Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Jan 2, 2023 at 4:12 PM
    #9761
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    six5crèéd[OP] likes this.
  2. Jan 4, 2023 at 10:53 AM
    #9762
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Gotta say...glad we picked up this tractor. Did find out its on real "flaw"....the hydraulics DO NOT like to work when its below 0 lol. I dont blame them though as thats just a general hydraulic thing more than the tractor.
    Did look into getting chains for it as it did slide a bit when at the edges ofe the road but man they want a ton of money for them!
  3. Jan 4, 2023 at 11:30 AM
    #9763
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    :thumbsup:
    I’m sure built chains probably cost a fortune, but I think you could probably build them yourself for less. Patrol the chain off removal area of your nearest highway, you’ll likely find a bunch of broken chains that can be pieced together to fit the tractor.
  4. Jan 4, 2023 at 11:40 AM
    #9764
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Absurd how expensive this tire chains are. I did the same thing recently when I looked for chains, wild prices!
  5. Jan 4, 2023 at 11:58 AM
    #9765
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    Many on the JD forum and I’m sure other brands have been grooving their R4s for better traction. Everyone says the results are worth the effort.
  6. Jan 4, 2023 at 12:00 PM
    #9766
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    One of those pictures you can smell :eek:
    po35042 and wilcam47 like this.
  7. Jan 4, 2023 at 12:08 PM
    #9767
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Id seen that. Done it before on other tires and was never super impressed with it. Im talking more "side" hill slipping than straight too. It did just fine going straight or in reverse through the snow. Just when it would get up on any sort of "side hill" tended to slip sideways
  8. Jan 4, 2023 at 12:21 PM
    #9768
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Kubota’s new r4 looks pretty good
  9. Jan 4, 2023 at 12:32 PM
    #9769
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
  10. Jan 4, 2023 at 1:19 PM
    #9770
    My Name is Rahl
  11. Jan 4, 2023 at 1:23 PM
    #9771
    Clark27
    Springfield, MA
    2015 Lexus GX460
    Definitely not prepared for that wallet shock. As a new homeowner with new machinery, you really gotta pay to play with the big boy toys.
  12. Jan 4, 2023 at 4:32 PM
    #9772
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Where there’s a will, there’s a way…:cool:
  13. Jan 4, 2023 at 4:43 PM
    #9773
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I want the tires, but I’m not looking forward to buying them. I don’t know if they are much more expensive than the R4 tires, but I think they will be worth the money. However, I won’t be buying them until my current R4 tires are all used up.
  14. Jan 6, 2023 at 12:05 PM
    #9774
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    hey fellas- to the one that advised the noco charger, thank you! question about it (as i burned the manual like a man) if it has the pulsing red light indicating charging, is it obvious when its at full charge? my yota is in the shop with a potentially blown motor and im trying to hurry to get my other truck running.
    after 2hrs i tested it and im near full charge. this little charger kicks ass!
  15. Jan 6, 2023 at 1:17 PM
    #9775
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Try a Google search with the model of the charger you purchased and manual in the search terms and you should find the manual online.
  16. Jan 6, 2023 at 2:38 PM
    #9776
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I have a different Noco charger, but I think it should turn solid when it’s done. But you can likely find the manual on there website.
  17. Jan 6, 2023 at 4:58 PM
    #9777
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
  18. Jan 6, 2023 at 5:03 PM
    #9778
    Jesse
    Poulsbo
    15' DCSB OR S/C
    thank you. really weird. light was red but battery showed 12.7?? wouldnt idle for nothing until 5min warm up. ill try running it for a little then charger again.
  19. Jan 6, 2023 at 5:16 PM
    #9779
    RustyGreen
    sleeping in a chair
    Pavement Princess
    If the fuel is old sometimes they won't run very well until the engine is warm.
    If you have the Genius 1 charger it is only a 1 amp unit, it will take a long time (around 60 hours) to go from dead to fully charged.
    If you can run the engine for a while the alternator is much more powerful obviously, it will get the bulk of the energy back in the battery, then put the charger back on and leave it overnight or longer if possible.
  20. Jan 8, 2023 at 7:18 AM
    #9780
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Did long delayed full maintenance on my Gravely. First I cleaned it. Filthy.
    Uh oh, blades were not salvageable. So may as well do all I can along with blades. New replacement grass chute, new belt, oil and filters, plugs. Foam sock for AF. Leveled the deck.
    I have to say I beat on this thing pretty hard. Used for clearing 5 foot common tansy. Other tall brush. I've hit more rocks and holes and sand mounds and 3" branches and 10" stumps than I can count. I guess the good news is the property is much more tame now. Life for the beast may be easier. Hhahahhahaha
