Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you mow in shorts?
  1. Mow, yes, weedeat, no
    43.6%
  2. Mow and weedeat, yes
    32.7%
  3. Pants all the way for me
    23.6%
  1. Oct 10, 2022 at 6:30 AM
    #9361
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    If only you knew a welder :rofl::)
  2. Oct 10, 2022 at 6:35 AM
    #9362
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    :anonymous:
    wilcam47 and RustyGreen like this.
  3. Oct 10, 2022 at 7:01 AM
    #9363
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    :rofl: :rofl: :rofl:
    :fistbump:
    Yea, I don't even know anymore :laugh: They used to be really sharp (mentally) back in the day and could do anything, but slowly as time passes on they've gone downhill a little. Medications do that. I think the side affects are worse than what it's treating. I help them out as much as I can, but this one was a facepalm. They even said "damn I'm stupid" :laugh:
  4. Oct 10, 2022 at 8:42 AM
    #9364
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    :yes:Dropped this tree over the weekend and split some wood. I really need a 20-24” bar for the 395xp. It currently has a 32” bar.
  5. Oct 10, 2022 at 9:58 AM
    #9365
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Well if it’s coming from the tire, I’d do is Mike and the others had suggested and try a tire goop or a tube. If it’s leaking at the rim, I would break the bead and clean up the rim then use a wheel sealant like this one before resetting the bead.
    Xtra-Seal - Bead Sealer Flammable 32Oz (TI250) https://a.co/d/9GmWD5p
  6. Oct 10, 2022 at 10:00 AM
    #9366
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Links or suggestion for tire chains? I have a Kubota B7610 and it looks like I will use it to plow the driveway with a front mounted skid steer plow (my bucket has the skid steer quick attachments). Driveway is not overly steep but steep enough that I think chains is the smart move. Did a quick search and DAMN they’re not cheap
    RustyGreen and six5crèéd[OP] like this.
  7. Oct 10, 2022 at 10:10 AM
    #9367
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I looked at some a few years ago and they are expensive!!!
    RustyGreen and Clark27[QUOTED] like this.
  8. Oct 10, 2022 at 11:22 AM
    #9368
    Clark27
    Springfield, MA
    2015 Lexus GX460
    I couldn’t believe it. I was think 100-200 for a full set but it was that price per wheel almost
  9. Oct 10, 2022 at 12:52 PM
    #9369
    Bushed
    Bushed Well-Known Member
    Kenora, ON
    08 DCSB TRD OR - Sold
    Cambridge Metals and Plastics Bed Bar
    Im at the other end of the Kubota spectrum with a sub compact BX-23S with R4 tires. I use it to with a 60” plow to clear my 720 foot driveway during the winter. Northwestern Ontario winters. The driveway is a combination of flat, sloped, and a steep hill. I haven’t run into any issues running it without tire chains or wheel weights. Just the hoe, or my scraper box as a counter weight. I’ve been stuck a few times, but it was operator error, running off the edge of the driveway into the ditch, or trying to widen out to road by push the windrow out into the yard and losing traction in the sugar snow underneath the powder. I’ve always been able to get myself unstuck. Don’t make the same stupid mistakes I’ve made, and I’m of the opinion that you’ll be fine without chains.
  10. Oct 10, 2022 at 3:24 PM
    #9370
    Clark27
    Springfield, MA
    2015 Lexus GX460
    Awesome input/feedback. My driveway is roughly 2000 foot but fairly wide and has a slope almost the entire way. I do have a circle at the top as well. The downside I have is one side of the driveway is a fairly steep bank and if I’m making any stupid mistakes on that side I’ll be in big trouble. I was planning to sand the driveway as well so I’ll have a big PTO spreader in the back for weight too. Are your tires in fairly good shape/newer? I’m new to owning a tractor but these tires on my seem rock hard and would just slide on snow/ice in my mind
  11. Oct 10, 2022 at 4:10 PM
    #9371
    Bushed
    Kenora, ON
    It was late winter when I brought my tractor home, so I have 2 and a half winters on my tires now. Only about 125 hours on my machine at this point. There is some tire wear and cuts in the blocks from sharp rocks, but overall my edges are in good shape. In hindsight, turf tires may have been a better choice for me, but my tires work quite well, and I’ll probably chose a hybrid R4 when they do eventually wear out. If you have Ag tires, I would probably consider other options for snow, or chaining up. Something to consider though is that you want to have a nice packed base of snow, and you want to leave that down, not plow right down to the dirt. The thing is, that packed snow does not equate to slippery. Your traction is quite good on compacted snow, so your tractor should handle it just fine. What can get you is if your cutting edge catches. You want to be moving fast enough to curl the snow up and off the edge of your blade. If the cutting edge grabs at that speed, it tends to skew the machine in the direction the blade is angled. Hopefully, in that case, you just end up stuck in your bank, and not sliding off of the side entirely. To try to prevent that from happening, and it’s not entirely fool proof but close enough, I run my skid shoes with enough spacers to keep the cutting edge about 3/8 to one half inch above the surface. You can still catch on an uneven surface, like the transition from my driveway to the pad in front of my garage, but I’ve learned what height and angle I need to run the blade at when working that area through trial and error. For the most part though, I am able to just run the blade in float once the base is packed down.
  12. Oct 10, 2022 at 4:33 PM
    #9372
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Those keys are hard to shear! :eek:
    My best guess they towed it at some point without releasing the brake or the hydraulic lock and the wheel stuttered and skipped on pavement impacting the key, about the only way I can see breaking one of those like that.
    That's a great deal on broke stuff, the best kind!
  13. Oct 10, 2022 at 4:45 PM
    #9373
    Key-Rei
    Key
    Florida
    I thought about something removable like that but the lower flange on mine was so flimsy towing the empty trailer around the yard on just a hook through that hole was enough to slightly bend the flange, anything cantilevered out like yours would bend it right off.
    So I built that 2x2" 1/4" SST and the 1/4" plate on top with the 45° gussets then welded all around if anything it reinforced the rear plate.
    I'm considering welding a lifting eye onto the face of the vertical so I can hook up a shackle for a solid connection for dragging but I got the Tacoma winch for that if need be really.
    Definitely the strongest part of my little lawn tractor though!
    :rofl:
  14. Oct 10, 2022 at 4:52 PM
    #9374
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    That might be 1/2", it was just a piece of steel I had around, seems plenty solid.
    The chipper doesn't have much tongue weight and it never changes.
    You painted yours too, I was too lazy. :laugh:
  15. Oct 10, 2022 at 5:23 PM
    #9375
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I thought the same. Not everyone knows about the hydraulic pump bypass valves for each wheel.
  16. Oct 10, 2022 at 5:30 PM
    #9376
    Key-Rei
    Key
    Florida
    My little tractor has a tiny wire L sticking out the back, pull it out release the parking brake and it free wheels easily, push it in and if you try to drag it the wheels will either skip or one turns backwards, forget you have it pulled out and you think the hydrostatic gave out because tractor no go nowhere.
  17. Oct 10, 2022 at 8:50 PM
    #9377
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Solenoid is the click I'm getting. Jumping it does not change anything re the engine not turning, though I"m not getting any sparkage from solenoid. Battery is good and I have a multimeter hit on battery and solenoid. F me.
  18. Oct 11, 2022 at 12:37 PM
    #9378
    koditten
    Kirk
    Central Michigan
    Strippijg down another deck. Found a nut that was completly rounded off. This will not deter me from my goals!
    Sacrificed an orphan socket. No problem once you add a little heat to the trouble.
    imdyy84UljYDzOh-7W0O_QMkAjNH83GpRaiuhxfQ_36348261dcc8349d0de25183fa39e5f7919c21b1.jpg
    Ua3OaDnXkU28_ibhsaRqIelRYm6Fat7T1aE4M0cj_a93351983abc744a0f64ff86cc2d3a031f33791d.jpg
    QmaNgv210nWP0gaue0gbVw82CJnJOFqaIVCOry7v_257d1d1200d5ce1ecfa76ca3e717a4d8d6dbc81a.jpg
  19. Oct 11, 2022 at 12:47 PM
    #9379
    Tacoma Mike
    Southern Maine
    No they aren’t.
    I stopped sealing my driveway since by the time spring rolls around, you can’t tell I did it anymore from the chains..
  20. Oct 11, 2022 at 12:48 PM
    #9380
    Tacoma Mike
    Southern Maine
    That’s reusable now. Get your monies worth out of that socket..
