Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Sep 16, 2023 at 1:53 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    A decent midsize inverter generator would be ideal for freezer/refrigerator use, MUCH quieter and cleaner power smoother sine wave VS the saw tooth square wave that normal “neighbor hater” loud generators put out. Inverter generators also tend to be more fuel efficient.
    Fuel consumption on LP will be about 25% higher as LP doesn’t make as much power per gallon. If you’ve got a 250-500gal tank at the ready that wouldn’t be an issue for several days with a 9kw gen set, even better if you had natural gas to the house.
    I have a 3500w Preditor inverter gen from Harbor Freight, so far it’s been fabulous, runs both a freezer and a fridge. I have a smaller 2000w suitcase Preditor I use on my work van for fans and charging batteries, using it to power a heat gun or a coffee maker makes it angry, but it does the job.
    308savage[QUOTED] likes this.
  2. Sep 16, 2023 at 3:45 PM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Ok gravity fed runs like normal, I replaced all the fuel lines when I bought it but I did blow them our as you suggested, put back to normal and its still surging, the flow from the pump does seems slow. I did check the fuel cut off solenoid on the carb and found that the plunger had been removed by a previous owner. Ordered a new fuel pump and cut off solenoid that should arrived Monday, hopefully its just that basic.
    Does a bypassed fuel cut off solenoid really stop the engine from backfiring when its turned off?
    RustyGreen[QUOTED] and koditten like this.
  3. Sep 16, 2023 at 3:51 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The reason is to keep fuel from flowing into the carb float area. The floats can jiggle when the mower is on a trailer going to next job. When the float jiggles, it lets raw fuel into the carb. It's not getting burnt, so that extra fuel goes into the engine and dilutes the oil.
    It's second function is to reduce back firing when you shut off the engine.
    RustyGreen and Tiedie like this.
  4. Sep 16, 2023 at 4:09 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    we got one from home depot. Its dual fuel...it burns a lot of propane when you use it
  5. Sep 16, 2023 at 5:29 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Realized the gas I was using was 87 ethanol free. Found another semi local gas station that has 90. It should work better in my saws and leaf blowers
  6. Sep 17, 2023 at 6:46 AM
    koditten
    Kirk
    Central Michigan
    I'm confused.
    Is the 90 octane ethanol free as well?
    Ive never noticed small engines run better or worse on 87 vs 90 octane.
    For that matter, if you are using such small quantities, the extra cost is not really an issue.
    KRAMERICA and wilcam47 like this.
  7. Sep 17, 2023 at 7:01 AM
    w.adventures
    Nowheresville, SC
    Yeah, 90 is ethanol free as well. Figure the higher octane is more beneficial in the 2-stroke chainsaws and leaf blowers. Husqvarna premix fuel is 95 octane.
  8. Sep 17, 2023 at 9:32 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    My Echo 2-cycle weedeater, blower, and chainsaw all call for 89 octane. The manuals say ethanol is ok.
  9. Sep 17, 2023 at 9:35 AM
    Tacoma Mike
    Southern Maine
    Sure it is. Easier to get money from you.
    RustyGreen and koditten like this.
  10. Sep 17, 2023 at 10:21 AM
    perterra
    perterra Well-Known Member
    Tejas
    I picked up a Champion dual fuel 2000 off Amazon for $450 back in 21. Called Champion to make sure they would warranty it if I had issues. They said with Amazon they would have all the info and it would be covered. 2000 watt gas, 1750 on propane. I got about 30 hours on a 20 lb BBQ tank and 10 hours on a gallon of gas. I bought it after the big Texas freeze up left us without power for 3 days mostly to run CPAP's, charge batteries and some tools.
    Hard starting on propane, gas is a 2 pull affair so I just put a cup of gas in it, start it and switch it to propane. Then when I am through I switch back to gas and let it run dry.
  11. Sep 17, 2023 at 12:37 PM
    koditten
    Kirk
    Central Michigan
    This is a good recipe.
    308savage and RustyGreen like this.
  12. Sep 17, 2023 at 1:31 PM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Here's my setup Generac xp8000e with transfer switch next to main breaker box.IMG_20230917_162647289.jpg IMG_20230917_162655720.jpg IMG_20230917_162712424.jpg
    Runs basically everything but heat pump and oven. Been thinking about adding oven to it. Since hot water is propane.
    Delta09 likes this.
  13. Sep 17, 2023 at 1:44 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I would think 8K should be plenty to run the whole house at the same time. I would wire everything in and if it was close I would just be mindful to not run the highest wattage items at the same time.
  14. Sep 17, 2023 at 2:01 PM
    Tiedie
    David
    WFOY
    everything is there.At the time we had electric hw and pump hooked up on the side of caution.
    koditten likes this.
  15. Sep 17, 2023 at 2:11 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Somehow notifications on this thread got turned off. Getting caught up.
    I have the same stump grinder as all you guys. It's been an animal behind my 40hp tractor. Very very pleased.
  16. Sep 17, 2023 at 2:20 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Notifications on TW have always been hit or miss for most of the threads I follow. Just got to keep an eye on the "Watched" tab to see what's got new posts.
    Delta09, sdk1968[QUOTED] and koditten like this.
  17. Sep 17, 2023 at 2:33 PM
    Tiedie
    David
    WFOY
    So we live very rural. My water pump pressure tank, Rennai propane water heater, water filter, washer and propane dryer,deep freeze all in the garage, heated and cooled with 9000BTU mini-split and we fit both Tacoma and Forester in there too. Propane on that side is fueled by a 120 gal. tank. Other side propane fire place for extra/emergency heat,gas stove, weber gas grill on 250 gal. tank.
    My internet is thru the electric co. fiber optic, this year in Jan. will be 2 years with internet. When we call 911 they ash what state and county do you live in? I pay fire/rescue taxes in another county and have to call local sheriff if law enforcement is needed. (811 is a faster response). Nearest hospital is 45 mins. away fastest time.
    :rofl::rofl::rofl:When we say we're going to town we mean it.
  18. Sep 17, 2023 at 2:34 PM
    Tiedie
    David
    WFOY
    Mike do you live near Cookeville?
    sdk1968 likes this.
  19. Sep 17, 2023 at 2:55 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Cookeville is a tad over an hour to the NE of me or about 45 miles as the crow goes. Murfreesboro is a bit closer, 10 miles or 25 min to the west.
    sdk1968 and Tiedie[QUOTED] like this.
  20. Sep 17, 2023 at 3:02 PM
    Tiedie
    David
    WFOY
    :plane: upload_2023-9-17_18-2-40.jpg
    sdk1968 likes this.
