Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Oct 30, 2022 at 7:59 AM
    #9561
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    You're right, I do have to keep the sticks cleaned up. I ususally try to hand clean and also cut with mower just before leaves start to fall, even if grass doesn't need it. Mulch the twigs.
    I used to have a piece of 6" regular corrugated on it because when I bought it the intake tube was missing. After I replaced it with the smooth walled pipe, twigs aren't as big of an issue.
  2. Oct 30, 2022 at 8:31 AM
    #9562
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Splurge on a set of ''gator blades,'' the design will do a far better job of chopping small sticks and leaves down to a size that will not clog up the tube and as a bonus, you can put quite a few more leaves into the bin before dumping. They really aren't all that much money and I just swap the two sets I have for the Grasshopper out each year and sharpen the one's I take out.
  3. Oct 30, 2022 at 9:44 AM
    #9563
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I need to do that with mine, never tried them.
    RustyGreen likes this.
  4. Oct 30, 2022 at 12:13 PM
    #9564
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Speaking of a Tacoma forum, the ol GT500 came to my rescue today cleaning up the axle in the first gen. FZJ80 axles are insanely heavy compared to mini truck stuff
  5. Oct 30, 2022 at 12:50 PM
    #9565
    Toyko Joe
    Toyko Joe Here for the pictures
    :anonymous:
    The Tacoma I had didn’t fit car seats. :ballchain:
  6. Oct 30, 2022 at 5:03 PM
    #9566
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I was kind of looking for a Grasshopper front mount like that justifying that a snow blade attachment would make it a 4 season machine. (I can justify buying damn near anything if I work at it... ;))
    Then...
    I saw one in person -- the thing is freaking huge, like take up an entire garage bay huge. :eek:
    :gossip: I would still buy one if it was cheap enough, it wouldn't be the first time cool trumped smart for me. :laugh:
  7. Oct 30, 2022 at 6:47 PM
    #9567
    fxntime
    Yeah but they mow so well around stuff. My shorter Kubota doesn't do anywhere as well and though the Grasshopper doesn't have an air ride seat, it rides as well as the Kubota.
    It's also very easy to work on and the hydro system uses actual auto sized filters that actually filter. I would have bought another one except that they are around 18 K now.
  8. Oct 31, 2022 at 5:59 AM
    #9568
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Stihl makes a grease for that application. (They did, I assume they still do.)
    It comes in a metal toothpaste-type tube, and screws into the hole (same threads as the plug). Squeeze a little, and you're done.
  9. Oct 31, 2022 at 6:02 AM
    #9569
    Scott B.
    Scott
    Georgia
    I twisted the threaded part of the axle shaft off on my trimmer (yeah, it's left-handed thread). I was able to find a replacement shaft.
    However, I was unable to remove it from the head. We tried and tried, and could not get it out. I assume the bearings are press-fit.
    A bummer, since I had to buy a new edger. Fortunately, it is a split-shaft, so I did not loose the power head as well.
  10. Nov 1, 2022 at 5:26 PM
    #9570
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    fellas- im in the pacific nw, cold and wet lots of months during tool storage. in a metal,unheated, dry space how would you....if you covered mower,chipper, etc?? solid plastic, like the bag on my pressure washer im thinking is bad. moisture, mildew, problems... maybe just a canvas dropcloth to cover yet leave breatheable? or am i over thinking? im just a poor bastard trying to care for my stuff. thanks and feedback welcomed.
    six5crèéd[OP] and Delta09 like this.
  11. Nov 1, 2022 at 5:31 PM
    #9571
    6 gearT444E
    Deep South
    Herculiner Hootus
    why cover it at all if you’re in a dry space?
    six5crèéd[OP] and DES2009 like this.
  12. Nov 1, 2022 at 5:32 PM
    #9572
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Metal unheated space... hmmm. Is it a concrete floor? If so I would probably leave it uncovered really. Most peoples sheds are the same way and nobody (including me) covers anything up.
    six5crèéd[OP] and 6 gearT444E like this.
  13. Nov 1, 2022 at 5:36 PM
    #9573
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I like loosely covering with the cheap HF tarps. I think the plastic rustling in the wind keeps the mice away.
  14. Nov 1, 2022 at 6:19 PM
    #9574
    6 gearT444E
    Deep South
    Herculiner Hootus
    barn cat and tarp, the ultimate mouse exterminators!
  15. Nov 1, 2022 at 7:30 PM
    #9575
    Jesse
    Poulsbo
    15' DCSB OR S/C
    gravel. open ended rv covering. lots of breeze. not much rodent issue. would get a cat but there's plenty above that food chain here.
    six5crèéd[OP] likes this.
  16. Nov 1, 2022 at 8:17 PM
    #9576
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I lived up there for many years and kept my mower under the carport. When I thought it was necessary to cover it, like if the rain started blowing sideways, I put a blue tarp over it. Most things with engines in them are made to handle a little weather.
  17. Nov 3, 2022 at 4:07 PM
    #9577
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    Update on cylinder, thank you all for suggestions on repair. Had a local shop weld for $62 we will see if she holds. Time to get blood in this bucket!
  18. Nov 3, 2022 at 6:43 PM
    #9578
    koditten
    Kirk
    Central Michigan
    Not impressed with the welds.
    Please tell me you put the paint on.
    I'd really have liked to see the welds before paint.
    Beat it like a rented mule. If it holds, I'm wrong ...and happy.
  19. Nov 4, 2022 at 7:12 AM
    #9579
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Meh, it'll probably hold. Best weld for that would be 1/8" (minimum) 7018 stick rod turned up pretty damn hot. If I was using our 480V welder at work I'd probably have it turned up to at least 120a.
  20. Nov 4, 2022 at 7:24 PM
    #9580
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
