Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Sep 27, 2023 at 6:54 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Thats a plus! Weird the old one would blow up like that.
  2. Sep 27, 2023 at 7:00 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    exactly. ^^^^^^^
    i dont like that hydrogear5400 pump/trans combo. that & the price kept me from buying the Ferris.
    if they dont have separate pumps.... im out. unless of course the price was so good that you just dont care. :)
  3. Sep 27, 2023 at 9:44 AM
    Squirt
    Squirt #SoBadGotBannedFromOwnThread
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    It went for $3500 today!
    six5crèéd[OP] and wilcam47 like this.
  4. Sep 27, 2023 at 9:51 AM
    wilcam47
    Will
    Bourbon state
    :eek::eek:
  5. Sep 27, 2023 at 9:55 AM
    Squirt
    Ben
    That's a good price! Used ones at other places are going for $5k+!!!!
  6. Sep 27, 2023 at 10:30 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Spring is pretty far off in the future...
    wilcam47 and six5crèéd[OP] like this.
  7. Sep 29, 2023 at 5:02 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i realize chinese carbs are a very cost effective solution. my atv(tractor) is a pita for carb solutions. spent the 200 for an oem unit and plan to rebuild the stock as a spare. one vehicle i do care about so i justified that. should i wear a helmet at the lunch table or what?
    six5crèéd[OP] likes this.
  8. Sep 29, 2023 at 5:34 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You good.
  9. Sep 30, 2023 at 5:58 AM
    sdk1968
    03 Taco TRD
    getting ready to go do a quick cut & mulch up some leaves as i top off the grass this week.
  10. Sep 30, 2023 at 12:52 PM
    sdk1968
    03 Taco TRD
    grass done, leaves mulched, weedbeating done, mower washed & just finished a Taco repair!
  11. Sep 30, 2023 at 2:32 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Semi local Kubota ZG227 zero turn available with a bad pump. Tempting but it’s a single pump unit for both sides, not independent so I know it’s a pain and can get pricy for a shop to do.
  12. Sep 30, 2023 at 4:30 PM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    New fuel pump seems to have fixed my Dixon running rough issue, but now one of the dry rotted rear tires doesnt hold air for even 12 hours so I ordered new tires to deal with that Monday, Ill probably replace the front tires with run flats in Dec when I do general maintenance.
    Do you all have recommendations for parts websites with good diagrams? I have been using Jacks Small Engines but am having a hard time finding the lever position switches for both drive handles and the parking brake.
    six5crèéd[OP] and w.adventures like this.
  13. Oct 1, 2023 at 4:48 AM
    sdk1968
    03 Taco TRD
    JSE is where I get most my info as well... After that I ask over on the mower site & someone there always points me in the right direction.
    six5crèéd[OP] and koditten like this.
  14. Oct 1, 2023 at 7:13 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    https://www.napaonline.com/en/p/SFI21348
    Just run this on there though... :anonymous:
  15. Oct 1, 2023 at 7:18 AM
    koditten
    Kirk
    Central Michigan
    You fuckers just gotta poke the bear...
    I will cut the Fram apart to see if there was evidence oil starvation just to satisfy all our curiosity.
  16. Oct 1, 2023 at 8:34 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Mostly just me :rofl:
    I use Fram filters here and there, but still like pointing it out due to internet folk lore :D
  17. Oct 1, 2023 at 9:30 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Adam >>:boink:<< Kirk
    Rusty >>:boink:<< Kirk
    :annoyed: << Kirk
    Adam > :fistbump: < Rusty
    :rofl::rofl:
  18. Oct 1, 2023 at 9:54 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I've got some random filters here and there... :anonymous:
  19. Oct 1, 2023 at 2:57 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I found the attached parts list for 2002 Dixon. I don't see any electrical switches, but maybe it will help you anyway if you don't already have it...
  20. Oct 1, 2023 at 3:38 PM
    joeyv141
    Virginia
    I'll look through it thanks, what occured to me is maybe all four position switches may be the same exact switch.
