Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. May 26, 2023 at 8:32 PM
    bigmw
    bigmw Not-So-Well-Known Member
    Northeastern Ontario
    2016 Blue DCSB Sport 4x4, manual transmission
    Bunch of different mods
    Should I take the whole thing off and open it up to check how is adjusted or just play with the screws?
  2. May 26, 2023 at 8:38 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Gotta pull the float bowl off to mess with it.
    Probably easiest with the carb removed. Is it a new chinesium carb? Can you exchange it?
    Might take the time to first see if you can determine where the leak is coming from.
    https://www.motorcyclepowersportsnews.com/mechanisms-of-fuel-delivery-the-float-valve/#:~:text=The float valve has three,is retracted from the orifice.
    In that link, it talks about connecting a hose to the bowl drain and opening the drain with the hose bent up. If the end of the hose is higher than the float bowl and fuel pours out of it, that's definitely your problem. Good, quick test prior to removal.
    bigmw[QUOTED] likes this.
  3. May 26, 2023 at 8:44 PM
    bigmw
    Chinesium it is, probably too late to exchange - bought it last year, and didn't have time and space to play with it until now.
  4. May 27, 2023 at 7:16 AM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Should be a fuel shutoff valve. Close it and clean the exterior of all gas. Then open the valve and watch where gas is leaking from. Yes the float can be the culprit because it prolly got jammed during handling or shipping. The float pushes a cone shaped plug upwards into the fuel feed when the bowl fills. This part might be jammed or damaged or missing. There’s a small
    linkage to let the float swing up and down and it could be jammed or whatever. I’ve had an old Craftsman pressure washer that the float would stick after sitting for a long time. I would wack the side of the bowl with the handle of a screwdriver a couple times to get it to drop and it would fill with gas and start. First thing I’d do though is shut the fuel valve off and find exactly where the gas is coming from. Could be the bowl drain bolt or something simple
    shaeff and bigmw like this.
  5. May 27, 2023 at 12:26 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    good point mentioned up there....
    if its one of the chineseium replacement carbs? many of these are junk right out of the box & have that exact fuel flooding thru problem.
    had this happen on 2 rplacement carbs for my mini truck that were chi-com versions. had to go get a Mikuni to get it right.
    bigmw likes this.
  6. May 27, 2023 at 1:56 PM
    bigmw
    I was afraid that would be a problem. The replacement looks cheap and some of the parts aren't even the same dimensions. (before someone says it's not the right carb - it is a very peculiar looking carb, and so is the replacement)
  7. May 27, 2023 at 6:53 PM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    I’ve actually started a compost area specifically for making top soil to fill holes and grade with. It’ll be a long, slow process but it’d break the bank to have that much top delivered.
    A suspension seat on my zero turn would be more cost effective. I’ll get it graded out eventually.
    Kbar[QUOTED] likes this.
  8. May 28, 2023 at 8:50 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    What do you guys think of Mahindra tractors? I found this Mahindra 2815 for 3500 with the attachments. Hours unknown.
    Looking at this and the Kubota I previously posted up
    E8C97572-90CA-4A0D-A7A6-D1C5347F4177.jpg 3AF8685E-2E73-4AC8-A103-A4F7493B1A10.jpg
    wilcam47 likes this.
  9. May 28, 2023 at 9:14 AM
    Kbar
    Western WA
    22 OR
    What’s up with the missing cowl? And the chain as a top link…Looks like a headache tbh
  10. May 28, 2023 at 9:23 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Mahindra is a decent brand, but that tractor has been around the block a few dozen times. I couldn't give it a thumbs up without a lot more details and a though understanding of what's going on with all the straps and chains...
    sdk1968 and wilcam47 like this.
  11. May 28, 2023 at 9:50 AM
    anthony250f
    Anthony
    San Diego, CA
    I definitely noted the same. Had another photo of it on driveway with a mat underneath. Probably leaks. I liked that it had a loader but honestly have zero use for that as I just need to mow only.
    might go take a look at that Kubota and try to ‘restore’ it with some fresh paint to get it to look more like
    the Kubota definitely looks stout
    Kbar[QUOTED] and Tiedie like this.
  12. May 28, 2023 at 10:08 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    With your use in mind, I would go for the Kabota over the Mahindra.
    sdk1968, Kbar and Tiedie like this.
  13. May 28, 2023 at 11:35 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Kind of chainsaw related. Went with my father to help him get firewood. Using the BLM maps and permit info, we found a couple pieces of madrone but nothing spectacular. Ended up running into a couple guys from the logging compay I worked for. After a but of BSing, they said if I go up to the site they are working, they decked a bunch of madrone.
    They weren't kidding. Got a little over a cord of clean madrone and there is enough still there l, I could take a self loader up and get a good load if I had room to put store it.
    KRAMERICA likes this.
  14. May 28, 2023 at 11:40 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I would tend to agree with Kbar and Kramerica walk away. Mahindra seems to be a (Gray Market) here in the states thru regular channels. At least around me. Kubota good to go parts are easlily had.
    Check if when Kubota is running if you can turn key back 1 click and motor keeps running but not clicking hrs. if so hrs. might not be accurate. My B7100 can do that.
    Kramerica is partial to the other orange tractor.
    KRAMERICA[QUOTED] likes this.
  15. May 28, 2023 at 1:22 PM
    Kbar
    Western WA
    22 OR
    Them old school Kubotas are tanks. Definately my pick of the 2
  16. May 28, 2023 at 1:33 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I really like that! Price doesn't look bad, either. I have a 16 ft Big Tex car hauler and it's good for a small to medium size vehicle or loading pallets of stuff, but too big to use for lighter work.
    Something like that in addition would be perfect.
    Toyko Joe[QUOTED] likes this.
  17. May 28, 2023 at 1:44 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Hour meter is driven thru tachometer, you can see the drive cable on right side on the top engine pic. Cable driven hour meter and tach, the down side is, hours aren’t linear due to engine speed, lower engine operation the hours rack up slower, engine rpm at suggested PTO speed and they track pretty well. Pretty common in older machines in machines with tachometer and hour meter in same housing. Many diesels don’t need power once running so don’t have much of an electrical system. Fuel solenoid doesn’t pull much power if so equipt, many have manual fuel cut to shut down.
    Tiedie[QUOTED] likes this.
  18. May 28, 2023 at 1:52 PM
    Tiedie
    David
    WFOY
    I gotcha but my 79 B7100 if left with the key turned on it keeps ticking even though the engine is off, same for when just idling. Might just be mine. I will have to really watch it.
  19. May 28, 2023 at 2:42 PM
    sdk1968
    03 Taco TRD
    mahindra makes a fairly strong tractor.... but the support for them & parts are not on the same planet with the Kubota.
    an old Kubota is still a Kubota & its value is gonna stay higher than the chi-com tractor.
    trust me on this: ive got Kubota(Japanese) & Kioti(Korean version) tractors & while the Kioti is built to the exact same specs ...... its value is 30% less than the Kubota.
    hard to go wrong with a good Kubo.
    KRAMERICA, Kbar and Tiedie like this.
  20. May 28, 2023 at 6:30 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Wasn't someone looking for a Kabota deck because theirs was rotted out? I don't remember the size, but saw this one and figured would hurt nothing to link it.
    Blkvoodoo and RustyGreen like this.
