Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you mow in shorts?
  1. Mow, yes, weedeat, no
    44.0%
  2. Mow and weedeat, yes
    34.0%
  3. Pants all the way for me
    22.0%
  1. Jul 24, 2023 at 2:34 PM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    In the meantime, the to do list is:
    -Fabricate bracket for muffler- the Briggs muffler is not welded to the pipes and sits on a bracket for easy removal. Kinda neat.
    -possibly swap the hour meter from the craftsman and run parallel to the Ferris meter to easily track engine hours.
    -adjust throttle cable
    -eventual oil filter relocation kit
    Parts on the way:
    -voltage regulator
    -replacement fuel pump pulse hose
    -new plugs
    -cap for front caster wheel upper bearing
    I mowed with it on Saturday. It has PLENTY of power. I’m honestly impressed. It didn’t bog cutting my VERY overgrown yard at 3.5”. It feels amazing to have a machine that I don’t have to mess with before I mow. Turn the key, it comes to life.
  2. Jul 24, 2023 at 4:11 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Looking for a little help tracking down a battery for my father in laws tractor. Older model 855 John Deere bucket loader. Needs to be jumped every time you want to use it and it’s been at my property for a bit now. Figured a new battery would be a nice thank you. The current battery is not original to the tractor. Including the VIN plate if that’s the way to track down battery stats.
  3. Jul 24, 2023 at 6:45 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Batteries are sold by group size (dimensions & post location) and then cranking amps within the group, more amps = more $$.
    Usually there are a few cranking amp selections within the group, personally if I am going to keep the vehicle I purchase the largest amp battery that will fit in the holder, they seem to last longer.
    If the current battery sits in the holder properly it is probably the proper group, take it to your local NAPA store or other reputable dealer, they can either look the tractor specifications up or match the size. Deka is a quality brand, made in Pennsylvania.
    I prefer not to buy batteries from Auto Zone or Advance.
  4. Jul 24, 2023 at 6:45 PM
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    Go to your closest Deere dealer and buy the John Deere strongbox battery for it. They are just a little more but last very well and are worth what they cost
  5. Jul 24, 2023 at 7:45 PM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    Stepping in to read and try to help.
    I found a parts catalog for the 855.
    https://partscatalog.deere.com/jdrc/navigation/pin/M00855d630062/equipment/73152
    Click on the right side and you can drill down in, ie: electrical, then battery. I believe it was item #12. Click on it and it will give you battery info. Or I could just do it for yea. Haha
    Verify with JD as well.
    koditten likes this.
  6. Jul 24, 2023 at 8:18 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Sold out.
  7. Jul 24, 2023 at 8:36 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Delta09 and KRAMERICA like this.
  8. Jul 25, 2023 at 2:42 AM
    fxntime
    I think they made that one go ''yoink.'' They have a yard force one also that, if you try to pull it up, it shows unavailable.
    There were quite a few of those available last night pretty late so I don't think they actually sold out unless someone snagged the entire lot for resale.
    w.adventures[QUOTED] likes this.
  9. Jul 25, 2023 at 3:35 AM
    w.adventures
    Nowheresville, SC
    We shall see if it ships. I should have ordered the champion rear tine as well for $179.
    Delta09 likes this.
  10. Jul 25, 2023 at 10:38 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
  11. Jul 25, 2023 at 12:13 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    That's a slightly different model than the one I bought. I'm thinking about ordering this one as well and taking back the one I like least. Looks like the same motor but there are some different features and the size is considerably different. They gave me an est delivery date of Aug 3rd on the first one.
  12. Jul 25, 2023 at 12:23 PM
    w.adventures
    Nowheresville, SC
    I have been contemplating ordering the champion rear tine for $179 as well. Which other one did you buy?
  13. Jul 25, 2023 at 12:26 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
  14. Jul 25, 2023 at 12:28 PM
    w.adventures
    Nowheresville, SC
    Still shows up for me:notsure:
    Delta09[QUOTED] likes this.
  15. Jul 25, 2023 at 12:31 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Hmm, just tried it again. Used Chrome instead of Firefox on my phone and it came up. Weird :notsure:
    I hope it all goes through. Really want to plant a garden and this is a great deal to get started.
    KRAMERICA likes this.
  16. Jul 25, 2023 at 12:34 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I ordered the other Legends Force that's sold out for $199. The one I ordered has an adjustable handle and selectable gear drive, but it's 60 lbs heavier. I can see the weight being better in some ways and worse in others. HD claims retail price on the one I ordered at $699, vs. $849 for the one sale for $179. They look to have the same 212cc engine. The heavier model digs a little deeper and looks to have four spokes per tine vs. three. With the easy return policy they have, I think it makes sense to buy them both.
    Legend Force 20 in. 212 cc Gas Rear Tine Tiller, Forward/Reverse LF20212RTG - The Home Depot
  17. Jul 25, 2023 at 12:54 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
  18. Jul 25, 2023 at 1:07 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    w.adventures likes this.
  19. Jul 25, 2023 at 3:19 PM
    fxntime
  20. Jul 25, 2023 at 3:27 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Does anyone with any experience with walk-behind tillers want to weigh in on the differences in these machines?
    My main concern is handling the 60# difference in their weight. 218# vs 158# I think I could manage to lift 158 lbs into the back of my truck; I don't think I could do the same with 218 lbs. Taking the bigger machine anywhere would certainly mean bringing along ramps for loading.
    I like the rotating handle, and the gear drive transmission seems like it'd be worth the extra $20. Also, it appears like the heavier machine doesn't have an option for freewheeling the tires, like the lighter machine.
