed to do this I would have gone whole house back up.
    You guys I live WFO (Way Far OUT). Litterly just got internet thi year :rofl::rofl::rofl::rofl::rofl:.
  14. Sep 26, 2022 at 1:57 PM
    #9154
    Tiedie
    David
    WFOY
    Do it might break free easier being able to move it around. Were you able to see manual?
  15. Sep 26, 2022 at 3:04 PM
    #9155
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    LOL, I'll get there eventually. I have enough to cover my basic needs. I live out in the sticks, but I'm not way far out. I'm at the outer edge of the county, but I'm still in one of the larger counties in Tennessee. In the 9 years I've been here, I've never had a power outage last a whole day. But I don't prepare for what hasn't happened to me; I prepare for what could happen. There have certainly been areas not too far from me that have faced multi-day power outages. I'll be pretty well set once I upgrade my electric panel with a disconnect and my propane tank lines so I can run my Gen and BBQ grill off my main supply.
  16. Sep 26, 2022 at 3:25 PM
    #9156
    Tiedie
    David
    WFOY
    :amen:
  17. Sep 27, 2022 at 7:34 AM
    #9157
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    howdy fellas. curious on feedback of my recent purchase. husquvarna lrh 125 rider. recent battery, claimed it ran a couple months ago. did i buy a lemon or is it worth having? has all bagging stuff. 75$20220925_073309.jpg
  18. Sep 27, 2022 at 7:40 AM
    #9158
    Toyko Joe
    It looks neat. It all depends on how much you want to spend on it.
  19. Sep 27, 2022 at 7:41 AM
    #9159
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    If you can get it running, it'll be well worth $75 :thumbsup:
  20. Sep 27, 2022 at 7:43 AM
    #9160
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    This!
