Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    44.8%
  2. After
    58.6%
  3. Neither
    13.8%
  4. I weed whack while someone else mows
    6.9%
Multiple votes are allowed.
  1. Jun 17, 2020 at 4:23 AM
    #921
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    I was thinking this would help keep it stable.
    No idea. Maybe I have been lifting to much weight? Makes me wonder if I should have went to a bigger machine.
  2. Jun 17, 2020 at 4:43 AM
    #922
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    IMHO a loader should be built where the hydraulics give up before steel bends.
    But, we all know that things are no longer built this way. Sadly.
  3. Jun 17, 2020 at 4:44 AM
    #923
    ColoradoTJ
    Colorado
    I agree, and thought this is how it was set up. Guess not. :D
  4. Jun 17, 2020 at 7:37 AM
    #924
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    I'd use a porta-power like the one you posted to bend it back straight. You might need to over bend it a touch to prevent spring-back. Then I'd weld a plate on the open side of it, just make sure you've got the clearance to do so.
    ColoradoTJ and six5crèéd[OP] like this.
  5. Jun 17, 2020 at 11:53 AM
    #925
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    HF Towable backhoe. Apparently, major assembly required...
  6. Jun 17, 2020 at 11:57 AM
    #926
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    :popcorn:
  7. Jun 17, 2020 at 12:57 PM
    #927
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    These are the assembly instructions :mad:
  8. Jun 17, 2020 at 1:23 PM
    #928
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I ordered an upper radiator hose for one of our 140’s from them. It’s an elbow with two different sized ends. It wouldn’t fit. I emailed them, they called me back and said half of their batch was wrong and to throw it away and they sent me another one :thumbsup:
  9. Jun 17, 2020 at 4:58 PM
    #929
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Not too bad actually. Need to pick up hydraulic oil in the morning so I can play with it though.
  10. Jun 17, 2020 at 6:46 PM
    #930
    Tractorman
    Tractorman Just A Dumb Farmer
    Stupid
    Misery
    2015 DCSB / MGM
    Baled a little hay today.
  11. Jun 17, 2020 at 7:07 PM
    #931
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    This morning’s project. I put the Haban sickle mower on the 1050. I just had to see it work.
    Most of the pieces are here. I was missing a spring so I had to get a little creative. But it’s in functioning condition once again.
    https://youtu.be/sPHJadCB_z4
    Bushed, shaeff, Steve Urquell and 2 others like this.
  12. Jun 17, 2020 at 7:09 PM
    #932
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Does that baler have the self contained hydraulic pressure system to keep tension on the belts?
  13. Jun 17, 2020 at 7:11 PM
    #933
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    That's a very cool piece of machinery. I'd have a very tough time letting that go.
  14. Jun 17, 2020 at 7:11 PM
    #934
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    How did it cut?
  15. Jun 17, 2020 at 7:18 PM
    #935
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I actually have it listed now. I only have one small spot that really makes sense to use it.
    BUT, if I can’t get my asking price. I will use it for five minutes every week with a smile on my face.
    I didn’t actually cut with it. I read somewhere that you’re supposed to oil the blades. Need to look into that.
  16. Jun 18, 2020 at 3:40 AM
    #936
    soggyBottom
    soggyBottom Well-Known Member
    I don't have a tractor but I saw this and thought of you guys.
  17. Jun 18, 2020 at 4:32 AM
    #937
    Tractorman
    Stupid
    Misery
    2015 DCSB / MGM
    Here’s the one I have for the 2000 rpm pto on a 430 John Deere.
  18. Jun 18, 2020 at 4:37 AM
    #938
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Oh yeah. That is cool
  19. Jun 18, 2020 at 5:11 AM
    #939
    shaeff
    Hudson Valley, NY
    Always thought of getting one of these, but I'd only be able to dig after it rains for an extended period of time. My property is primarily clay, during dry summers it's like concrete. :(
    I've always had good luck with them except for their tractor manuals. (I ended up getting a factory AGCO manual for my '64 MF35 Utility) If I don't get factory MF parts, I usually go through them. Their shipping prices kinda suck on small items, though.
  20. Jun 18, 2020 at 10:12 AM
    #940
    CavalryTacoTN
    CavalryTacoTN Well-Known Member
    Lee
    2020 magnetic f150 STX
    A little open cab 4455 action today 9BA4E2E2-D6C5-40D7-A05B-92FFFC929E1B.jpg
