Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Sep 27, 2022 at 12:22 PM
    #9161
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I believe that was built when Husky was under the AYP umbrella (American Yard Products), it is a twin to some Craftsman models so parts should be no problem.
    Should have the nice Kohler Command engine too, they are usually nice runners.
  2. Sep 27, 2022 at 12:25 PM
    #9162
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Fixed that one for ya :D
  3. Sep 27, 2022 at 12:44 PM
    #9163
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The one I have on the New Holland is a generous oil consumer I agree, runs nice though and has plenty of go.
  4. Sep 27, 2022 at 2:38 PM
    #9164
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Friend of mine said he’d help me put a clutch in my Ford 4630. I got the clutch today, now to find time.
    I’ve never seen a pressure plate with splines. I guess it drives the shaft for the PTO pump in the trans to give me live PTO. That’ll be fun trying to line 2 sets of splines up to get it back together.
  5. Sep 27, 2022 at 2:50 PM
    #9165
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    yes its a kohler12.5. tbd on the smokin.
  6. Sep 27, 2022 at 2:51 PM
    #9166
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Friend has an older twin Kohler on a Terrimite Backhoe. Insist on running 5w20 in it and wonders why it smokes at idle... :facepalm:
  7. Sep 27, 2022 at 2:55 PM
    #9167
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i should probaly use 30w. believe it was made between 94 and 07.
  8. Sep 27, 2022 at 3:02 PM
    #9168
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Probably wouldn't hurt to use a heavy duty diesel 15w40. That's what I used in my older mowers. My newer Kohler twin gets Valvoline VR1 Synthetic 10w30 racing oil. It's wayyy overkill though :laugh:
  9. Sep 27, 2022 at 3:06 PM
    #9169
    Jesse
    Poulsbo
    15' DCSB OR S/C
    ill try that. coworker has 1 week to move, figured 75$ wouldnt be bad. not sure if an older hydro drive is an expensive mistake or a quality choice. he last used it 2 months ago and had a new battery this year. ill give it a go.
  10. Sep 27, 2022 at 5:53 PM
    #9170
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The Command engine has an oil pump, filter and hydraulic lifters, straight 30 grade is a poor choice especially with the coming cooler weather.
    Kohler recommends 10W-30, I have used the Kohler branded oil in all my OPE with a filter. You can use a common WIX 51348 filter, easy to find, it fits many Chryslers.
  11. Sep 27, 2022 at 5:55 PM
    #9171
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Older hydros in lawn tractors are usually quite reliable, after all these years it isn't a bad idea to change the oil and filter if it has one (probably not), kind of a fussy job but not difficult or even expensive.
  12. Sep 27, 2022 at 6:16 PM
    #9172
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i really know nothing about it and was spitballing ideas. thank you for the advice. ill have it in a couple days.
  13. Sep 27, 2022 at 6:18 PM
    #9173
    Jesse
    Poulsbo
    15' DCSB OR S/C
    yes! definately that. i figured 100$ish in tune up costs to see what i have would be worth it.
  14. Sep 27, 2022 at 6:21 PM
    #9174
    RustyGreen
    sleeping in a chair
    Pavement Princess
    As long as you aren't mowing huge amounts of land with some maintenance and care those older riders can give many years of service.
  15. Sep 27, 2022 at 6:26 PM
    #9175
    Jesse
    Poulsbo
    15' DCSB OR S/C
    sweet! i have a 30min mow with it. mainly wanted it for hauling.
  16. Sep 27, 2022 at 6:28 PM
    #9176
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I have had lots of older riders (cheap) the number #1 problem is always the deck, #2 the steering. The actual engine and transmission are usually far more reliable.
  17. Sep 27, 2022 at 6:37 PM
    #9177
    Jesse
    Poulsbo
    15' DCSB OR S/C
    yep ill look into that too. thank you.
  18. Sep 27, 2022 at 6:38 PM
    #9178
    Jesse
    Poulsbo
    15' DCSB OR S/C
    do appreciate you guys giving feedback. thanks. should get delivered tmrw so i can see what is.
  19. Sep 27, 2022 at 6:56 PM
    #9179
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I agree.
    Straight grade oils were designs to keep impurities in suspension. The idea was to remove contaminates with an oil drain.
    Newer engines have filters to catch these particulates.
    In addition, straight weight oils are more money or harder to find.
    I do believe changing your oil is the best recipe for keeping your engine running as long as possible.
    With that said, keeping the oil topped off is the cheapest.
    I have a 1974 Kohler twin that has burned oil for 20 years. I check the oil every 6 hrs, add oil the next spring. It doesn't care.
  20. Sep 27, 2022 at 7:28 PM
    #9180
    Toyko Joe
    Toyko Joe Here for the pictures
    We used to say if the tire goes flat in one day that’s when you fix the leak, otherwise just check on it daily. Same sort of thing. :rofl:
