Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Sep 12, 2023 at 10:00 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I always put a petcock on all my mowers and engines without to shut off the fuel to keep the tanks full to keep the metal tanks from rusting.
  2. Sep 12, 2023 at 10:08 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Been driving since this morning. Sorry it took so long to respond.
    I'm more of a Kohler guy. With that said, they operate pretty much the same.
    I'm sure once you dive into it, the issue will be easy to fix.
    You got a linkage from the gov shaft to the throttle. I'd check there first.
    I'd even bet, you already figured it out.
  3. Sep 12, 2023 at 10:11 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I haven't looked at it that close, thanks for the response. I'll try and get to it one day this week, wasn't sure if it was a common problem or not is why I thought I'd ask :thumbsup:
    koditten[QUOTED] likes this.
  4. Sep 12, 2023 at 10:28 AM
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    When we moved in I noticed the salt taste but tbh we just adjusted to it and before too long didn’t taste it anymore.
    The dog came back from the vets after a full blood panel and came back with high sodium levels, that triggered me buying a hydrometer…
    Im sure for some people it could create problems. However people that are drinking a gallon of water a day probably aren’t eating too unhealthily or likely have a good water filtration system.
    EDIT: Kirkland water has approximately 27 ppm vs 630ppm city water.
    Delta09 and RustyGreen[QUOTED] like this.
  5. Sep 12, 2023 at 1:11 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Wow!
    Delta09 likes this.
  6. Sep 12, 2023 at 5:22 PM
    koditten
    Kirk
    Central Michigan
    It's no more NaCL than what people have that have water softeners.
    I don't see it being a big deal beyond the taste.
    wilcam47 likes this.
  7. Sep 12, 2023 at 5:50 PM
    mosccat
    Mark
    2020 OR
    With a salt water softener you should not have any salt residue left after the rinse, the resin beads do the softening not the salt.
    Also USEPA recommends no more than 200ppm for drinking water, but it's not regulated at a federal level so AZ can get away without treating the water to lower the levels from 630ppm. Crazy.
    wilcam47 and koditten[QUOTED] like this.
  8. Sep 14, 2023 at 6:41 AM
    Tiedie
    David
    WFOY
    All you guru's how are vanguard engines looking into woodmaxx chipper. Just curious how they stack up?
  9. Sep 14, 2023 at 6:46 AM
    koditten
    Kirk
    Central Michigan
    They are good engines. They are considered the Commercial version of Briggs and Stratton.
    What HP was the original chipper mower?
    six5crèéd[OP] likes this.
  10. Sep 14, 2023 at 6:47 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I have a Vanguard 16 HP twin on my wood chipper.
    It starts instantly, is smooth & quiet and seems to be good on fuel.
  11. Sep 14, 2023 at 6:52 AM
    Tiedie
    David
    WFOY
    Enlighten on wood chipper please.
  12. Sep 14, 2023 at 6:55 AM
    Tiedie
    David
    WFOY
    It would come with new chipper 14hp.
    https://woodmaxx.com/product/woodmaxx-dc-1260/
  13. Sep 14, 2023 at 7:08 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    It is a DR Products, probably around 20 years old.
    It will process 5" round with ease and makes piles of brush disappear.
    It was painfully expensive, on the other hand it is built like a Mack truck.
    Maintenance is 2 grease fittings on replaceable 4 bolt flange bearings, a carbide chipper knife, 2 belts plus regular engine care.
    With reasonable care I don't think you could wear it out with just personal use.
    https://www.drpower.com/power-equipment/chippers/wood-chippers
    This model is road towable, I made an adapter to pull it around with a garden tractor.
    There are no mods to the chipper, the big bolt is where the original chintzy stand went, remove it and uncouple the ball and it is ready to go on the road.
    Daisy, the yard foreman.
  14. Sep 14, 2023 at 11:00 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    this is a model or two up from mine. and about 3x the price. dr makes a fine setup for the money. very pleased with mine.
  15. Sep 14, 2023 at 1:02 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    It is a powerhouse, one person can't keep it occupied.
    You really need a 3 man crew to be efficient:
    Machine feeder
    Man to keep the feeder stocked
    Man to rake away the chips
    Of course there is just me to do it all...
    :goingcrazy:
    Tiedie likes this.
  16. Sep 14, 2023 at 1:11 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Just a remind but I’m sure everyone knows. Put the battery on wood. Never on concrete or just on the ground.
    MoneyMan55 and RustyGreen like this.
  17. Sep 14, 2023 at 1:30 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    "They say" the modern high dielectric plastic cases make that unnecessary...
    :gossip: ...but you will never find a good battery sitting on concrete in my garage... :fistbump:
    FastEddy59[QUOTED] and koditten like this.
  18. Sep 14, 2023 at 1:37 PM
    koditten
    Kirk
    Central Michigan
    Not an issue these days, but a good practice in case the battery leaks. The wood will soak up the leaked acid, vs eating at your nice shiny concrete.
    RustyGreen likes this.
  19. Sep 14, 2023 at 1:41 PM
    koditten
    Kirk
    Central Michigan
    Well, shit!
    I battled with a mouse infestation in this unit last year. Got it all cleaned up and sealed up against those evil little shits.
    It ran it's weekly test cycle for the last 2 months.
    This week she ran for 15 seconds.
    After that, one of the connecting rods decided it needed some air.
    Out it comes again so I can replace the fucking engine!
    Not gonna be this year.PXL_20230914_203217914.jpg PXL_20230914_203201285.jpg
    FastEddy59 likes this.
  20. Sep 14, 2023 at 1:43 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Gonna call it; it's the Fram oil filter... :anonymous:
    :D
