Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Dec 30, 2022 at 10:42 AM
    #9721
    My Name is Rahl
    I bought a Husqvarna, can't remember the CCs, but the 16" bar has been enough for the occasional tree work I have to do on my little acre.
    six5crèéd[OP] likes this.
  2. Dec 30, 2022 at 11:46 AM
    #9722
    My Name is Rahl
    Hoping one of you can help me. I have this MTD rear tine rototiller that I need to find either a carb rebuild kit or a new carb completely. I tried looking online, but I know so little about compatible carbs that I kinda just gave up. It has a Tecumseh engine, if that helps. I also need a new muffler, but that's secondary.
    six5crèéd[OP] and wilcam47 like this.
  3. Dec 30, 2022 at 12:04 PM
    #9723
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    This is what i found. From that placard. Might find a suitable sub cheaper, carb is $130
    https://www.partstree.com/models/hh60-105079d-tecumseh-engine/engine-parts-list-2-1/
    Carb
    https://www.partstree.com/parts/tecumseh-630994a/
    Carb kit
    https://www.partstree.com/models/ca-630994a-tecumseh-carburetor/carburetor-0/
  4. Dec 30, 2022 at 12:10 PM
    #9724
    My Name is Rahl
  5. Dec 30, 2022 at 6:25 PM
    #9725
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    I second the 261. Love it for the power to weight. It will pull a 20” bar easily and quite light for all day work. you mentioned beer money reserves, the time saved in cutting with spending a little more will leave more time for beers.
    also look for some older huskys like a 372.
  6. Dec 30, 2022 at 9:37 PM
    #9726
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
  7. Dec 31, 2022 at 2:55 AM
    #9727
    Tacoma Mike
    Southern Maine
    I buy all my carbs from Amazon. Like ten bucks. I buy 3 or 4 before winter.
    People don’t store their shit right…
    Not worth the time to try and clean them..
  8. Dec 31, 2022 at 5:29 AM
    #9728
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    Would it really be that much faster cutting? Than say something like a 271? The 261 definitely is well recommended here and elsewhere but that price tag... Leaves me with $25 for beer. That's not even a 12 pack here. Ha.
    The 271 is almost $300 cheaper.
    I see some say the 261 will last "forever" but you may only get 10 years out of a 271. It can't be that bad? I won't be thrashing these saws. I don't need to bushwack with them, toss them in the truck, hike with them, etc. I assume if you treat it well you should be able to get more than a decade out of it. Even if the case is plastic.
    At most I'd be cutting 6 cords a year and a bit of dead fall.
    six5crèéd[OP] and markmizzou like this.
  9. Dec 31, 2022 at 6:34 AM
    #9729
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    I have a Stihl consumer level saw, not sure of the number, 16" bar. I've used it to cut at least 15 cords of wood at this point and it is still working fine. I also cut up some really big stuff with it. My favorite feature is the easy pull starter rope; there's a spring in there that you load by pulling slowly on the rope, then it releases and spins the motor. Clever, handy feature.
  10. Dec 31, 2022 at 6:37 AM
    #9730
    wilcam47
    Will
    Bourbon state
    Same, but 18" love that feature
    six5crèéd[OP] and RustyGreen like this.
  11. Dec 31, 2022 at 6:58 AM
    #9731
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Not a chainsaw, but I remember many years ago we had a lawnmower with a wind-up crank starter. You would wind it, then press a release lever and the spring would spin the motor to start.
  12. Dec 31, 2022 at 7:44 AM
    #9732
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Every Saturday morning you would hear the very distinctive ratchet sound of them being cranked followed by the loud snap as the spring released all around the neighborhood - sometimes the mowers started too. :laugh: The sounds carried well, there seemed to be dozens of them around back then.
    The handle unfolded to crank.
    And then snapped closed for use, some had a key lock to keep kids from tinkering.
    There is a pawl, visible at 7 o'clock, that held the flywheel until the knob on the side was pulled.
    As the pawl wore it could release the flywheel before you had the spring cranked up all the way. :annoyed:
  13. Dec 31, 2022 at 7:47 AM
    #9733
    wilcam47
    Will
    Bourbon state
    Never seen those! Neat
  14. Dec 31, 2022 at 10:07 AM
    #9734
    markmizzou
    Mark
    Missouri
    With your amount of cutting AND if you are diligent about care your saw(s) will last you many many years. Of course this depends on you buying a quality saw to begin with -like a Stihl, Huskie, or Johnsenred. Bring the saw in and do not leave it out in your truck, start it every couple of months -if not using, and always store with a full tank of gas. Some will say never use gas with ethanol- but I always do and in my 55 years of using small engine equipment -I have NEVER had a fuel related problem -except in our "shared -ownership" wood splitter where my dumb neighbor kept getting water (condensation ) in the fuel he was using. He was storing the metal fuel cans half full in the outsise sun and cool cyclye of the daytime/night.
    Don't fool with the carbureator adjustments of 2-stroke, unless you absolutely know what you are doing. These are touchy.
    This is why the M-tronic stihls are so nice -they are computer chip controled. The guys that like to soup-up their chain saws do not like the m-tronics as they can't do their "thing" to them. If you want to know more personal experience I have had with the 261CM -PM me - I hate typing!
  15. Dec 31, 2022 at 10:19 AM
    #9735
    markmizzou
    Mark
    Missouri
    Faster cutting -- probably not -that mostly depends on several things -Saw chain sharpness, type of chain, type of wood, dryness of wood (green woods of any type cut faster just because of the natural lubrication of the wood moisture. Also hardwoods (oak hickory etc)of any type will cut slower than soft woods (pines firs etc) -thats just common sense. And all of these depend on the saw running at its best.This is another area the M-tronics stand out. I did also mention "type of chain" -Full chisel chains are usually the fastest cutters of the wood chains, problem is -they dull faster and tend to grab a bit more than the rounded over chains. too much "grab" is also called "kick-back" and can be very dangerous to the operator who does not know to control it! be careful with kick-back on a smaller/lighter saw with a shorter bar. Again my experirnce has taught me smaller saws with lighter/shorter bars will tend to rise back at you more than the bigger/heavier saws.
  16. Jan 1, 2023 at 7:48 AM
    #9736
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I’ve got a Husky Rancher 460 that has been fine running a 24” bar for some 70+ foot trees I’ve had to drop around the property. That being said, pick any of them from Husky, Sthil, or Echo, and you’ll probably be happy. A friend has an Echo CS590 that he’s used really hard with no issues either doing similar work.
    the downside to the 60+ CC stuff like @RustyGreen said is that they are heavy. The pro-grade stuff’s biggest difference is that they get lighter with magnesium parts but I’m not using it every day, all day, so higher end homeowner stuff works fine for me and saves a few bucks
  17. Jan 1, 2023 at 8:22 AM
    #9737
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    I have worked my husky 435 hard clearing 40+ trees. Mix of poplar, oak and hickory. Thing is a little beast! With that said I recently bought a 395xp with a 32” bar and it puts the little 435 to shame cutting rounds. Thinking about a mid sized saw next, maybe a 372xp if I can find a good deal.
  18. Jan 1, 2023 at 8:44 AM
    #9738
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    This is sort of the way I'm leaning.
    Spending $1000 on a Stihl 261 that I'll use maybe 40 hours a year seems a bit excessive. Getting a top "homeowner" saw for 600 or 700 bucks seems a bit more palatable.
  19. Jan 1, 2023 at 8:51 AM
    #9739
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    There is one used saw for sale near me.
    It's a ten year old Husqvarna 455. Half the price of a new one. Looks to be in good condition just needs a new chain. Anyone have thoughts on this? Is half price still too much? I feel it may be but I don't really know the market for used saws or how much they change over 10 years.
  20. Jan 1, 2023 at 4:59 PM
    #9740
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    So no good deed will go unpunished it seems. My co-worker is in the process of buying their first home which is situated on 3 Acres. They currently live in a townhouse so they have no lawn care equipment...
    A while back I gave my other friend my old 30" rear engine rider. She hasn't used it so I just need to pick it back up...
    The bad part is it has been hard to start for some time despite good batteries. It has the Briggs 21B807 13.5HP Intek which is known to throw the compression release assembly. Just so happens that it only comes with a new camshaft, which is almost $100. o_O So that, plus a new battery and other things I got to do to it, I'm gonna be out some cash just to give it away. But hey, I think it will be for a good cause. Is it too small for 3 acres, well of course, but after all the expense of home buying it can be a financial drain and this is better than no mower at all. The rule is though when they get a chance to get a new mower I get it back and any future breakage will be a small pick-up and delivery fee with only parts cost, no labor. I also have a spare gas powered blower I'll give them.
    Got to re-weld the deck and some other things along with tearing open the engine. Gives me something to do.
